Old 07-24-2016, 04:26 PM   #1
Clonemaster 66
Leon Wilkins's Avatar
2016 25' Flying Cloud
Denver , North Carolina
Unhappy Ford backup assist sticker placement
Hi all,
I just got my new 2017 FC 25' to go with my 2016 Ford F-150, with the new trailer backup assist feature. Manual tells you to attach a special sticker (provided) horizontally on one Y-hitch arm in a zone 7" to 22" back from the hitch ball. Problem is, there is one of the propane tanks and the cover taking up this zone. Have any Ford F-150 & Airstream owners with backup assist run into this problem AND SOLVED IT?? Love to hear from you.
Newbie Clonemaster
Leon Wilkins is offline   Reply With Quote
Old 07-24-2016, 05:00 PM   #2
2016 27' International
Montreal , Quebec
I have a 27fb international and a 2016 f150 with pro trailer back up assist. I did not install the sticker myself, CanAm did when I picked up my new AS. There is a small corner of the sticker that is under the tank cover but it does not seem to be a problem. The available space on a 25ft might not be the same.
Papa smurf is offline   Reply With Quote
Old 07-25-2016, 10:17 AM   #3
2017 25' Flying Cloud
Victoria , British Columbia
I have the same truck and will have the same AS shortly. I am very curious to hear whether there is a resolution of this issue.
Hullap is offline   Reply With Quote
Old 08-07-2016, 10:17 PM   #4
SailorSam205's Avatar
Northville , Michigan
Just saw a post on the F150 Forum:
They confirmed to me that it can be placed either horizontally or vertically as long as it is within their "green zone" of 7" to 22".
Hope this helps someone...
SailorSam205 is offline   Reply With Quote
Old 08-07-2016, 10:39 PM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I helped a neighbor install his sticker; It went on the curb side and a small corner of it went under the propane tank cover as Papa smurf stated. The street side would be blocked by the brake switch.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
ROBERTSUNRUS is online now   Reply With Quote
Old 08-07-2016, 10:41 PM   #6
2019 27' Globetrotter
Salem , Oregon
I have the 2016 with backup assist. My trailer is a 23. No problem. Sticker had to go about 1/2: under tank. Works fine there.
Still not sure if it is worth the trouble. I have to back up a steep driveway and then turn.
Dave
NoResults is offline   Reply With Quote
Old 05-03-2017, 12:11 AM   #7
2016 26' Flying Cloud
Lake Arrowhead , California
This answer is amazing! Problem solved
Brianjward is offline   Reply With Quote
Old 05-03-2017, 05:51 AM   #8
2017 27' Flying Cloud
London , Ontario
Does this imply people might install the sticker on their propane cover?
Philip Jones is offline   Reply With Quote
Old 05-03-2017, 05:55 AM   #9
London , Ontario
Also, see this post (#2) which shows the Ford installation booklet: https://www.f150forum.com/f118/pro-t...estion-337277/
It clearly states that the sticker must be horizontal. It also states the entire sticker must be visible to the camera. Of the two conditions, I am guessing that violation of the latter may be of lesser importance. Any other thoughts?
Old 05-03-2017, 08:13 AM   #10
2017 23' Flying Cloud
Bartlett , Tennessee
So, a test.
Attach the sticker to a properly sized piece of aluminum. Place the sticker/aluminum on the propane cover, vertically, with double stick tape. Test it.
If it works, you can either rivet the piece of aluminum to the propane cover, or, remove the aluminum and place another sticker on the propane cover.
If it doesn't work, you are out 1 sticker.
Bobbo, Lin and the furry kid (45 pound rescue)
2017 F-150 4x4 SuperCab 3.5l EcoBoost V6
2017 Flying Cloud 23FB "BobLin Along"
Bobbo is offline   Reply With Quote
Old 05-03-2017, 08:24 AM   #11
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
I have a 2017 F150 towing a 2013 trailer. I put the sticker on the A frame next to the jack. One end of the sticker just touches the propane cover. The sticker also lays partly on top of the jack base so it's not exactly flat. In the end it barely met the minimum 7" requirement. Backup Assist sees the sticker and works remarkably well.
kscherzi is offline   Reply With Quote
Old 05-03-2017, 08:50 AM   #12
London , Ontario
Well, the proof is in the pudding! I have the same truck so now I know it will work. Thanks for sharing.
Old 05-27-2017, 08:32 PM   #13
BoatnutG2
BoatNutG2's Avatar
2015 28' Flying Cloud
Fountain Valley , California
Great thank you.
BoatNutG2 is offline   Reply With Quote
Old 05-29-2017, 05:23 PM   #14
I actually put the sticker on the propane cover, and seems to be working fine. All data was good, it found the sticker with no problem and calibrated quickly. I only backed down the street, and zigged and zagged a bit, and worked fine.
davloose is offline   Reply With Quote
Anybody have experience with Ford's New "Pro Trailer Backup Assist"? DaytonaDan Towing, Tow Vehicles & Hitches 35 10-07-2017 05:03 PM
Opinions on F150/Pro Backup Assist/25'+ clamb Tow Vehicles 39 09-29-2017 11:56 AM
Ford's Pro Trailer Backup Assist BW1 Tow Vehicles 10 09-17-2017 06:43 AM
Ford Dynamic Hitch Assist cwf Towing, Tow Vehicles & Hitches 2 12-12-2014 04:52 PM
Sticker Placement SwampBillies WBCCI Forum 12 06-21-2007 05:02 PM
