Old 11-21-2015, 09:30 AM   #1
2016 25' International
Upper Arlington , Ohio
Flamma Bike Rack
Looking for feedback from folks who have used the Flamma bike rack. We plan to take our bikes on the back of our 25FB on most every trip. I'm most interested in how well the rack performs and whether there is any damage, wear etc. that the AS suffers in the process. Thanks all.
Brad Waite
2016 25FB International Serenity
bwaite is offline   Reply With Quote
Old 11-21-2015, 09:59 AM   #2
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
We have the Fiamma rack on both our 19' and our 23'. It has worked well for us though others have reported a few problems like broken fittings. Also, Fiamma USA is not the most responsive group. Just have to be persistent.
Steamy1 is offline   Reply With Quote
Old 11-21-2015, 10:02 AM   #3
Also, do a search on the forum for Fiamma. Several threads are available with detailed comments and installation advice.
Old 11-21-2015, 11:33 AM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We've traveled extensively with the Fiamma, consider it an ideal setup. We also had a Fiamma on our VW Camper Van. Easy to use, bikes stay clean, has been no trouble. Subtracts from often excessive hitch weight.
Have seen a few reports of the Fiamma's shell mount breaking, one was loaded with heavy electric bikes, another not mounted correctly, another apparently just broke. No damage to the trailer. If you have a rear storage hatch it's harder to access.
Doug and Cheryl
Old 11-21-2015, 11:39 AM   #5
Good suggestion Steamy1. After a quick search, this guy will not be buying a Flamma.
Brad Waite
Old 11-21-2015, 01:08 PM   #6
dkottum's Avatar
Can-Am Airstream in London, ON also makes a custom rear mount bike carrier for an Airstream, and it folds down to access a rear storage compartment. Contact them.
Doug and Cheryl
Old 11-21-2015, 01:57 PM   #7
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
Maybe not, but we've been quite happy with their rack on our 27FB.
However, we're also cognizant of the weight limit specified for the rack. We carry no more than two bicycles of normal size and weight. We also don't carry any heavy stuff there, such as battery-powered bikes, recumbent bikes, etc.
Rocinante is our 2014 International Signature 27FB
Old 11-21-2015, 04:28 PM   #8
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I had one on my '12 28' Intl CCD. Do not have one on my '15 Classic. Main reasons: cast aluminum fitting broke ($56) -- and my bikes were not that heavy; makes rear window emergency exit unusable; very difficult to access rear storage area through the maze of aluminum. We went to Dahon folding bikes.
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 11-21-2015, 05:46 PM   #9
2015 Interstate Grand Tour
kirkwood , Missouri
My father-in-law fabricated a hitch receiver for the back of our 27fb which is bolted to the frame of the AS. It's super steady and does not add a bunch of weight to the rear. The main issue I found with putting a rack on the rear is apparany associated with older model AS experiencing rear end separation. We aren't all that worried about it. Our bikes weight 50lbs plus the rack plus steel.
I have a few pics if interested.
epicdetour is offline   Reply With Quote
Old 11-21-2015, 07:58 PM   #10
Flht2k's Avatar
sacramento , California
Could you post a few pictures underneath and from the front. Thanks
Flht2k is offline   Reply With Quote
Old 11-21-2015, 09:10 PM   #11
dkottum's Avatar
We have been cautioned by some Airstream repair shops here on the forum about using a bumper mounted rack without struts attached to the shell to hold the rotational downward and increased G forces imposed by movements of the trailer going down the roadway. They suggest the weight on the frame will be increased far more than the static weight of the bikes and assembly. The frame will flex independently of the shell, or try to.
Doug and Cheryl
Old 11-22-2015, 04:03 AM   #12
tkowalyk's Avatar
2013 27' FB Classic
North Wales , Pennsylvania
Images: 11
We love the Flamma on our 27 Classic. We use it all of the time (3 seasons now). and have never had any problems. We haul 2 bikes. It is much more convenient than our previous roof mount rack.
Bottom line - no regrets and highly recommended.
Tom & Lori
2013 27 FB Classic Limited
2016 Nissan XD Turbo Diesel
WBCCI 03288 TAC PA-17
tkowalyk is offline   Reply With Quote
Old 11-22-2015, 04:23 AM   #13
ShinyPete
ShinyPete's Avatar
2014 27' Flying Cloud
Bushnell , Florida
Two years with Fiamma rack on our Pete (FC 27fb), with no problems. So much easier than most any bike solution we have ever used on any rig. Tighten three straps per bike and you're gone. Now if I could figure out how to haul grand-kid bikes on it too............
I guess my only regrets are that yes, accessing the bumper storage is tricky when the bikes are on the rack (probably worse with a rear hatch like an rb would have), and it does take away from the aesthetics of the rear of the coach. But it sure is easier to use than so many solutions I've seen struggled with in campgrounds.
ShinyPete is offline   Reply With Quote
Old 11-30-2015, 09:07 AM   #14
kirkwood , Missouri
These pics aren't great but I'm having trouble loading from my phone.
ID:	253123   Click image for larger version
Old 11-30-2015, 01:51 PM   #15
Flht2k's Avatar
That's exactly what I want. Thanks
Old 11-30-2015, 02:45 PM   #16
2011 23' Flying Cloud
Durango , Colorado
Very nice piece of work. Just what I would like. Your father-in-law doesn't happen to live near Durango, CO does he?
Safe Travels,
JamuJoe
Safe Travels,
Joe & Joan Donnaway
Durango, CO
JamuJoe is offline   Reply With Quote
Bike Friday / Swift Folder / Airnimal folding bike? 85MH325 Off Topic Forum 47 09-26-2008 06:21 AM
Bike rack on a Suburbban Les Gilliam Our Community 2 04-06-2003 07:25 PM
bike rack mount on rear of AS trailer rmmm68 Repairing/Replacing Floor &/or Frame 7 11-26-2002 10:55 AM
Bike Rack ALANSD Our Community 3 03-19-2002 10:57 AM
