Old 06-08-2013, 03:40 PM   #15
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
I'd agree that this is likely a brake problem - but regardless - it might be helpful to also get an opinion from Hensley by giving them a call - I'm sure they will ask you a couple of specifics about your setup - which should lead you to being able to eliminate the hitch as a possible source of the issue.
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
Old 06-08-2013, 05:32 PM   #16
1988 32' Excella
Robbinsville , New Jersey
Could be air or water in the break lines.
When was the last time the break fluid was replaced?
Old 06-09-2013, 03:57 PM   #17
2006 30' Classic
Milton , Florida
Current Status
Jay
I believe that I will call Hensley tomorrow.
We went about 140 miles today, with some grades as steep as 8%, with no problem. The only change that I made was to increase the trailer brake controller gain setting from 7.5 to 8.0.
At this point, I am unsure of the cause of the problem. We will continue on and monitor the situation.
Many thanks for all of the suggestions from everyone.
F. A. Meloy
2006 30' Classic
Dexter hydraulic disc brake system
Centramatics wheel balancing & Dill TPMS
Hensley hitch & Maxim skylights
Voyager Camera System WVOS713
2010 FORD F-250, ITBC, 6.8 liter V-10 gas, with VIAIR on-board air system
nickmeloy is offline   Reply With Quote
Old 06-09-2013, 05:02 PM   #18
1981 31' Excella II
New Market , Alabama
It could be as simple as one or more rotors got wet and caused uneven breaking. I used to have an old motorcycle with a front disk brake and it would stop working in the rain. I slid through a stop light on it when the front brake stopped working from the rotor being wet.
Perry
Old 06-09-2013, 05:20 PM   #19
Eric H's Avatar
1974 23' Safari
1947 25' Spartan , Manor
If your trailer starts to fishtail you should apply the breaks to the trailer manually and actually accelerate the TV gas if possible to straighten out the rig, just a nonintuitive action that makes sense when you think about it:-)
Eric H is offline   Reply With Quote
DirecLink Brake controller... Mexray Brakes & Brake Controllers 123 01-03-2016 08:58 AM
Wheels for 1958 Traveler cuyeda 1958 Traveler 9 04-25-2013 07:36 AM
Do I need brakes? Modern South Brakes & Brake Controllers 84 04-04-2013 07:25 PM
Road side help when breaking down la nomade Classic Motorhomes 19 06-26-2012 04:37 PM
Guide to Better Trailer Braking... Mexray Brakes & Brake Controllers 12 01-23-2012 11:33 PM
