Old 10-17-2010, 07:31 PM   #43
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Originally Posted by Airstreamer67 View Post
Any trailer that has a "sway" under normal conditions is a sick puppy. It needs fixing before any superhitch is employed.
After all, aren't these the best towing trailers on the planet?
Incidently, I've been using the classic brainless friction anti-sway bars for decades from coast-to-coast with no sway problems whatsoever. This includes using them not only on the best towing trailer on the planet, but on the underlings as well.
Would be easy enough to show with a camera. Just because you don't feel it (or see it in the mirrors) doesn't mean the trailer isn't always looking to get around the TV. It's there . . however minor the side-to-side movement TT and TV do not follow the same line except in general. There are a few brands of hitch that will eliminate this. I point out this motion to passengers all the time. Once one knows what to look for it's obvious.
Old 10-17-2010, 11:58 PM   #44
Maniacal Engineer
barts's Avatar
Menlo Park , California
No, actually, it's just the physics of the situation. There will be small oscillations as the trailer reacts to road bumps, etc. This is perfectly normal and not dangerous; trailer dynamics are typically underdamped, so that a step disturbance causes several dying oscillations - like a pendulum... the trailer is really not plotting your demise
At the risk of sounding like a broken record: if your trailer starts swaying back and forth w/o driver input while towing on flat ground, get it checked out right away. Do NOT apply any patent nostrums in the way of sway damping hitches - something is Out of Spec, and should be corrected first.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 10-18-2010, 09:05 AM   #45
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Originally Posted by barts View Post
I may not have been clear: if you have a trailer that sways back and forth noticeably (from the tow vehicle, not the trailer's rear bumper) under normal towing conditions w/o a sway reducing hitch - something is wrong, and you should address the cause of the problem rather than slapping damping (friction) on it and hoping it goes away under all conditions.
-= Bart
Yes,
You are 100% correct:
Something is wrong. Maybe the wind is blowing, the road surface is uneven, you just applied the brakes, a large vehicle just passed, the road is slick, someone just cut you off, an animal ran across the road in front of you, etc, etc..... These type of wrong things happen all the time when drivng.
I am impressed by your driving and towing skills. I have read many of your posts on these forums where you tell of your experiences towing large trailers with simply a hitch and ball.
Maybe the problem is that the rest of us mortals do not posess your skills.
What I don't inderstand is why it is seems so important to you that the rest of us drive lightly rigged as you do. I am glad that it works for you, but it is not going to work for everyone.
Ken
Old 10-18-2010, 09:50 AM   #46
Sky
Classic 30
Sky's Avatar
Sum Wear , Ohio
Originally Posted by finalcutjoe View Post
blah blah blah
.... where you’ll stay while he, at his leisure, feasts on your bloated corpse…
blah blah blah
Tell us another story uncle Joe, please please please
"Only dull people are brilliant at breakfast" - Oscar Wilde
2500HD DMax............30' Classic
Sky is offline   Reply With Quote
Old 10-18-2010, 10:03 AM   #47
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
Nighty-nite, Sky.
Bedtime for you, while you let the grown-ups talk
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Old 10-18-2010, 01:43 PM   #48
VIKING's Avatar
Boulder Creek , California
Originally Posted by w7ts View Post
Yes,
Ken
I don't get the impression that Barts is trying to talk anyone into doing anything dangerous. Rather, it seems that he is relating something he experienced while towing a rig without anti-sway.
This is so common with boat haulers that they would probably think you are a little off if you suggest anti-sway, or wd is necessary.
It seems to me that there is a issue with a trailer that sways without any input at highway speeds. If your axles are out of alignment or your tires are screwed up, or you are loaded incorrectly, and you use a super-hitch to keep it in-line, what are you putting unnecessary wear on? Probably all of your running-gear and your hitch.
I wouldn't advocate hauling your Airstream without a-s and w-d, but I understand the analogy is just an analogy, not a recommendation..
Rich the Viking
VIKING is offline   Reply With Quote
Old 10-18-2010, 02:15 PM   #49
_
the boat issue is tossed out regularly, it's a non starter.
different center of mass/gravity, different axle placement, different tongue load, different mass in the wind...
and so on.
and a lot of toad'boats DO end up in a ditch or off the road.
__________
bart might be suggesting proper setup helps and it does.
the problem is what part is or is NOT properly set up, there are dozens of issues 2 dial in properly.
there is often the undertone (perhaps not in this thread) that "more experienced drivers"...
simply don't need sway control OR sway elimination gadgets.
because their driving skill and experience supersedes advanced equipment (like abs or shoulder harnesses)..
this topic has been beaten well in older threads and the info is still relevant.
the op basically writes "got the wiggles, what should i do?"
which has morphed into the broader "how to address sway or dynamics of towing" theme.
many of the issues worth considering are in this one post...
http://www.airforums.com/forums/f238...tml#post467652
and reading these threads may help some.
http://www.airforums.com/forums/f238...res-37009.html
http://www.airforums.com/forums/f464...rol-37238.html
http://www.airforums.com/forums/f463...low-58771.html
http://www.airforums.com/forums/f438...sway-4636.html
ken's point is that EVEN once everything is dialed in properly the 4 bar/pivot point projecting hitches...
simply provide a smoother, more relaxed and controlled towing experience.
and there is NO reason to discourage folks from using these gadgets,
it's NOT about masking faulty setups, it is about improving the towing experience.
i've read 100s of posts from guys doubting this and claiming 'proper setup' = perfect towing.
the simple fact is that whenever those guys finally try towing a rig with the fancy hitches...
they very quickly realize that EVEN with a good setup there is a difference in the driving experience.
________
there are very few details provided by the op and no pics of the rig...
so providing useful/specific/relevant guidance is umpossible.
cheers
2air'
Old 10-25-2010, 11:33 AM   #50
Rodeo Clown
BillyJoe's Avatar
Sealy , Texas
I never pull nothing faster than 60 mph.. Slow Down...
BillyJoe is offline   Reply With Quote
Old 10-25-2010, 12:44 PM   #51
mhilley's Avatar
2000 23' Safari
Vero Beach , Florida
I am with BillyJoe! Slow down!
mhilley is offline   Reply With Quote
Old 10-25-2010, 12:50 PM   #52
dznf0g's Avatar
Oswego , Illinois
I tow at 63MPH. Safety first reason. Also, that's the road speed where my TV torque curve just peaks in direct drive (4 speed Overdrive tranny). That's the most economical speed for my setup.
Old 10-25-2010, 12:53 PM   #53
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
First, visit ODM for assistance
Secondly, tow at slower speeds.
55-60 mph..
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 10-29-2010, 05:59 PM   #54
Dearborn , Michigan
Images: 21
Here's what a 31' A/S and Dodge 2500 using a REESE WD with friction bar looks like.
At 65 mph, on a slight uphill. The sway was instantaneously uncontrollable. I felt a slight tug to one side, then I turned my head out my driver side window and was seeing the tail of my 'stream next to me.
There was no time to react.
We rolled 5-6 times. Hitch stayed connected. Everyone walked away from this gator attack. These are the pix from the junk yard in WV, where I went to salvage some of our stuff afterward.
Old 10-29-2010, 06:29 PM   #55
r carl's Avatar
Lin , Ne
OMG, so what was the cause of the sway?
Old 10-29-2010, 06:54 PM   #56
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Obviously, not a big enough tow vehicle . . nor enough driver skill or presence of mind or other irrational "reason" some like to come up with when it comes to narrowing risk against the day it happens to any of us.
Really doesn't matter, now, does it? The cause.
Same thing happened to my folks with theirs.
Do the homework, don't settle for half measures, use true numbers to set hitch rigging. And spring the wallet for the best hitch & brakes.
Be meticulous with the details on an ongoing, disciplined basis . . and have a pile of scale tickets to CYA.
fishtailing
Trailer Sway or Fishtailing 68 Overlander Hitches, Couplers & Balls 9 12-13-2007 06:43 PM
