Old 04-17-2015, 08:47 AM   #1
1975 25' Tradewind
Navarre , Florida
First Tow - Have an issue
Towed my AS yesterday for it first significant trip, Pensacola - Lafayette, LA, and discovered an issue but not sure where it's originating from. When towing, my vehicle has a significant pull to the left side of the road. Previously, I thought my axles may have been slightly out of alignment, but 5 days ago I had the original axles replaced with new ones along with new tires and the problem still exists. 2 weeks ago I had 4 new tires put on my TV along with an alignment correction and everything functions as normal when I'm not towing anything.
The trailer isn't loaded with anything really significant, and all my tanks are empty. Its hard to imagine that it is loaded improperly but It appears when looking in the rear view mirror that the curbside of the AS rides slightly lower than the street side. Since the problem existed before I had new axles put on I dont think it's a result of improper install by the shop that did the work.
Rsmied is offline   Reply With Quote
Old 04-17-2015, 09:27 AM   #2
SteveH's Avatar
Common Sense , Texas
What type of hitch do you have, and are you sure it's setup correctly?
Have you checked to prove you don't have dragging brakes?
Regards,
Steve
Old 04-17-2015, 09:39 AM   #3
1994 34' Excella
Warren , Manitoba
Park the trailer on level parking lot and measure the height on both sides, front and back, and between the wheels. They should be the same. Also check the A frame for signs of damage or twisting. Have someome follow you when pulling and confirm that the trailer is tracking straight. If this problem started on the original axles, and was the same when new axles were installed, I am suspecting a bent or twisted frame. Good luck, and keep us informed of the progress. Chris
WBCCI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 04-17-2015, 10:46 AM   #4
AldeanFan's Avatar
1977 23' Safari
Niagara on the Lake , Ontario
agree on the checking for a stuck brake
more information on your vehicle and hitch would help.
one way of checking for alignment problems on the trailer is to drive on a straight dirt road and look at your tire tracks, if the alignment is right on the tire tracks should look like the tire tread, if the tracks are scuffed and show no tread indentation you probably have a problem. if you don't have a dirt road available a bag of play sand and an empty parking lot will work too. not scientific by any means but a cheap way to identify the source of the problem.
1977 Safari Land Yacht
2005 Toyota Tundra SR5
2010 Ford Flex Ecoboost
AldeanFan is offline   Reply With Quote
Old 04-17-2015, 12:24 PM   #5
SteveH's Avatar
A maladjusted Reese Dual Cam, ProPride or Hensley hitches could cause this problem.
Regards,
Steve
Old 04-17-2015, 02:17 PM   #6
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
Do you have a friction type anti sway bar ? If its adjusted too tight it could cause this.
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 04-17-2015, 02:49 PM   #7
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
Dragging brake?
Old 04-18-2015, 07:23 PM   #8
Sodbust's Avatar
1972 27' Overlander
Penokee , Kansas
Most roads and hi-ways have a crown or taper to each side to allow water to drain off into the ditches.. Some are 1 degree while others can be as much a 4 degrees.. This will tend to tilt or lean the trailer more than the TV,, then transfer this off center line draw bar pull to make the TV pull a little to the left.. ( American right hand lanes).. I have found if I feel a pull as long as traffic allows I drive dead center down the center divider line and if the problem goes away I feel safe to go onward till the next spokey issue faces me.
Sodbust
2012 Ram 1500 Tradesman Hemi, 4x4, 6 speed
20mpg empty, 14 mpg with 27' Overlander.
Today is the first day of the rest of your life!
Sodbust is offline   Reply With Quote
Old 04-18-2015, 07:47 PM   #9
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
It almost has to be the hitch setup.
I doubt a twisted frame would cause a pull, and being loaded heavy to one side pretty much wont make a difference. (Wouldn't a twisted frame make for a wrinkly trailer?)
Road crown should move you slightly to the right in the right lane of an interstate and slightly to the left in the left lane.
I have pulled trailers that dogleg pretty bad, but I have never felt a dog leg trailer mess with my steering.
I say look at your WD/anti-sway setup first. If that isn't it then we have a real mystery to solve.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 04-18-2015, 07:54 PM   #10
lahrfarm's Avatar
1969 29' Ambassador
1985 31' Excella
1969 29' Ambassador
Crescent , Oklahoma
I would look at WD hitch, possibly not set tight enough, causing light steering
Have a blessed day !
TAC OK-5
lahrfarm is offline   Reply With Quote
Old 04-18-2015, 08:21 PM   #11
SteveH's Avatar
Interesting the original poster has not been back on this thread with more info or questions.
Regards,
Steve
Old 04-18-2015, 08:23 PM   #12
r carl's Avatar
Lin , Ne
Start a process of elimination by towing your AS with a different TV.
Old 04-18-2015, 10:33 PM   #13
J. Morgan's Avatar
1972 31' Sovereign
Benton , Arkansas
Images: 11
Very good advise!
Old 04-19-2015, 06:32 AM   #14
z , North Carolina
Yeah I was hoping to read some feedback from the OP too. Some excellent suggestions & areas to inspect given by all posters to the thread. I have (fortunately) only run into a bent frame issue once. And the first indication was the "cupping" of the tires. That can be an arduous & expensive task to narrow the problem down to the frame itself.
I wish the OP all the luck I can, that it's NOT his frame, but as you guys said. "Check the hitch."
FishinHatteras is offline   Reply With Quote
Furnace issue turns out to be AS issue 92landyacht Land Yacht/Legacy Motorhomes 16 01-20-2016 10:19 PM
Do I have an axle issue?? Wheel issues when reversing trailer on slant idaramin Axles 7 03-19-2012 03:53 PM
Do I have a brake issue? lbrownah Brakes & Brake Controllers 13 08-21-2010 12:08 PM
Tow, tow tow your Airstream Hhthorny Towing, Tow Vehicles & Hitches 11 04-12-2008 12:06 AM
Airstream Life Winter 2005 issue. Have you seen it? ALANSD Commercial Listings 49 02-09-2005 11:00 AM
