Old 04-19-2015, 02:28 PM   #15
2000 30' Excella
2014 30' Classic
Princeton , Iowa
This is simplistic, but you said only one tow. What was the wind doing.
larryglarson is offline   Reply With Quote
Old 04-19-2015, 02:42 PM   #16
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Very good point also.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 04-19-2015, 02:43 PM   #17
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Always interesting when the OP does not give feedback, but maybe some folks are not as obsessive about the forums as I am....
My guess, totally a guess is that somehow the hitch is not set up properly, one side of the weight distribution/sway control arms being adjusted to a different length than the other.
The way I have found to check this is to drive the TV and AS to a large level parking lot, straight forward, and then adjust the bars precisely.
Another issue could be tire pressures, and if one wants to compensate for road crown, there are some ways to do this with right left variations on the TV. My moho had about 3 lbs. different R to L, i.e., 110 on road side, 113 curb side....Steer axle, 100, 102 in rear, duals and TAG.
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 04-19-2015, 03:29 PM   #18
1994 34' Excella
Warren , Manitoba
Reading the original post, the problem was present with the oiginal axles, and after the new axles were installed, the problem was still there. This indicates problem with 1. Hitch, 2. Tow vehicle, 3. Frame or A frame on trailer, 4. Miss alignment of axles from original. OP has not returned to comment or indicate that he has tried suggestions given, so I ASSUME problem has been solved. Hopefully OP will return and give us an update!!
WBCCI #7394
2002 Chev 2500 HD Duramax
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 04-24-2015, 09:01 AM   #19
1975 25' Tradewind
Navarre , Florida
Thanks for all the feedback. Sorry I wasn't able to get back and respond to comment sooner. The hitch I've got is a Reese 49586 Pro Series WD hitch. The hitch itself is pretty much brand new but I bought it from local guy who had used it a few times before selling his trailer. After making my original post, I dug up the installation directions for the hitch and went to see if I could find anything wrong. In the past I had made several slight adjustments but it was just to the height and angle of the ball to achieve an level ride.
While comparing my hitch to the installation directions and a few YouTube videos I realized that the WD arms were installed upside down by the previous owner! The u-bolt connecting the chain too the arm had been assembled upside down so I took it apart, flipped it around and now the arms are correctly installed and everything is perfect...i solved the issue...or so I thought. The same issue is still hanging around.
The road and the wind definitely aren't the issue. I've pulled it all the way across I-10 through texas into arizona. The trailer doesn't pull dog leg, I had two separate people follow behind me to watch and everything checks out. My TV, when unhooked drives straight as an arrow and right now I dont have anyone with a different TV to test it out. I'm gonna continue to make adjustments to the hitch and hope that solves the problem. I'll be sure to update along the way. Thanks for the help!
Rsmied is offline   Reply With Quote
Old 04-24-2015, 09:13 AM   #20
SteveH's Avatar
Common Sense , Texas
The only thing I would caution you on with that hitch reference the problem you are having is to make sure the snap-ups are located such that the chains on both sides are straight up and down when the truck and trailer are in a straight line. If the chains are slanted, it could cause the problem you are having.
Regards,
Steve
Furnace issue turns out to be AS issue 92landyacht Land Yacht/Legacy Motorhomes 16 01-20-2016 10:19 PM
Do I have an axle issue?? Wheel issues when reversing trailer on slant idaramin Axles 7 03-19-2012 03:53 PM
Do I have a brake issue? lbrownah Brakes & Brake Controllers 13 08-21-2010 12:08 PM
Tow, tow tow your Airstream Hhthorny Towing, Tow Vehicles & Hitches 11 04-12-2008 12:06 AM
Airstream Life Winter 2005 issue. Have you seen it? ALANSD Commercial Listings 49 02-09-2005 11:00 AM
