Old 11-16-2009, 04:37 PM   #1
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
First Recovery: What do I Need?
Well it looks like we'll be bringing home our first "stray". 20' Argosy...don't know the year yet (neither does owner). I have been towing trailers for many years; but never a recovered trailer. What items should I have available? Temporary rear brake lights? Wheel bearings? Spare tire? What experiences have others had in their recoveries? Thanks!
Roadrunner is offline   Reply With Quote
Old 11-16-2009, 05:08 PM   #2
_
hi bob
congrats.
common issue and series of questions.
seems there is a 'sticky' some where entitled...
"how do i tow or haul home a really old trailer i just purchased, and haven't inspected yet?"
or there SHOULD be one...
here's a couple of threads on this topic, but there are 100s.
http://www.airforums.com/forums/f368...ome-26080.html
http://www.airforums.com/forums/f238...ome-33441.html
http://www.airforums.com/forums/f42/...home-2435.html
http://www.airforums.com/forums/f48/...ome-14489.html
i'm sure some1 will come along with THE definitive thread on this, but those above help.
some folks USE their trailers on the first trip home.
and the list of things for a maiden travel/camping voyage are in another string of threads...
then there are the...
-"find a transport company" theme threads and
-"flat bedding it home" theme and
-"i only need to haul it 100 miles home, so can i do it without brakes, tires or lights?"
well you get the point.
safe travels by what ever route U take.
cheers
2air'
Old 11-16-2009, 06:00 PM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
How far do you need to haul it, Roadrunner? How long has it been since it was towed? What condition are the tires in? Any idea when the wheel bearings were last packed?
We towed our 1972 Sovereign home from Mobile, AL, this spring. She had not been towed in many years. There were car tires on her (very OLD car tires), and the exterior lights did not work, or were broken out. We took 2 rims and tires down with us (should have taken 4), since we were told 2 of the tires were marginal. Turns out they were ALL marginal, but we made it home without blowing any tires, by putting the new ones on the back, and the best 2 of the others on the front. We took lots of wire and temporary running lights down with us and rigged them along the side and rear of the trailer using gorilla tape to hold them on. Chris also rigged the brakes with new wire. We had a little brake power for the trip. Fortunately our Excursion had the rest of the braking power we needed for the trip. The PO had a mechanic friend help her repack the wheel bearings before we went down. All in all, it worked out very well for us, and we had a fairly uneventful trip back to MN. Take extra tools with you, and a few prayers!
Kay
Old 11-16-2009, 09:52 PM   #4
Alwhisman's Avatar
1978 Argosy Minuet 7.3 Metre
Dayton , Texas
Images: 94
Send a message via Yahoo to Alwhisman
I would take two wheels/tires, temp lights, and tools and material to check and pack the bearings before I left............tools and tools....and the universal repair tool-Duct Tape!
Congrats! How far do ya have to tow her back?
Al
Alwhisman is offline   Reply With Quote
Old 11-16-2009, 10:01 PM   #5
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Bob,
Check out past podcasts of TheVap.com Rob Baker had made several rescue trips, every one an adventure.
Bill
Just my personal opinion
Old 11-17-2009, 04:59 AM   #6
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Thanks for all the advice. We have about 90 miles of mostly back roads to tow. The Argosy was last towed 2 years ago. Tires still appear to be holding air. Great reminder of the duct tape - the "universal tool". PO lost the keys so there is no way to lock the door. I don't want it swinging open during the haul so looks like duct tape is the answer there. Will keep you posted. Again, thanks!
Old 11-17-2009, 07:47 AM   #7
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Bungee cords, bailing wire, flashlight, hitch grease, hitch chains and basic toolbox.
Congrats on your new-to-you Argosy. I recommend you take twice as many pictures of her in as found condition as you'll think you'll want and of every nook and cranny. Post a few here so we can all marvel in her beauty.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 11-17-2009, 01:00 PM   #8
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
Bob, for an emergency more secure than duct tape door fastener. You can take a rubber door stop and jam in behind the door grab bar on the outside. There are several designs for wooden safety locks in these threads.
We did the rubber door stop...it takes a long one. Larry drilled a hole on the fat end for a loop of rope to go thru. Make a loop around the grab bar and jam the door stopper in between so it comes over the edge of the door. I know there are pictures of that somewhere on the threads. Here is one such thread that talks about the rubber door stop and has a photo of the wooden one:http://www.airforums.com/forums/f161...tml#post761289
Lou and Larry
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 11-17-2009, 03:05 PM   #9
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
After three bad recoveries, I now put the trailer on a flatbed trailer without the wheels and call it a day! The only safe "legal" (for Rob Backer) way to bring a trailer home!
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Canada - California - Colorado recovery mission truckasaurus On The Road... 4 04-07-2008 12:23 AM
Amazing video of violent trailer sway and recovery! SilvrSausage On The Road... 6 03-07-2008 11:34 AM
'61 Ambassador recovery - need some specs RoverOwner 1959 - 1965 Ambassador 36 01-26-2008 07:48 AM
A Special Speedy Recovery Wish for Chaplain Kent codybear Off Topic Forum 49 09-19-2006 08:33 AM
