Old 01-12-2016, 09:50 AM   #1
RFP
RFP's Avatar
2014 23' International
Hurst , Texas
First Airstream and I don't want a truck (!)
Linda and I are so excited that we will be picking up our new-to-us 2014 23D International Serenity later this week. We are 99.99% sure that our trusty '96 Land Cruiser won't be satisfactory for the weight... sometimes it seemed to struggle a bit when pulling our Casita (~ 3,100 pounds on the road). The truth is that we don't want a truck, preferring a SUV. Right now, I'm thinking 2008~2012 Toyota Sequoia with the 5-point-something V8, six speed transmission and all the towing stuff. I've read a number of threads about this vehicle and all seemed pretty positive, but all I found were 'kinda old."
So, I thought that I'd post this question as to the suitability of the Sequoia with the 23D for current thought. We do like to travel frequently to the Rockies, if that matters, and it probably does.
Thanks so much,
Rob
RFP is offline   Reply With Quote
Old 01-12-2016, 10:08 AM   #2
2016 25' Flying Cloud
Holly Springs , Mississippi
I'd for sure call Andy T. at CanAm and discuss your circumstance with him. He can give you some really good guidance as to what TV can be made to work quite well.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is online now   Reply With Quote
Old 01-12-2016, 10:42 AM   #3
cameront120's Avatar
1972 25' Tradewind
Yes, give Andy a call. He can speak to your specific vehicle choice as well as recommend other options that would work for your trailer.
North Vancouver, BC
Old 01-12-2016, 10:49 AM   #4
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Top here on AIRForums uses a Sequoia as one of the tow vehicles. It's not a fuel-economy champ but for a 23' trailer should do fine if properly equipped and set up. If memory serves he's had minor annoyances with the brakes, starting before he ever towed with it. Big heavy SUV that likes to warp the stock rotors, I think.
David
Old 01-12-2016, 10:51 AM   #5
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Sequoia is pretty close to Tundra in size, shorter wheelbase and independent suspension which are very good for getting around and stability.
A little smaller SUV with a 5.7 engine (plenty) and 8-speed transmission that is less expensive and not as thirsty on fuel is a late model Dodge Durango, also independent suspension and rated to tow any mid-size Airstream.
There are three equally important elements in a great towing combination. Tow vehicle, trailer, and hitch, if any one is poor, the combination will be poor. Spend at least as much time researching the hitches as you do the other two elements, and get it set up by someone who knows what they are doing. Many dealers and customers treat the hitch as an afterthought, a make-do item.
Doug and Cheryl
Old 01-12-2016, 10:57 AM   #6
1974 Argosy 20
Kooskia , Idaho
Also consider a Jeep Grand Cherokee, with the V8 or diesel.
Old 01-12-2016, 11:23 AM   #7
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
Another choice: Nissan Armada or Infiniti QX56
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 01-12-2016, 11:34 AM   #8
N/A , N/A
Why not another Land Cruiser? It will last you another 20-25 years.
rostam is offline   Reply With Quote
Old 01-12-2016, 12:07 PM   #9
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Believe there is another thread with a similar question. The Toyota reliability reputation drives loyalty. However, there is a lot going for new, in place of older used. Travel breakdowns are a real distraction at a time that you need/want to enjoy the experience.
Towing is a unique type of driving. A tow vehicle performs better and is safer if it has a low center of gravity, long wheel base, short rear overhang, wide track, large tire contact patch, big disk brakes, similar mass to the trailer, reasonable torque, stiff chassis, and a payload that matches load and tongue weight conditions. The reduced oxygen at higher elevation gives an advantage to boosted induction engines.
The 23 matches well with a number of SUVs. However, it also matches up with minivans and cars, which can be less expensive and provide as much and often more economy and utility. They are worth your consideration.
Good Luck, Pat
Old 01-12-2016, 12:59 PM   #10
TheCabin's Avatar
2013 25' FB International
Liberty Corner , New Jersey
We ended up with a QX and really like the comfort and power. If you get a 56 make sure it is at least a 2011. Big change for better that year.
TheCabin is offline   Reply With Quote
Old 01-12-2016, 01:07 PM   #11
2015 28' International
Ofallon , Missouri
I have a 2013 Armada 4WD with tow package, which has a tow rating of 9,000 lbs. I have towed a 25' and now a 28'. We love it.
mpsgolf is offline   Reply With Quote
Old 01-12-2016, 01:13 PM   #12
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Another vote for a 2011 or later Durango or Cherokee.
2012 Dodge Durango Hemi/AWD
Wayne&Sam is online now   Reply With Quote
Old 01-12-2016, 01:38 PM   #13
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Get a newish Sequoia. You'll be happy. They make great tow vehicles. It would only be better if they offered it with the twin turbo diesel from the Land Cruiser.
Lance
Top is offline   Reply With Quote
Old 01-12-2016, 03:03 PM   #14
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
I guess I should add the twin turbo diesel is from the LC that is available worldwide minus North America.
Lance
Someone please talk me down-- i don't want an SOB! bakerliz Off Topic Forum 19 04-01-2008 07:06 PM
What if you don't want a mirror finish? retrocats Cleaning, Stripping & Polishing 7 04-22-2007 11:38 PM
Don't want to "Beat a Dead Horse" but...? Baby Whoopie Electrical - Systems, Generators, Batteries & Solar 1 09-27-2006 03:57 PM
