Old 01-14-2016, 04:56 AM   #43
RFP
RFP's Avatar
2014 23' International
Hurst , Texas
Originally Posted by Top View Post
Well, maybe or maybe not. This agonizing over a tow vehicle is driving us nuts! Wanting to stay in the range of $30 or under does put limits on the search. We looked at, and drove, a 2015 Ford F150 2.7 Eco-Boost yesterday. We really liked it but are concerned about the oomph of the 2.7 in the Rockies. And it's huge! Still liking the Sequoia, though.
Anyway, our new-to-us 2014 23D will be in our driveway today, so that excitement will be about all I can deal with today!
Rob
RFP is offline   Reply With Quote
Old 01-14-2016, 05:54 AM   #44
Buck944's Avatar
1998 25' Safari
Mascouche , Quebec
I pull my 1998 25' safari with a 2015 4wd Sequoia 5.7 L. Trailer is around 5800 lb ready for camping. It pull great, no problem so far.
1998 Safari 25' SS
2015 Toyota Sequoia Limited
Buck944 is offline   Reply With Quote
Old 01-14-2016, 06:03 AM   #45
The Woodlands , Texas
Originally Posted by dkottum View Post
There are three equally important elements in a great towing combination. Tow vehicle, trailer, and hitch, if any one is poor, the combination will be poor. Spend at least as much time researching the hitches as you do the other two elements, and get it set up by someone who knows what they are doing. Many dealers and customers treat the hitch as an afterthought, a make-do item.
How do you find the person who knows what they are doing?
SCTX is offline   Reply With Quote
Old 01-14-2016, 06:10 AM   #46
RFP
RFP's Avatar
Hurst , Texas
Wow, now that's a question I can relate to!
Old 01-14-2016, 06:30 AM   #47
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
That can be a challenge. The best place to learn about towing, hitches, hitch rigging and adjustments is right here. It can be a daunting task to sift through all the differing opinions, but it is worth it. Another option is to attend a WBCCI unit rally, meet people that were once newbies and they will be glad to help.
Places like Hurst and The Woodlands are not far from many, many experienced Airstreamers. You might have a neighbor that is an Airstreamer.
Lance
Top is offline   Reply With Quote
Old 01-14-2016, 07:39 AM   #48
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Just remember the Airstream literature tongue weight is always less than the reality when loaded for camping and the hitch head is attached, which is part of the unsupported tongue weight when not hitched. That is the weight the trailer frame supports.
If the preferred tow vehicle hitch rating is only 720 pounds, give Andy at CanAm in London Ontario a call:
(519) 652-3284 or (866) 226-2678
to discuss if some modifications to the tow vehicle of your preference can have the receiver reinforced to handle the tongue weight along with the rotational forces applied to it by any weight distribution hitch system.
I took my 2007 Mercedes there in October 2012 to have the factory receiver reinforced and the Hensley stinger shortened and slightly bent. Click on "Images" below my avatar to the left and there is a photo of the underside of the Mercedes with a new 2"x2" bar going forward to reinforce the recall repaired factory installed receiver.
I was able to tow a new empty (only full fresh water and propane tanks) 2013 25FB International Serenity from Los Angles dealer to Phoenix through the mountains on I-10 and especially the climb east bound out of Palm Springs. There were no issues until we loaded the trailer for camping and had the wife in the car to cross the scales. The car axle limits were then exceeded and thus we acquired a Dodge 2500HD Cummins tow vehicle.
So take a "test" drive in the proposed tow vehicle and cross the scales with the two people and some of the gear you would plan to take with you in the car. You will see the actual axle weights on the print out. Compare those to the axle rating on the door post. One would hope there is at least a 1,000 pounds of payload left on the rear axle....
Since we tow the 23D with the Mercedes, I did not want gasoline fumes from a generator or gasoline cans in the car. I have converted the existing pair of Honda EU2000 generators to propane.
Propane Kits for Honda Inverter Generators by GenConneX
I could carry a spare 30 pound propane tank if necessary inside the car or secured in the shower of the trailer.
Old 01-14-2016, 01:40 PM   #49
Tom T
Tom_T's Avatar
Orange , California
Originally Posted by johncook
It always comes down to do you want the Airstream or the Tow vehicle to be the boss
The answer is, get it hitched right and the Airstream will follow.
doug
Agreed!
And the "smaller than a big-a$$ed-truck" TVs in fact won't be "bossed" by the AS - esp. the shorter ones specifically designed for smaller TVs! It's just BS scare tactics IMHO!
Certainly our Avion T20 didn't "boss" the Nissan Pathfinders with our WD/AS hitch & properly set-up!
Geesh, I just hate these cryptic non-factual & non-contributive "big TV/truck types' " quasi-input.
Tom
Tom T (janabanana48's other half )
Orange CA
1960 Avion T20, #2 made, Hensley Cub, TV tbd- looking for 08-14 Cayenne S
1988 VW Vanagon Westfalia CamperGL (Orig Owner)
Tom_T is offline   Reply With Quote
Old 01-14-2016, 01:45 PM   #50
Tom T
Tom_T's Avatar
Orange , California
It always makes me shake my head when the OP asks one simple question and it always veers off course into the same old tow vehicle debate.
Just as a refresher, here is the question the OP asked-
So, I thought that I'd post this question as to the suitability of the Sequoia with the 23D for current thought. We do like to travel frequently to the Rockies, if that matters, and it probably does.
Lance
Lance, it never hurts to answer the OP's question, plus offer relevant options based on his prior vehicle, trailer size/wt., etc.
And as it turns out, the OP has gone off topic on his own, by now veering towards what he initially said he doesn't want ... a truck, by now focusing on some deals he can get on new 2015 Ford F150s!
So you just never know when additional info will be useful - he may also have instead decided to go with a smaller V8 Land Cruiser or 4Runner over the Sequoyah, or onto any other full or mid-sized TV of another make.
Tom
Orange CA
Old 01-14-2016, 02:01 PM   #51
Tom T
Tom_T's Avatar
Orange , California
There is some good info in a booklet done by the Sherline hitch weight scale people, that I think is a good self-reading starting point, as well as Lance's suggestions above. I think it's online as a pdf Adobe Reader file, but I don't have their website bookmarked.
You'll want their or another way to weigh your trailer's hitch wt. in the real world as wet & loaded for a trip, as well as getting the whole trailer on truck scales or similar to get the actual wet/loaded trailer wts. overall & per axle & per wheel/side.
I agree that Andy Thompson at CanAm is also a good resource to call or email on these types of questions, plus read up on his "Hitch Hints' articles linked from his CanAm website to the Canadian RV Lifestyles magazine website who prints them; as well as those WBCCI folks have literature online & at their events or to call/email them.
So I guess we're on to RFP's new TV search topic now....
http://www.airforums.com/forums/f238...ml#post1736312
Happy Trails!
Tom
Orange CA
Old 01-14-2016, 06:24 PM   #52
2007 25' International CCD FB
Somewhere in , Texas
I have towing my 2007 25FB International with my 2012 VW Touareg TDI for over 3000 miles since October. I absolutely love it and get 18mpg while towing. Would love to paste a picture, but was not able to.
Mymosaicmess is offline   Reply With Quote
Old 01-14-2016, 07:42 PM   #53
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The nearest one is at your house, and should be. Read, learn, experiment with your setup.
Your hitch owners manual is a great place to start. Andrew Thomson at Can-Am Airstream in Ontario is considered a great resource, he has written extensively on the subject in many magazines. Google his Hitch Hints and you will know more about hitching Airstreams than most dealerships. There are many discussions about hitches in this forum, some good information but tend to drift into arguments about brands or truck size.
Get a high quality hitch and learn how each part and adjustment contributes to weight distribution and sway control or sway elimination.
Your towing experience will be much safer and more comfortable.
Doug and Cheryl
Old 01-14-2016, 08:11 PM   #54
mhilley's Avatar
2000 23' Safari
Vero Beach , Florida
Tow my 23 with a sequoia. 130 k miles on it. Have towed over the Rockies many times.
mhilley is offline   Reply With Quote
Old 01-31-2016, 09:16 AM   #55
GuitarmanFL's Avatar
1972 27' Overlander
Orlando , Florida
Originally Posted by richw46 View Post
We tow ours with a 2004 4Runner. It has a smaller 4.7L V8 but it has a 7,000 lb. towing capacity. The early Sequoias also had the 4.7L. If you can get the 5.7 you can upsize the trailer later on with the bigger engine but the 4.7 does nicely with the 23' size. I think Toyota kept the 4.7L in the 4runners through about 2007 but the '04 models have the larger fuel tank.
Just a thought.
Hey RichW46-
I too have a 4Runner, albeit the V-6.
I have the 72 27'. What size AS do u have and how well / comfy do you feel with it as a TV.
I love my 4R, and don't want another truck. So I'd consider the v8 4R or possibly a used Sequoia, but i'd prefer the 4R - due to it's killer off roading - which I don't do with my AS!
Thx
Brek
GuitarmanFL is offline   Reply With Quote
Old 01-31-2016, 09:59 AM   #56
2015 28' International
Ofallon , Missouri
Nissan Armada with tow package is a great tv with 9000 lbs capacity and 900 lbs hitch limit. Tow package has a diff rear end, trans cooler, trans temp gauge and tow mode. No brake control though you'll have to add it but the connector is pre wired and you just have to buy the controller. We towed a 25' for several years and just upgraded to a 28' GW 7600. It'll tow your 23 with ease.
As a large suv it has cavernous space and both rows of back seats fold flat with no gaps or level changes so it is our packing and dog hangout space.
mpsgolf is offline   Reply With Quote
Someone please talk me down-- i don't want an SOB! bakerliz Off Topic Forum 19 04-01-2008 07:06 PM
What if you don't want a mirror finish? retrocats Cleaning, Stripping & Polishing 7 04-22-2007 11:38 PM
Don't want to "Beat a Dead Horse" but...? Baby Whoopie Electrical - Systems, Generators, Batteries & Solar 1 09-27-2006 03:57 PM
