Old 01-13-2016, 12:07 PM   #29
Tom T
Tom_T's Avatar
Orange , California
Originally Posted by RFP View Post
Linda and I are so excited that we will be picking up our new-to-us 2014 23D International Serenity later this week. We are 99.99% sure that our trusty '96 Land Cruiser won't be satisfactory for the weight... sometimes it seemed to struggle a bit when pulling our Casita (~ 3,100 pounds on the road). The truth is that we don't want a truck, preferring a SUV. Right now, I'm thinking 2008~2012 Toyota Sequoia with the 5-point-something V8, six speed transmission and all the towing stuff. I've read a number of threads about this vehicle and all seemed pretty positive, but all I found were 'kinda old."
So, I thought that I'd post this question as to the suitability of the Sequoia with the 23D for current thought. We do like to travel frequently to the Rockies, if that matters, and it probably does.
Thanks so much,
Rob
Hi Rob,
You don't say what engine or tow rating your 96Gland Bruiser ;-) has, but if it's a V8 it may be okay to pull the 23 AS home at least, if no grades.
As for a used SUV - I'd suggest trying to get one with a factory backed CPO extended warranty, or else Fidelity has been recommended for a 3rd party warranty (they also do the factory CPO for VW, Audi & I think Porsche & maybe others). Others may recco other 3rd party warranty providers for Toyota & other makes.
Whatever the make/model/engine you settle upon, I'd also suggest looking for a 1-2 owner SUV at below 60,000 miles (or less) which has been well cared for - even babied, has all maintenance done on time always by either a dealer or good independent specialist, & has records of all work.
It's also a good idea for both you & your wife to go out & test drive the different ones to see which you actually like, since they've changed a lot since your 96. Any of the 3 Toyota SUVs from that era would be fine TV choises, but you may also want to look at some other options too - as others have said.
Also the smaller mid-size with the same V8 weighs less, ergo you have more power available to tow with the same engine. So that may be a consideration for you guys, if you don't need/want the big SUV.
We looked at the full range of mid-sized SUV options in the `06-12 MYs with a V8, before deciding what was right for us is the 08-12 Porsche Cayenne S, for which we're currently looking. The reason only mid-size is given our narrow driveway & streets - we just can't fit the full size SUV/Pick-up, nor will my wife drive one (unless emergency .... maybe).
One thing I ran up against is that most of the used SUVs on the market tended to be 100-200,000 miles at that 3-10 year age range, whereas it's fairly common to find a sub-60,000 mile Porsche Cayenne S which has been properly maintained & babied by their owners. Ditto with the other luxury brands tending to be better kept & lower miles - like Audi, BMW, Mercedes, Lexus & Infinity.
The Toyotas & their Lexus cousins are great trucks with great reliability, but Sequoyah (correct spelling for the Cherokee man it & the tree/park was named after BTW - but it is just too big for us), & the 4Runner V8 & Land Cruiser V8 would work for you (& size-wise for us). I also looked at the full range of US, Euro & Asian options in mid-size SUVs, & many were dropped due to only offering a V6 (e.g.: Honda, Hyundai/Kia only V6), but most for the miles on them & the issues below.
From that 08-12 era mid-sized SUV with V8s & some with Diesel - there are some reliability & longevity issues which I heard/read about including, some of the Dodge/Ram Durango V8s, Chevy Trailblazer & GMC cousin, Ford Explorer V8 & Lincoln cousin (older body style), BMW V8 & Diesel.
While even a V6 Diesel will have plenty of torque to pull a trailer like yours - more than a V8 in some cases - you should be aware that the regular maintenance will cost more than on the gas vehicles, & you'll have to keep track of the extra emission control fluid, as well as fuel, oil & coolant.
The above is not a deal killer - just a consideration, but the current "VW diesel debacle" has spilled over into their V6 Diesel used in the Porsche Cayenne, VW Touareg & Audi Q7 models. While they have the emissions equipment & fluid that their smaller 4 cyl TDIs lack - & why their "fix" for the smog test cheating program was needed, their software being questioned is apparently related to the cold running mode for the need to maintain temps to induce ignition in diesels. So I'd be cautious if you look at any of those 3 options - but I understand that at least Porsche is giving an extended warranty to 10/100,000 on their 2013-15 diesels (2016 is a different 3.2 or 3.6L Porsche only diesel motor & they only had diesels since `13 MY). There are a few topics on here about those TV options in V*, V6 & diesel flavors - if you're interested.
In the end, you'll have to pick what fits your needs & wants.
PS - FYI our rig is an older restored vintage kin 1960 Avion T20 which is about 3000-3500 lbs wet & loaded, with a Hensley Cub & we've been towing since we got it in July 2012 with various rented Nissan Pathfinder 4.0L V6 (mid-size, but we'd want a V8 version) & full size F150 & F250, Dodge 2500 in both V8 gas & diesel motors (but too big for us & our driveway).
Good Luck!
Tom
Tom T (janabanana48's other half )
Orange CA
1960 Avion T20, #2 made, Hensley Cub, TV tbd- looking for 08-14 Cayenne S
1988 VW Vanagon Westfalia CamperGL (Orig Owner)
Tom_T is offline   Reply With Quote
Old 01-13-2016, 12:21 PM   #30
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
This Toyota
Adventures of Dave and Ann: Re-deciding on a New Tow Vehicle
has seen a few miles towing a 25.
Adventures of Dave and Ann: 2015 Map and Stories
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 01-13-2016, 12:37 PM   #31
2015 23' FB Flying Cloud
Redmond , Washington
Originally Posted by idroba View Post
Also consider a Jeep Grand Cherokee, with the V8 or diesel.
This past spring and summer I towed our 2015 23 FB 13,700 miles with our 2014 Jeep Grand Cherokee Summit Ecodiesel, including round trips across the northern rockies and through New England to St. John's, Newfoundland. (We didn't think it would float too well so we took a ferry from Nova Scotia.). The Jeep Ecodiesel handled fantastically in all kinds of wind, rain, light snow, hail, up, and down steep grades. We got 16.4 mpg overall for the trip. Used an Equalizer hitch.
The tongue weight on the 23 D is higher than the 23 FB and that may limit your options. The Jeep is rated to tow 7,200 lbs. (4x4 version), but tongue weight allowed is 720 lbs.
Happy travels!
D2
"Having differences makes a difference"
WestieHouse is offline   Reply With Quote
Old 01-13-2016, 01:27 PM   #32
2015 23' Flying Cloud
Santa Fe , New Mexico
We have a 2015 FC 23D and a 2014 Sequoia Limited with tow package, which has the 5.7 L engine. We love the Sequoia, which we bought used with 24K miles on it--it's a very comfortable car to drive. Pulling the trailer was great. We have a Equalizer hitch and never had any sway while towing the trailer from Idaho, where we picked it up, back home to Santa Fe. And we could accelerate going up hills. The Sequoia is a gas hog, like every big vehicle, and a pain to park sometimes, but we really like it.
Danielle, Bob and TuTu (a 2015 23' Flying Cloud)
Danielle is offline   Reply With Quote
Old 01-13-2016, 02:09 PM   #33
johncook's Avatar
2007 27' Safari FB SE
Mesa , Arizona
It always comes down to do you want the Airstream or the Tow vehicle to be the boss
Puresilver
johncook is offline   Reply With Quote
Old 01-13-2016, 02:38 PM   #34
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The answer is, get it hitched right and the Airstream will follow.
Doug and Cheryl
Old 01-13-2016, 03:33 PM   #35
2000 30' Excella
2014 30' Classic
Princeton , Iowa
I had a Tundra with the 5.7 engine and pulled a 30' Classic. It did a wonderful job. I think it would have lasted 200,000 miles pulling the trailer.
larryglarson is offline   Reply With Quote
Old 01-13-2016, 03:46 PM   #36
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
It always makes me shake my head when the OP asks one simple question and it always veers off course into the same old tow vehicle debate.
Just as a refresher, here is the question the OP asked-
Lance
Top is offline   Reply With Quote
Old 01-13-2016, 04:32 PM   #37
Major Tom's Avatar
I tow my 22 FB Bambi sport with a new Land Rover LR4. It tows like a dream. However I generally only get about 14 mpg when towing. It is my daily driver as well.
Major Tom is offline   Reply With Quote
Old 01-13-2016, 05:57 PM   #38
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
I didn't want a truck either, so we purchased a 2012 Sequoia Limited to pull our 25' 2013 Flying Cloud. SUV is equipped with 5.7L V8 and full towing package. Selected this over an equivalent Chevy Tahoe. Gas mileage could be better but I prefer driving a vehicle I like over saving a few dollars on gas with a less enjoyable ride.
Big test last fall was going up (and down) the huge grade on I70 in Colorado at the Eisenhower tunnel and kept up with traffic just fine.
Back end holds a 4' x 4' sheet of plywood and I built a sub-floor raised about 2' to increase functionality of the rear space.
Full disclosure, this is our first trailer and first tow vehicle.
Greg
greghoro is offline   Reply With Quote
Old 01-13-2016, 07:17 PM   #39
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
My Toyota 4-Runner, 6 cyl. towed a 6000 lb. Gross wt. Hi-Lo for 6 years, no hassle.
A Sequoia or another Land Cruiser should handle the 6000 lb. Serenity O.K.
MelGoddard is offline   Reply With Quote
Old 01-13-2016, 07:32 PM   #40
2004 22' Safari
Albuquerque , New Mexico
Thanks so much,
Rob
You won't have any trouble with a Sequoia. You might want to reconsider, though. I was absolutely set on an SUV and had a lot of experienced people who worked for me strongly recommending a truck. I am glad I got a Tundra, since I have generators and gas cans etc that are separated from the cabin, and I don't have to worry about fumes.
Silver.Sanctuary is offline   Reply With Quote
Old 01-13-2016, 07:38 PM   #41
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Guess he changed his mind.
Lance
Old 01-13-2016, 08:31 PM   #42
lindaebrewer's Avatar
Sacramento , California
We bought a 23' FC FB last summer. Pulled it to Canada & back w our 2006 Toyota 4Runner w tow package which was fine w our 17.5 Bigfoot but not so fine w the AS. This winter we traded for a 2013 GMC Yukon Denali w tow package. Perfect!
lindaebrewer is offline   Reply With Quote
Someone please talk me down-- i don't want an SOB! bakerliz Off Topic Forum 19 04-01-2008 07:06 PM
What if you don't want a mirror finish? retrocats Cleaning, Stripping & Polishing 7 04-22-2007 11:38 PM
Don't want to "Beat a Dead Horse" but...? Baby Whoopie Electrical - Systems, Generators, Batteries & Solar 1 09-27-2006 03:57 PM
