06-18-2010, 08:17 PM
asbury park
, New Jersey
'feedback' to T.V. when plugged into trailer.
on the 84 suburban we have bargman 7 way car end connector and on the trailer is a 7 way pigtail ('umbilical cord') harness to plug in to the car end connector.
there are a few problems. First, it seems there is 'feedback' to the TV at some point. here's whats happening;
When the tow vehicle brakes are hit, ALL the running lights turn on (EXCEPT Tail lights). When the TV headlights are ON (all running gear on too, including tail lights), and we hit the brakes, the taillights turn OFF.
the suburban usually makes a beeping noise when the lights are ON and the car isn't. but when we hit the brake with the lights off, beeping starts.
With a voltage tester, there was no power at the connector on any of the & way prongs when the left or right turn signal was activated.
I read something about 'diodes' that control energy from the TV and make sure its going in one direction. are these built in to the car-end connector? is it an add on i need? is it relevant here?
Have we just messed up the configuration, or what?
I've tried searching the forums for the answer for the last hour and came up with nothing :/
06-18-2010, 09:34 PM
1970 23' Safari
1956 26' Cruiser Overlander
Lambertville
, Michigan
Sounds to me like the TV alternator puked! Take it off and get it tested at Autozone or somewhere. Be prepared to replace. Not a terrible job, and will take an hour or so.
Dave
TAC# MI-1
Operation "Save Rudy" Strike Team (charter member)
Yes, I am still working on it.
06-18-2010, 09:59 PM
Moderator Emeritus
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna
Working from the assumption that either the trailer or the Suburban is new to you, my suspicion of potential causes for your difficulty would include: - Corossion bridging between one or morterminals causing shorting. If corossion is found when the connectors are opened up, repalcement of the parts is likely the easiest solution.
- There is a mismatch between among the 7-pins of the connector. If this is the case, it may require rewiring either the trailer end, tow vehicle end, or sometimes both.
- When I encountered this problem, I started with the trailer end by disassembling the connector end
- Cut each wire back and stripped the end to create a new clean connection.
- Used a 12 volt power source and a 2 pair of alligator clamps - - one for ground and the other for hot
- The hot alligator clamp was then applied briefly to each wire to ascrtain its function and once that was done it was secured to the appropriate terminal in a new 7-pole connector -- see this link for information about the industry standard wiring pattern.
- On the tow vehicle end, the process was similar. The old connector was disassembled
- Each of the existing wires were cut back and new clean ends stripped.
- Using a test light, the function of each wire was determined and it was connected to the appropriate terminal on the connector.
Airstream didn't start using the industry standard Bargman connector wiring pattern until the late 1980s or early 1990s. I haven't seen a wiring schematic for the Airstream Bargman connector that pre-dates 1964 so the testing is often necessary with the older Vintage coaches. Even with a modern tow vehicle there isn't a 100% assurance that its wires will correspond to the expected color codes - - I know that my 1999 GMC didn't.
There is also the possibility of corossion causing issues in the umbilical cord junction box. My understanding is that for most if not all 1960s Airstreams this junction box is located in the front curbside corner of the bellypan and is identified by a square or rectangular removable cover. There were problems with abraded wires and shorting between wires that had to be corrected in my Overlander's junction box when I experienced similar problems.
Good luck in locating your wiring Gremlin!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
06-19-2010, 03:58 AM
1967 26' Overlander
Huntsville
, Alabama
Originally Posted by NJtoNC
...I read something about 'diodes' that control energy from the TV and make sure its going in one direction. are these built in to the car-end connector? is it an add on i need? is it relevant here? ...
The diodes you read about are used for tow vehicles which have separate light bulbs on each side for brake and turn-signal lights. Your Suburban uses one bulb for both just like your Airstream does (unless someone modified it in the past). So there should not be any diodes in your setup.
A bad ground can cause the issues you are having. I have seen many cases where the ground wire was not connected on the tow vehicle's side of the wiring under the assumption that hooking the trailer to the ball is sufficient to complete the ground path.
You could speed up trouble-shooting if you could hook up to a known good travel trailer or hook your Airstream to a known good tow vehicle.
Tom
06-19-2010, 05:15 AM
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown
, Tennessee
When strange things like this happen it is almost always a ground problem. Most likely at one or more trailer sockets. Also keep in mind that running lights etc. are usually grounded where they rivet to the body.
Trouble shooting something like this can be a lot of trial and error. The problem most likely will be with the trailer.
Substitution could help isolate it. Either hook your TV to a known working trailer. or hook a known working TV to your trailer.
Poor grounds make for strange happenings
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
06-21-2010, 09:12 AM
asbury park
, New Jersey
to follow up;
we tested w/ other TV, and all worked. so problem was with the suburban. then it got turned over to dad to solve. unfortunately i cant really report on the final troublemaker - when i got home from a baby shower the TV was fixed
thanks all for ideas. you provided thoughtful insight and ultimately helped get it fixed.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Plugged or Un-plugged in the Driveway
clancy_boy |
Winterizing, Storage, Carports & Covers |
25 |
10-02-2017 01:14 PM |
P&S trailer clearcoating feedback, happy or upset
wishsilver |
Clearcoat, Exterior Paint & Trim |
45 |
01-23-2011 06:10 PM |
plugged in
rashton |
Electrical - Systems, Generators, Batteries & Solar |
3 |
05-24-2008 01:38 PM |
Plugged in 24/7
Chaplain Kent |
21 |
12-04-2006 10:55 AM |
Question - Keeping Trailer Plugged In
kamadeca |
5 |
05-08-2006 12:28 PM |
