Old 02-22-2016, 10:03 PM   #15
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
"If you back into a site that is very tight the Hensley interferes with the foot. You need to pull forward first to straighten the Hensley out in order to lower the foot."
That's what I have been wondering about it with our ProPride hitch. In other words, the w.d. bar will block the Fastway from coming down if the hitch is turned at an angle?
Doug and Cheryl
Old 02-22-2016, 11:00 PM   #16
LAWBC's Avatar
2013 27' FB International
2012 23' Flying Cloud
Victoria , British Columbia
Had a Fastway flip foot installed on our 23 FB and really for some reason I just didn't like it seems to me especially when your on an incline that the damn thing might just buckle . You have to watch when the unit is being deployed , that it is fully down like mentioned by another poster .Also the mechanic that installed it did not set the limiter properly on the jack and it keep blowing fuses ( 30 amp) until I had it adjusted . There's another story about the fuse on your jack , they are special 30 amp slow blow and hard to find. Anyway I don't have it on the 27FB , and that is my experience.
Laurence
LAWBC is offline   Reply With Quote
Old 02-24-2016, 05:45 AM   #17
Ayr , Ontario
Yes. The W.D. bars block the foot from coming down. Really annoying when you've already chocked the wheels and sometimes "plugged in" only to find out you can't lower the Jack. Now it is the first thing I try. After going back to the Hensley late last year I hope I don't forget about it this year. It's more of an annoyance.
As far as the Fastway goes I don't think it is useful on an Airstream trailer. An SOB yes, but an AS no. The trailers are much lower to the ground to begin with and I have never run out of travel on the Jack on a real campsite. When I park the AS next to my house is the only time I run out of Jack, but I am unable to deploy the Fastway since the SUV is on such a steep slope the Tongue is almost on the ground when I go to unhitch and it can't swing out.
Walt
gator.bigfoot is offline   Reply With Quote
Old 01-02-2017, 12:59 PM   #18
The Colonel's Avatar
2017 25' Flying Cloud
Navarre , Florida
Well, I just ordered one for my 25FC and will watch these concerns, but am optimist it will help. I'll definitely watch as it is deployed to ensure it is vertical. If it doesn't work out I'll remove it.
The Colonel is offline   Reply With Quote
Old 01-02-2017, 01:32 PM   #19
dkottum's Avatar
We've used a couple of different jack feet, one the factory stand that stuck to the shaft and had to be pounded off, another that screwed on and interfered with the w.d. bars.
I had a scrap piece of 6x8x12 wood lying around, dropped the jack on it without issues, and it's doing the job very well as we move around the country.
Doug and Cheryl
