Old 10-23-2016, 06:39 AM   #1
Naper's Avatar
Loretto , Ontario
F250 Trailer Charge Dead
I have a 2017 F250, trailer charging from the 7 pin connector is not working. The fuse (30 amp #27) is good. Cant find the relay no mention of it in the owners manual. Trailer lights and brakes work.
Naper is offline   Reply With Quote
Old 10-23-2016, 07:32 AM   #2
2011 27' FB Classic
Camp Hill , Pennsylvania
I had the same issue. My Ford dealer went nuts finding what was wrong but eventually came up with a service note on it. There is no voltage on the truck pin unless there is a load on it. That's done so we don't short out the truck battery if snow or water gets into the connector. To prove this is correct measure the trailer battery voltage when disconnected. Then connect and start the truck. The voltage should be higher on the trailer battery.
LyleRussell is offline   Reply With Quote
Old 10-23-2016, 09:30 AM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
My 2006 F150 had a relay, at least it had a spot for a relay, but it was not installed. I bought the relay and my trailer charge port became active (but only when the engine was running).
On a lark, I dug up the manual for the 2017 F250:
http://www.fordservicecontent.com/Fo...ngEnabled=True
Fuse 27 says it powers the trailer tow charge relay
Item 37 is the relay
Maybe Canadian trucks are different
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 10-23-2016, 10:48 AM   #4
Naper's Avatar
Loretto , Ontario
[QUOTE=LyleRussell;1867959]I had the same issue. My Ford dealer went nuts finding what was wrong but eventually came up with a service note on it. There is no voltage on the truck pin unless there is a load on it. That's done so we don't short out the truck battery if snow or water gets into the connector. To prove this is correct measure the trailer battery voltage when disconnected. Then connect and start the truck. The voltage should be higher on the trailer battery.[/
Thank you.
The truck connector wouldn't show power on a meter or a 7 pin test light. I am thinking it needs some feed back voltage to activate.
Old 10-23-2016, 07:22 PM   #5
2011 27' FB Classic
Naperville that's the exact experience that I had. Try my test. It's true of 2015 and newer. There is a fuse but it was installed at the factory. The relay is now built in.
Try my test to see if I'm right.
Old 10-23-2016, 08:34 PM   #6
2011 27' FB Classic
Naper sorry about my autocomplete function.
Old 10-24-2016, 02:45 PM   #7
Naper's Avatar
Loretto , Ontario
Yep you are correct. Plugged in to the truck started the engine and sure enough it was charging. It would be helpful if Ford mentioned this in the owners manual.
Solar charge controller affect charge from converter? fran&frank Electrical - Systems, Generators, Batteries & Solar 1 03-22-2016 10:39 PM
dead dead bolt Jim from SB Doors & Locks 3 09-09-2012 11:32 AM
Charge wire on 7-pin, what demands does AS need and how does this charge starcraft Batteries, Univolts, Converters & Inverters 10 04-20-2012 08:38 AM
Full Charge - No Charge! Cracker Batteries, Univolts, Converters & Inverters 2 06-22-2007 02:04 PM
Dead ...really dead Melody Ranch Batteries, Univolts, Converters & Inverters 17 06-13-2007 12:23 AM
