Old 02-11-2017, 11:15 PM   #1
Some Guy
djarrett's Avatar
2018 28' Tommy Bahama
Nashville , Tennessee
F250 and No Weight Distribution Hitch?
I was watching an interview with the design lead for the 2017 F250.
In this interview, he states that due to the new box frame, that no weight distribution hitch is needed.
I am wondering thoughts on this and if anyone is using the new F250 in this way?
Here is the interview:
Thoughts?
D
The Jarretts
Nashville, Tennessee
2018 27' Tommy Bahama
2015 F250 TV-Petrol
WBCCI # 22342
djarrett is offline   Reply With Quote
Old 02-11-2017, 11:58 PM   #2
2016 28' International
San Marcos , California
I read the same thing and was excited until I hooked up my Airstream with 900lb tongue weight to my 2017 F-250, it for sure needs a WD hitch. Without it the suspension compresses significantly.
Mgieselman is offline   Reply With Quote
Old 02-12-2017, 12:17 AM   #3
Some Guy
djarrett's Avatar
Does yours have the HD rear spring package?
The Jarretts
2015 F250 TV-Petrol
WBCCI # 22342
Old 02-12-2017, 02:55 AM   #4
Gainesville , Florida
How much does the front rise?
Old 02-12-2017, 11:41 AM   #5
1978 Argosy Minuet 6.7 Metre
1971 27' Overlander
1973 31' Sovereign
Griffin , Georgia
Images: 14
I'd use a hitch for the anti sway controller for sure.
paddle whisp is offline   Reply With Quote
Old 02-12-2017, 11:59 AM   #6
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
As long as you are going to use the anti sway bars then might as well employ the WD also.
TinCan
graysailor is offline   Reply With Quote
Old 02-12-2017, 12:38 PM   #7
jcl
Vancouver , British Columbia
A boxed frame is certainly stiffer. When the original Expedition came out, it used the pickup frame, but with boxed rails for increased stiffness. The difference was noticeable when driving the two vehicles back to back. From a frame strength perspective, he is likely right.
But that isn't the primary reason to use weight distribution equipment.
Imagine you are going to load 1000 lbs or so, equivalent to the amount of tongue weight you may have, in a concentrated load, into the back of a new pickup that isn't towing anything. You have a choice to locate the 1000 lbs 12 inches or so behind the rear bumper (where the hitch is) or up in the centre of the bed, between the two axles. It is easy to understand why of those two examples, the one with the weight forward will handle better. All WD equipment does is move the virtual load forward, exactly like in that example. You may not need to, but why wouldn't you? In other words, why accept the compromises in handling and safety by not doing so?
What the designer is really saying, IMO, is that he is a specialist on frame strength, and not loading and towing dynamics.
Jeff
jcl is offline   Reply With Quote
Old 02-12-2017, 01:03 PM   #8
Long Island , New York
One function of a WD hitch goes beyond the static measurements being considered, and is the most important one IMO -- that of the rig in motion on roads which are not perfectly flat. As the road surface undulates up and down, and the combined rig of TV and AS reacts by Hobby-horsing up and down, the WD hitch dampens these dynamic oscillations. The complicated hitches like Hensley and Pro-Pride control this dampening in a serious way, but all WD hitches do it to some extent.
No matter how much static load the new F-250 will handle, dealing with the combined rig in motion underscores -- IMO -- that almost all trailers require some WD except for maybe the smallest at 16' to 19' or so.
And on this issue there are tons of other threads . . .
Good luck!
Peter
Old 02-12-2017, 01:05 PM   #9
Some Guy
djarrett's Avatar
Well, I was intrigued by the comment. When we had our airstream delivered, the guy that delivered it from Texas to Tennessee pulled it the entire way with no sway or weight distribution apparatus. He did, however have a dually truck.
I'm 54 and find there are things I don't like about distribution hitches -
1) Weight. My back isn't the best, and just moving the hitch to and from the truck when we arrive at home from a trip kills my back.
2) Aggravation of attaching. Dirty hands, getting sweaty before a drive, etc. No fun.
3) My wife and I cannot stand all the popping and creaking especially when we are arriving in a quiet campground. All the moans and banging sounds awful.
I just thought if what this guy was saying is true, it might save some of that aggravation.
I'm now looking at the (fairly) new Anderson weight distribution hitch.
Dog if Im gonna keep punishing my back like this.
The Jarretts
2015 F250 TV-Petrol
WBCCI # 22342
Old 02-12-2017, 02:45 PM   #10
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Hensley Arrow
djarrett,
Look for a used Hensley Arrow hitch and leave the stinger in place when you unhitch. To deter theft I have used a hitch tube and locked it in place. Yes, it takes some getting use to when backing up for perfect alignment but your back will appreciate it. Hensleys are expensive but worth every penny.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 02-12-2017, 04:34 PM   #11
1987 32' Excella
Sagle , Idaho
I have a 2007 F250 and the load leveling hitch and bars makes my 32 ft Excella a dream to pull. I dont want or need more springs on the truck.
southsaglejim is offline   Reply With Quote
Old 02-12-2017, 04:38 PM   #12
Some Guy
djarrett's Avatar
To clarify, I have a 2015 F250 and a Equalizer hitch, which I love the performance of. What I don't like is all the things specified above.
What prompted the post was seeing the interview stating no weight distribution hitch was needed on the new 2017 box frame truck.
Im researching the Anderson Weight distribution hitch, as it is light weight and a new approach. I've seen the Hensley, but it looks like it weights a ton. I realize you leave it on the trailer, but sooner or later you're gonna have to take it off.
D
The Jarretts
2015 F250 TV-Petrol
WBCCI # 22342
Old 02-12-2017, 04:41 PM   #13
Frederica , Delaware
Having owned the Andersen, you may not like performance of it. Light trucks and heavy tongue weights don't do very well with this hitch. I don't know where you stand in this situation. I did a lot of things to make this hitch work. The only thing I did with any success was to deform the washers it came with.
Overloaded is offline   Reply With Quote
Old 02-12-2017, 04:45 PM   #14
Some Guy
djarrett's Avatar
What about with an F250 (not a light truck)?
The Jarretts
2015 F250 TV-Petrol
WBCCI # 22342
Weight distribution hitch and/or sway control chaeha Towing, Tow Vehicles & Hitches 14 10-11-2018 04:52 PM
Weight Distribution and Tongue Weight AldeanFan Hitches, Couplers & Balls 28 01-27-2013 10:28 PM
Tongue weight and weight distribution Bex Hitches, Couplers & Balls 8 06-06-2010 12:11 PM
touareg, bambi and weight distribution hitch ericwarren Hitches, Couplers & Balls 2 10-02-2008 09:19 PM
Refined TV weight numbers = required weight distribution? flyfishfred Hitches, Couplers & Balls 4 01-12-2008 08:13 PM
