Old 08-24-2013, 07:58 PM   #1
1971 31' Sovereign
fresno , California
F150 relay question
I have a 2006 f 150 xlt. I got the relay to run the charging system and running lights but I still have no lights.brake, turn signals and flashers all work. The parts guy didn't know for sure what the part number for the relay is and I suspect I got the wrong part. Does anyone know the part number or where I can find it? Thanks in advanc
imbighoe is offline   Reply With Quote
Old 08-24-2013, 09:23 PM   #2
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
You can move the relays around to see if it IS a relay. Ford had a huge problem with moisture entering into the fuse box through bad design and cracked winshields. Google Ford and check on a "GEM" box, located above the fuse box above the driver's side inside compartment..From what I understand, it's a bearcat to replace. Good luck.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 08-24-2013, 10:48 PM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
So, you have brake lights and turn signals, but none of the running lights work (neither the tail lights on the low-power filament, nor the marker lights)?
Since you have a vintage trailer, are you sure that you have the umbilical connector wired correctly for modern tow vehicles? Did these lights work before and stop, or is this the first time to set up this trailer with this tow vehicle?
If you're familiar with the pinout pattern and a multimeter, you can check for voltage on the truck's output pins. If you're not, or just don't want to fiddle with it, you can get a plug-in tester like this one to check the truck's brake circuitry.
David
Old 08-25-2013, 04:16 AM   #4
johnamjr's Avatar
1970 25' Tradewind
parkville , Maryland
Check to see that the fuse is there. The relay is most likely fine. But a lot of f150s don't come with the fuse for towing accessories. So nothing would work. Other wise check your umbilical pin out.
johnamjr is offline   Reply With Quote
Old 08-25-2013, 07:02 PM   #5
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
My 2003 F150 needed both fuses and relays. Don't know thew part #, but don't you have the owner's manual? Auto parts store will have the numbers.
Alumacoot
"I'd rather be happy for just one day than miserable for the rest of my life."
Dan and Liz is offline   Reply With Quote
Relay Question mcm9970 Land Yacht/Legacy Motorhomes 25 06-17-2013 11:05 AM
Question about wiring new battery charger on the battery side of the latching relay. BTUs4You General Repair Forum 3 07-27-2012 12:36 PM
Relay for Life Walkathon sparky5 Off Topic Forum 3 04-23-2006 07:21 PM
Ac Relay ? tinman7 Furnaces, Heaters, Fireplaces & Air Conditioning 7 06-08-2004 06:50 PM
Suburban furnace.. need relay.. Happycampers Furnaces, Heaters, Fireplaces & Air Conditioning 5 05-10-2004 02:35 PM
