Old 06-26-2013, 08:12 AM   #1
1982 34' Limited
Harrowsmith , Ontario
F150 payload
I'm hoping someone can share their thoughts on F150 payload. Right now I have a 2012 F150 Supercab with the 5.0 litre and 3.73 axle. Payload is ~1800 on this. I'm thinking of changing to a 2013 SuperCrew with the EcoBoost - the truck does not have the Max Tow package and has the 3.55 axle. The dealer prefers the 3.55 axle for fuel savings. Payload on this is 1520 which is less than the current one and is what has me concerned. Tow capacity is fine at 9700 lbs.
Do I need to be concerned about that given what I'm towing (76 Sovereign)? I don't think I'll be changing the trailer for some time and if I do it would likely be an older (80's) 34'.
My 76 has a reasonably light tongue (~500 dry) and we travel lightly enough - I don't expect to put much, if anything, in the truck box.
Does anyone have any suggestions to offer about this? Anyone doing it with an EB and 3.55?
BradB is offline   Reply With Quote
Old 06-26-2013, 08:33 AM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I think you will be ok, if you really travel light. No doubt, the vehicle will pull the trailer.
Several limits are set by the manufacturer (tire load, axel load, hitch load, payload, gross vehicle weight, max combined weight), though they surely include some safety margin. Each limit is important as the other. Exceeding any one by a large amount could be dangerous.
My advice: do some honest math, based on how you load the vehicle, before you purchase.
Alan
Old 06-26-2013, 09:05 AM   #3
1982 34' Limited
Thanks - I'm talking to the dealer right now and he's trying to understand payload more fully. I think it's often a totally misunderstood area!
Options on the vehicle are subtracted from the payload right?
Old 06-26-2013, 09:52 AM   #4
Tongue weight of the trailer is subtracted from the payload. Load yourself, your wife, the family dog and a full tank of fuel into the truck and you may have a couple of hundred pounds for camping gear or an extra passenger. Why should you have to choose which to carry?
Is the payload improved by a lower rear end ratio? If so, that is a better choice.
handn is offline   Reply With Quote
Old 06-26-2013, 10:02 AM   #5
Sphere Guy's Avatar
2016 30' Classic
Livingston , Texas
All things going on, on top of or into, detracts from the payload, fuel, people, pets, bed liners, bed caps, food, drinks, chairs, etc.... especially tounge weight!
I wouldn't think a gear ratio would benefit the payload.
Sphere Guy
AIR 50601
Sphere Guy is offline   Reply With Quote
Old 06-26-2013, 10:59 AM   #6
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
The problem is that the F150's HD payload package ONLY comes with the 3.73 limited-slip rear axle, at least in 2WD configs. So, you're going to be down on payload from the ideal case for F150s if you buy one of those 3.55s off the dealer's lot.
I've pretty much resigned myself to a factory order for the next truck, because dealers rarely stock the HD payload with nice trim levels. I think part of the reasons they don't stock those configurations in Lariats is that the "fancy" factory wheels aren't compatible with the 7-lug hubs, and of course EVERYONE needs 20" wheels on their pickup, right?
David
Old 06-26-2013, 11:32 AM   #7
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Are these payload numbers you are quoting being taken from the sticker on the trucks driver side door jam or from another source.If it is from another source t is probably much less as each truck is different due to weight of options and configurations available.
Old 06-26-2013, 11:44 AM   #8
JFScheck's Avatar
Rockville , Maryland
Images: 33
Double check your "Max Payload" sticker inside your door jamb. Also, in the Ford Owners guide, is a great explanation of the importance of this sticker and how to use it in calculating your "Max Payload Weight".
Basically for Ford F-150 2013 Trucks - According to the owners manual, Max Payload is the truck with a full tank of gas already accounted for, but no driver, passenger or payload.
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 06-26-2013, 01:42 PM   #9
1982 34' Limited
They're just from the literature, not on the door itself. Just to make sure I understand, the door sticker will likely be less than what I posted?
Old 06-26-2013, 01:46 PM   #10
1982 34' Limited
That does seem to be a problem, trucks that are cars.
I had a hard time getting 3.73 in my 2012 at all as it was. I think I may have to order eventually too because it's too hard to find exactly what you want.
Old 06-26-2013, 01:51 PM   #11
Moflash's Avatar
Yes the true payload will be on the door jamb of each truck.The literature figure is without any options and is not accurate.This is tricky you have to read carefully including the fine print.
Old 06-26-2013, 02:17 PM   #12
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up The only "payload" I worry about....
Weigh your truck hitched-up, loaded for camping, look on the door jamb sticker to get the axle weight ratings.
Example...
Our TV,
GAWR frt. 4180lbs
GAWR rear 5500lbs
Loaded & hitched,
Frt. 3640lbs=540lbs of standby payload.
Rear 4680lbs=820lbs of standby payload.
PFC
"Tahawus"
RLC
Step aside Starbucks, this is a job for alcohol.
Old 06-26-2013, 02:23 PM   #13
Moflash's Avatar
Example:My f150 had the optional 7200lb Gvwr with only a 1340 max payload.That 1340 includes passengers,tongue weight,WD hitch and any gear you put in or on the truck. It fades away quickly.
Old 06-26-2013, 02:29 PM   #14
X2
You can't figure payload without actual weights and axle ratings...all else is guesswork.
Consider the stated AS tongue weights.
PFC
"Tahawus"
RLC
