Old 07-30-2012, 08:54 AM   #1
Loeber's Avatar
Calgary , Alberta
F-150 "Trailer disconnected"
I have a 2011 F-150 Ecoboost that I use to tow my 31' with. When I apply the brakes my dash display shows "Trailer Connected" and as soon as I remove my foot I get a bell tone and "Trailer disconnected" I have my gain set at +6 and I am not having any issues braking or stopping, it just seems odd that the display would show this and chime after every time I stop? Does anyone have insight to why this would be happening? My dealership is stumped and I couldn't find anything in the manual.
Cheers
Dan
Loeber is offline   Reply With Quote
Old 07-30-2012, 09:07 AM   #2
2012 25' Flying Cloud
Tacoma , Washington
Dan,
I really have no idea but it sounds like it could possibly be the embilical cord ??? Or something in the sending unit on your dash panel ??? Definitely would insist the dealership find the solution . Are you getting braking? The below link may shed some light as well???
Good Luck !
OEM trailer brake controller problem, "trailer not connected" - Ford F150 Forum - Community of Ford Truck Fans
BigGrey is offline   Reply With Quote
Old 07-30-2012, 09:15 AM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Looking through that F150 forum post, it seems like there's some sensitivity on the center pin (the statement was that if you use an adapter to 6-pin so that there's no circuit completed for the center pin, the controller reads "no trailer.")
Do you have reverse lights hooked in an working on your '79?
— David
Old 07-30-2012, 10:00 AM   #4
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
I like it. When you need to stop, you have all the advantages of a proper trailer braking system. Other times you have all the performance and economy of not towing the trailer when it is disconnected. The best of both worlds.
Sorry, I just couldn't resist. It would be great if you really could make things work that way.
I'm pretty much stumped. I would think it was an intermittent connection, but it always shows "Trailer Connected" when you put your foot on the brakes, then gives you a bell tone and displays "Trailer Disconnected" when you take your foot off the brake. When it is doing the same thing consistently, that implies that the connections are good.
Vaughan
Old 07-30-2012, 10:11 AM   #5
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Originally Posted by vswingfield View Post
when you take your food off the brake. When it is doing the same thing consistently, that implies that the connections are good.
Well here is the problem. He is putting food on the brake and not his foot
Sorry couldn't help myself. (this happens to me all the time too.)
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-30-2012, 10:20 AM   #6
Wayward's Avatar
Cary , North Carolina
connection
I had this happen on my f250.
When the truck was brand new it would not recognize the plug. I tried everything and checked everything. The dealer fixed it pronto. They did something simple on the truck but I cannot remember what - maybe a loose connector.
This year it happened again but reseating the trailer connector fixed it. It happened a second time so I sprayed some electrical contact cleaner on the connectors and then a light coat of dielectric grease. Seems to have done the trick
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 07-30-2012, 10:24 AM   #7
1983 34' Excella
1967 24' Tradewind
Images: 32
I'll show you! It's still within the edit time period. Now everyone will think you're crazy, not me...ha..ha..ha!
For those coming onto this later, I originally had :I would think it was an intermittent connection, but it always shows "Trailer Connected" when you put your foot on the brakes, then gives you a bell tone and displays "Trailer Disconnected" when you take your food off the brake."
Actually I had him putting his foot on the brake and then removing his food from the brake. This is obviously improper operation. Just think what it would do to a sandwich. Although a piece of watermelon has a certain Gallagher appeal.
Thanks for catching that, It made me laugh.
Vaughan
Old 07-30-2012, 10:39 AM   #8
purman's Avatar
1968 28' Ambassador
Ha Ha HA You fixed the original but it still show up in the quote
crawford Gene catches all my stuff (and points it out) I think it makes for better reading personally.. little laugh here and there is good for you.
The worst is when I use my iphone. That has auto correct, and if your not paying attention can really change things.
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-30-2012, 10:50 AM   #9
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
So back to the OP's problem... I had the same thing happen with my new F250 and new Airstream. Cleaning the plug connectors on the trailer side has fixed it for the last 10,000 miles of towing...
The NSA -- The only part of the government that listens.
newroswell is offline   Reply With Quote
Old 07-30-2012, 10:58 AM   #10
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Clipper, Drawtite
My Clipper has a 6 pole connector with a Drawtite Controller.
I get the trailer disconnected signal if I use the 6 to 4 adapter plug when using my cargo trailer with no brakes. Drawtite works as it should on the 6 pole plug to the Tracker toad that has no electric brakes (air brake over hydraulic).
This tells me it is probably the way you have the plug wired.
I have not pulled a trailer with brakes for some time so assume the Drawtite still works as it should.
Dave
Old 07-30-2012, 01:04 PM   #11
Loeber's Avatar
Calgary , Alberta
Thanks kids!! The truck is going in for service next week. I'll get them to check it then. I'll just have to try not to spill any food on the brake til then.
Cheers
Dan
Old 07-30-2012, 01:41 PM   #12
alclad's Avatar
1961 16' Bambi
Wilmington , DE
Images: 46
use this:
Sanchem NOOXID electrical grease & electrically conductive grease dielectric grease and contact lubricants
on all electrical connections.
it works.
alclad is offline   Reply With Quote
Old 07-30-2012, 09:22 PM   #13
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Originally Posted by alclad View Post
I hate dielectric grease. Gets old, catches crap and never really "seals". I use a product similar to the above (the above is better) and haven't cleaned a car battery terminal or lamp socket in over twenty years.
Thanks for the link!
And tell the cop the, ah, break peddle still had lasagna sauce on it . . kinda slippery for heel & toe work.
