Old 04-22-2018, 12:27 PM   #15
2016 25' International
Deerfield , Massachusetts
Originally Posted by graysailor View Post
Save yourself some aggravation as I went thru this same process. Cut to the chase and get a F250 diesel. It will cover all of your needs.
I do understand the love of diesel... but the payback timeline on the cost is always a tough calculation for me....
thiel is offline   Reply With Quote
Old 04-22-2018, 12:28 PM   #16
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Originally Posted by cplyons View Post
Howdy,
I can only speak from my experience, but I bought a 2013 F150 with the 3.5 ecoboost engine and Max Tow package, and it tows my 9000 pound 1985 Excella superbly. Very capable truck. You probably know this, but don't take the Manufacturer quoted tow ratings seriously. My truck is rated for 17K pounds but I would hesitate to go much over 11K with it. Also, please pay close attention when choosing a weight distribution tow rig. A good one properly adjusted increases comfort level and driving confidence enormously. - Chris
I doubt your F150 is rated to tow 17k lb. Perhaps it's rated for 17k GCWR (max trailer weight PLUS the truck weight)? I'd expect a '13 Max Tow to be rated for around 11k trailer weight.
— David
Old 04-22-2018, 02:11 PM   #17
2016 25' Flying Cloud
Holly Springs , Mississippi
...and when considering payload, don't forget that a weight distribution hitch transfers a portion of the tongue weight back to the trailer's axle(s). Some say as much as one-third, but a scale tells the story.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 04-29-2018, 08:55 PM   #18
ITSNO60's Avatar
Tucson , AZ
Originally Posted by Me. Bill View Post
Good Morning all. I’m looking into purchasing a 27 ft international. I spoke with a dealer about possibly going with a F-250 Diesel He recommended a 150 gas which has a 13,200 tow rating. I’m sure this isn’t the first nor will be the last time this question was asked but I appreciate your thoughts. Thank you.
I am flat out amazed at the stated towing capacity of the new trucks. My 2002 F-350 SRW diesel is only rated to tow 12,500. My payload however is 2930 (4X4 LB,CC) but even at that I figured loaded for a trip with a 7K trailer, fuel, people, supplies & camper shell we are using up 2,320 lbs of the payload capacity, so we have a safety margin of only about 600 lbs with a 1 ton truck!
Brian
ITSNO60 is offline   Reply With Quote
Old 04-29-2018, 09:42 PM   #19
AirstreamCSH's Avatar
Huntington , New York
I tow with an F250 diesel 2017 crew cab and was so worried about the ride quality that I didn’t add the $300 helper spring that makes it an F350. It was a mistake because the truck drives so smoothly and that spring doesn’t change anything as it already has the snow plow option.
Which brings me to a comment here about not wanting the 250 as a daily driver because the 150 is more comfortable. Having just spent 4 days in a rental 150 EcoBoost crew cab 2017 rental I was surprised by how similar the ride was. The bodies of the 150 and 250 are the same, the chassis is different. Anyone concerned about the ride quality on these new trucks and making a decision on that basis should try renting one for a few days.
With either, parking in a parking deck will take some forethought for how to back out and so forth. A full size crew pickup simply requires thinking about turning radius and so forth.
AirstreamCSH is offline   Reply With Quote
Old 04-30-2018, 08:58 AM   #20
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
I have been towing a 1997 34' for the past 8 years with our 2009 F150 5.4L gas. It tows and handles great with the ProPride hitch. My first couple of outings was with a Reese W/D hitch. The ProPride made it a much more capable combo. We've been through high passes (11,000') and across the plains without issue.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Review of first trip with Ford F-150 as tow vehicle ghaag Towing, Tow Vehicles & Hitches 40 08-02-2016 05:10 PM
Looking at Ford 250 versus 150 - possible to overdo it on tow vehicle bonginator Tow Vehicles 13 09-08-2013 06:55 AM
E 150,250,350 for Tow Vehicle Chaplain Kent Tow Vehicles 11 05-12-2011 11:51 AM
New Tow Vehicle - 2010 Ford F-150 mello mike Tow Vehicles 50 03-21-2011 10:37 PM
Ford F-150 As a Tow Vehicle Cstar Tow Vehicles 16 05-02-2004 07:24 AM
