Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 07-11-2009, 09:42 PM   #1
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
EZ Trailer Connector?
Has anyone used this new style 7-pin connector on their Airstream?
http://www.ezconnector.com/best-trailer-plug.html
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
https://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-11-2009, 09:47 PM   #2
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Looks pretty cool. But then I would have to replace the other utility trailers and the other TV that could get costly.
But if you just use it on the AS I don't see why is wouldn't work well.
But then, Why fix what isn't broken....
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-11-2009, 10:41 PM   #3
6PackCharlie's Avatar
1995 30' Excella
Logan , New Mexico
Hey Mike,
When I bought my new tow vehicle, it came wired with the flat 7 pin connector. I swithed the 9 pin plug that was on my airstream to a 7 pin flat plug(bought it a NAPA). I had to leave out two wires, but they were ones that weren't being used anyway. Mine works pretty slick.
Charles & Annette
WBCCI # 1407 -- Member 4CU
1995 31' Excella
Dodge 2500 Diesel-Tow Vehicle
___________________________________________
6PackCharlie is offline   Reply With Quote
Old 07-12-2009, 02:02 AM   #4
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
I should have explained why I made this thread in the first place. I found out today that the trailer end of my 7-pin connector is bad. One contact point is actually missing (the one for my running lights, no wonder they don't work). While researching this problem online, I came across this website. Looks like a nice product and was just curious if anybody is using one.
1958 Overlander
4CU 1st VP
Old 07-12-2009, 04:02 AM   #5
"Cloudsplitter"
Better be REAL good for $109.00.
I think Jason may be right......"if it ain't broke, fix it 'til it is"
Old 07-12-2009, 07:12 AM   #6
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
If you keep the TV connection "stock" you won't be limited to towing your trailer with just one TV.
Richard
'71 Tow vehicle/trailer 7 way connector wiring Lumatic Lights - Interior & Exterior 12 08-15-2010 08:19 PM
replacing umbilical/rewiring trailer connector funkill Electrical - Systems, Generators, Batteries & Solar 7 06-22-2009 07:42 AM
Oh no, 7-Pin trailer Connector corroded... now what?? mmfly4fun General Repair Forum 5 05-20-2009 07:36 PM
Adapting a 7 pin vehicle connector to a 9 pin Airstream connector PatandLane Lights - Interior & Exterior 3 03-22-2009 07:09 PM
7 Pin Male Trailer Connector. firedog Electrical - Systems, Generators, Batteries & Solar 0 07-31-2007 02:02 PM
