Old 02-23-2017, 06:58 PM   #1
waninae39's Avatar
2017 22' Sport
NCR , Ontario
Extend mirrors for pulling a 7.5' wide trailer
Hello
We are getting an airtream sport 22BF camper Trailer. It is 7.5' wide.
https://www.airstream.com/travel-trailers/sport/
We are told that we need to add Extend mirrors on the Q5 car. if not, the camper is more wide that the Q5 thus we can not see back.
what is the best Extend mirrors that can connect on the Q5
thank you
waninae39 is offline   Reply With Quote
Old 02-23-2017, 07:51 PM   #2
BoscoMN's Avatar
2015 19' Flying Cloud
2017 25' Flying Cloud
Rosemount , Minnesota
Congratulations and welcome!
There are a wide variety of options. I would suggest that you first see what the car's OEM had to make sure that there is not a factory designed option. If not, here are a few options:
https://hensleymfg.com/products/mckesh-mirrors/
http://www.cipausa.com/
And of course do some searches on this forum. Here is one:
http://www.airforums.com/forums/f238...rs-160942.html
I am using these until I get my three camera system installed onto our Airstream:
CIPA 11980 Universal Bar Towing Mirror Kit
They work ok, no real complaints.
2018 F-250 6.2L Gas
Blue Ox SwayPro 1000#
BoscoMN is offline   Reply With Quote
Old 02-23-2017, 09:35 PM   #3
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Bosco is spot on. OEM is best. Mckesch mirrors are a good set to consider. The Aero 2s are also a usable solution. Try what looks effective to you and do not be concerned if you need something different. You must be comfortable with your mirrors.
Hope to see you down the road. The 22 is a great coach. Should get you lots of smiles. Pat
Old 02-23-2017, 10:25 PM   #4
waninae39's Avatar
2017 22' Sport
NCR , Ontario
state mirror towing laws
state mirror laws
Old 02-24-2017, 11:42 AM   #5
1996 25' Excella
Tillsonburg , Ontario
Neat Trick to see what is behind you, using the technique truckers use by offsetting their trailer wheels to improve sight line along driver's side by causing the trailer to "crab" along behind.
Mirrors only show so much!
I pull over to the right of the lane and then ease left to the center line. While the vehicle is tracking left there is greater visibility behind the trailer through the drivers mirror(s). My '96 does not let me see headlights through the rear window due to the rock guard. My '89 had a fairly good sight-line through the trailer to see what was following me.
JCW
JCWDCW is offline   Reply With Quote
Old 02-24-2017, 11:58 AM   #6
Sonoma Co. , California
California requires a view to 200 ft behind the trailer, which I believe is standard in most states. So latch the bathroom door open and pull the curtains. You can see straight thru the trailer to what is directly behind it from the TV's center mirror. The TV's side mirrors will pick up whatever is in the lane to your left or right, allowing for the inevitable blind spot, of course. The CHP seems fine with this technique. I've never been stopped.
USAtraveler is offline   Reply With Quote
Old 02-24-2017, 12:37 PM   #7
Vashon , Washington
We have a 23FB and 2014 Tundra TV. You can't beat OEM factory extending mirrors. An expensive add-on but every time we hook up the trailer ... love those factory extending mirrors! Pull 'em out and good to go.
guillaume is offline   Reply With Quote
Old 02-24-2017, 01:09 PM   #8
2005 28' Safari
Saint Joseph , Michigan
agree w OEM extended mirrors
We have a Ford F150 (used by 75% of AS owners, I'm told) and also love the Ford extended mirrors, assume almost every brand has something that will utilize the built in mirror controls.. the way to go..
TruckerFritz is offline   Reply With Quote
Old 02-24-2017, 01:19 PM   #9
Mollysdad's Avatar
Does the Q5 offer tow mirrors?
If not check Amazon, there's a lot of aftermarket clip on mirrors.
My experience is they vibrate a lot, and you end up using your car mirrors if the person is far enough behind you.
However, the beauty of tow mirrors is to see something in your blind spot. I have a blind spot I could hide a semi in.
They're not that expensive and a cheap addition.
BTW remove them when you arrive, narrow roads make them subject to being hit.
Old 02-24-2017, 01:59 PM   #10
2011 23' FB Flying Cloud
Augusta , Kansas
The Milenco mirrors work fine for us.
submirj is offline   Reply With Quote
Old 02-24-2017, 02:42 PM   #11
banderabob's Avatar
2008 19' Bambi
2012 23' Flying Cloud
Bandera , Texas
Huh. I guess on my next trip in CA, I need to remove the cardboard from the rear window, which is there to block ambient and other obtrusive light during sleep-time.
banderabob is offline   Reply With Quote
Old 02-24-2017, 04:56 PM   #12
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Get a rearview camera. No blind spots, period.
2019 Ford Expedition Platinum
Old 02-24-2017, 05:12 PM   #13
2016 22' Sport
Lecanto , Florida
Tow mirrors
We also have a sport 22 fb and tow with a toyota highlander which is narrower than the airstream. Our dealer recommended and we have Dometic mirrors by Milenco. These clamp on to our TV mirror frame and work well with very little vibration and good rear visability.
WDEL is offline   Reply With Quote
Tow Mirrors for Painted Stock Ford F150 Lariat Rear View Mirrors Vinster Towing, Tow Vehicles & Hitches 16 02-08-2017 04:47 AM
McKesh Towing Mirrors with Convex Spotting Mirrors SilverCabin Airstream Classifieds 1 01-20-2015 06:54 PM
Mirrors for 8' wide FCFB23 Matt Kline Tow Vehicles 7 05-05-2010 03:15 PM
How to extend the waste valve hookup tincuplady Waste Systems, Tanks & Totes 3 05-23-2008 12:39 PM
Extend Ladders Davydd Our Community 3 02-15-2004 12:16 PM
