Join Airstream Forums Today
Old 01-30-2012, 09:40 AM   #1
Rbphoto's Avatar
2011 27 FB International
La Quinta , California
Equalizer hitch stress
I'm in a 27FB and am wondering if I'm backing over a 8" curb 1 wheel at a time is it better to disconnect the equalizer hitch to reduce the torque stress to the frame.
Rbphoto is offline   Reply With Quote
Old 01-30-2012, 10:16 AM   #2
Sphere Guy's Avatar
2008 23' Safari FB SE
Tomball , Texas
Rbphoto, I have a 2008 23 Safari and After hearing all the groans and grunts while backing over a curb and up a slight grade at my home, I now, always line up, then remove me Equalizer bars, then back into the driveway.
I think there is undue stress applied to the A-Frame and TV hitch.
Thankfully, not rivets have poped.
Sphere Guy
AIR 50601
Sphere Guy is offline   Reply With Quote
Old 01-30-2012, 10:54 AM   #3
Remove the bars.
Then, add a small ramp next to the curb, so that you minimize the stresses.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 01-31-2012, 07:44 AM   #4
redwoodguy's Avatar
2012 25' Flying Cloud
Eureka , California
I can just imagine the SOUND that must make! :-)
redwoodguy is offline   Reply With Quote
Old 01-31-2012, 08:30 AM   #5
JBinKC's Avatar
2007 31' Classic
Kansas City , Missouri
You'll bend the L-brackets when you turn too tightly, I've found out. The Windish RV service manager told me to take off the bars when making aggressive turns during parking.
JBinKC is offline   Reply With Quote
Old 01-31-2012, 08:56 AM   #6
StreamRollin's Avatar
1999 25' Safari
Denver , Colorado
Images: 14
What about the sway bar control? Should that be removed also?
WBCCI #2601 Den-CO Unit
AIR # 56543 TAC# CO-10
StreamRollin is offline   Reply With Quote
Old 01-31-2012, 11:30 AM   #7
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
Images: 13
I remove mine at the same time I remove the bars. I figure sway is not an issue by this time.
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with three two dogs)
kevin242 is offline   Reply With Quote
Old 01-31-2012, 12:18 PM   #8
CrawfordGene's Avatar
2008 25' Safari FB SE
Crawford , Colorado
Backing over an 8" curb sounds like a really bad idea without or with the bars. Like Andy wrote, use ramps to reduce stresses on the trailer. If you don't have ramps, scrap wood piled up may help, though it may collapse as you back up. Make sure you don't hit anything underneath the trailer as you climb that curb.
Gene
CrawfordGene is offline   Reply With Quote
Old 01-31-2012, 03:50 PM   #9
Vintage Kin
REDNAX's Avatar
Corpus Christi , Texas
Ramps from pressure-treat wood, sand-bags, etc, all sorts of "easy" solutions are possible.
2004.0 DODGE 2500 QC/LB Cummins 305/555; 6-manual, 7,400-lbs; fuel cost is 25-cpm towing 34' trailer; 15-cpm solo.
Sold: 1983 Silver Streak 3411 Supreme; 6,860# (8,000 GVWR) Currently: 1976 32' SS
Photos prior to sale
REDNAX is offline   Reply With Quote
Old 01-31-2012, 04:36 PM   #10
JimGolden's Avatar
1987 34' Limited
My Eq Procedure
With mine, I run the jack way out, raising the tongue up high to offload the stress on the bars.
Then I pull the bars out of the L-brackets and swing them up parallel to the truck bumper so they won't strike the trailer no matter how sharply I turn while backing up. Then lower the trailer back down and retract the jack up and away.
Now I'm on just the ball and can jack knife it to my heart's content
You don't need the weight distribution or the antisway when you're in your driveway. Just run her on the ball and that way you don't overstress your A-frame.
- Jim
JimGolden is offline   Reply With Quote
Old 02-23-2012, 06:05 PM   #11
mefly2's Avatar
2012 20' Flying Cloud
Msla , Big Sky Country
That is how we do it as well ... but had to figure it our trial and error ... why didn't I read it here first !!!
~ mefly2 ~
Terminal aluminitis * 2; a very chronic disase ! Luckily, WIFE is a nurse!
US & Mexican made Crew Cab Diesel
*Helping "grow" the US economy
--->> one peso or yuan at a time.
Old 02-23-2012, 07:22 PM   #12
Splitrock's Avatar
1976 31' Sovereign
Sioux Falls , South Dakota
I've heard that backing over a curb is a quick way to remove leveling jacks, gas lines, and certain sections of the belly pan.
http://img.photobucket.com/albums/v1...g?t=1278182564
Hitch advice - Safari Sport 22 nesvt Hitches, Couplers & Balls 17 12-16-2011 04:50 PM
Hitch age? Skater Hitches, Couplers & Balls 18 09-03-2011 01:12 PM
Tundra w/ Equalizer Hitch Booger12 Hitches, Couplers & Balls 11 03-01-2011 11:42 AM
Hitch height Khulse Hitches, Couplers & Balls 1 02-26-2011 04:19 PM
Equalizer hitch benefits Moonstruck Hitches, Couplers & Balls 34 01-19-2011 08:03 AM
