08-25-2017, 08:53 AM
#41
Tampa
Originally Posted by franklyfrank
I could be wrong but I don't believe that any of those short stiff trunion bars have any flex.
If that were true, then why does Equal-I-Zer include the pry bar to put the bars on the pads?
In my hands a car's coil spring or leaf springs don't flex either. But in practice, they do.
Since I don't have one's to compare, do the different bars interchange? My 1000# bars are square, the socket's are square, the lighter bars are thinner. Don't you need to swap out the entire hitch?
Or at least the sockets on the head?
08-25-2017, 09:07 AM
#42
Full time Airstreamer
2014 30' FB FC Bunk
Anywhere
, USA Living.Somewhere.Yonder
I believe you have to swap out the head. I did going from 600# to 1000#.
@living.somewhere.yonder | Instagram
08-25-2017, 09:40 AM
#43
Spokane
MStephens, my advice to you is to not get an Equalizer for your new trailer but only because you have doubts and doubts can follow you anywhere you go.
I also believe that your hitch was not properly set up. I have a 25FB that I tow with a half ton. 40K miles on the combination without any big issues. Early on I did have some popped rivets and an open door now and then but that was due to the GM tires that came with the trailer. Got a new set and had them balanced and bingo, no more issues.
The ease of hooking and unhooking is a big advantage of my hitch. If you couldn't get the bars to sit on the brackets then something was wrong with the setup.
Good luck with your next trailer/hitch. There are lots to choose from.
08-25-2017, 04:46 PM
#44
2013 25' Flying Cloud
Cat City
Hi
Yes, you could use the pry bar gizmo .... how many do? Hands please ? ... hmmm.... that's what I though.
The pry bar option was not even possible. The bars hung down well below the angle at which you could attach the pry bar, and/or, the amount of brute strength needed to pry up the bar was way, waaaaay beyond my strength.
Yes, I am quite sure in retrospect that something was deadly wrong even though the combo rode almost level with the TV rear down about 1".
Typically, using the tongue jack, I had to raise the back of the burb to positively scary heights to swing the bar up onto the L-bracket. Anything less, and I tried many adjustments, led to a sagging rear end.
Anyway, that was ancient history. I'm hoping to find a hitch that is easy, clean, and effective if we get a new rig.
08-26-2017, 06:55 AM
#45
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
The number of washers in the top bolt on the hitch controls the angle of the bars. If the angle gets crazy, you go to bigger bars or do less WD. My guess is that you had to many washers in and a lot of the weight was pushed to the front axle.
Again, I'm in no way trying to sell anybody on these hitches. They do indeed have some issues. I'm just trying to help sort out what's what in terms of how they do (or don't) work.
08-26-2017, 08:16 AM
#46
Tampa
If I was starting over, I'd look into the Reese steadi flex.
All the good of the Equalizer without the questionable.
It looks like several hitch makers are jumping on the Equal-I-zer bandwagon.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Installing a 12,000 lb. Equalizer hitch
Alphonse |
Hitches, Couplers & Balls |
7 |
11-06-2021 11:14 AM |
Resurrecting Big Bertha... or, 'How I spent $30,000 on a $2,000 trailer...'
Panama Red |
1974 - 1979 Sovereign |
251 |
02-10-2015 07:08 PM |
HOT IN TEXAS!!!! Upgrade a 13,000 BTU to a 15,000 BTU? Does it help?
bowhead13 |
Furnaces, Heaters, Fireplaces & Air Conditioning |
47 |
07-19-2013 12:02 PM |
28,000 or 128,000 miles?
jimelmoreiii |
Mechanics Corner - Engines, Transmission & More... |
8 |
01-11-2004 07:16 AM |
