Old 06-15-2015, 09:33 PM   #1
1973 23' Safari
Sacramento , California
Equal-i-zur noise
We have a 2002 Tundra pulling a 1973 23' AS Safari. Have noticed when we were just up to a site; while backing in, we had a lot of "screeching moaning noise". when we left a few days later I did not hook up the sway bars and did not have the problem. Called the company and they said to use a grease compound on the head. Anybody have any other ideas?
Thank you,
Carl
kaminski73 is offline   Reply With Quote
Old 06-15-2015, 09:49 PM   #2
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
http://
Equal-i-zer 95015150 Spring Arm
Not sure if this link will work but just go to Amazon and search for the above. Takes much of the noise out of the equalizer and of course grease in the appropriate places helps.
TinCan
graysailor is offline   Reply With Quote
Old 06-15-2015, 10:55 PM   #3
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
When you reverse you need to detach the bars first...
http://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowbaording habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 06-15-2015, 11:41 PM   #4
2015 16' Sport
Portland , Oregon
I called the company and they said you do not need to detach them when backing unless the L brackets are very close to the ends, like more than 29" from the head.
leedav is offline   Reply With Quote
Old 06-15-2015, 11:42 PM   #5
2015 16' Sport
Portland , Oregon
Meaning more than 29" of bar between the head and the L brackets.
Old 06-15-2015, 11:52 PM   #6
Gsmblue's Avatar
Bend , Oregon
Awesome! Thanks!
I assume if you are cutting tight turns you should detach still, does that sound reasonable?
When we pull into a camp site, the wife checks us in and I take the bars off, it is a system that works for us and it means we do not creak and groan all around the camp site!
Old 06-15-2015, 11:52 PM   #7
2015 16' Sport
Portland , Oregon
Sure. Can't hurt. Just sometimes a PITA
Old 06-16-2015, 08:44 AM   #8
mefly2's Avatar
2015 25' FB Eddie Bauer
Try the EQ bracket jackets ...
Old 06-16-2015, 12:40 PM   #9
runnersg's Avatar
2016 27' Eddie Bauer
TX , Texas
Is taking off the bars during back up recommended or just suggested? I've backed in four times now with my trailer and the bars were on. While it sounds like zombies coming out of the grave, there didn't seem to be any problem. Am i risking damage of some kind?
2016 Eddie Bauer 27'
runnersg is offline   Reply With Quote
Old 06-16-2015, 06:53 PM   #10
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Equal-i-zur noise
On a properly installed Equal-I-zer brand hitch you do not have to pull the bars for any type of backing, no matter the angle. I've had the tow vehicle almost perpendicular to the trailer and the bars are just fine. Yes they squeak and groan but that's their nature. As mefly2 noted they have jackets available to minimize noise. Be careful as to what you lube since the Equal-I-zer is a friction based hitch. Lube incorrectly and you reduce your sway control.
Jack
Jack Canavera
STL Mo.
AIR #56
Motor noise vs fan noise vs overdrive question SebasSF Mechanics Corner - Engines, Transmission & More... 25 12-15-2013 11:18 AM
Equal-i-zer hitch Ed & Nancy Our Community 12 03-23-2003 10:58 AM
Equal-i-zer or Reese Dual Cam Sway Control? VWMARTINEZ Hitches, Couplers & Balls 19 03-19-2003 06:17 AM
Equal-i-zer Hitch dmac Hitches, Couplers & Balls 6 01-23-2003 07:14 AM
Safari and Equal-i-zer Hitch dmac 2001 Safari 8 01-15-2003 07:01 PM
