Old 09-24-2012, 12:00 AM   #15
mefly2's Avatar
2015 25' FB Eddie Bauer
Originally Posted by ROBERTSUNRUS View Post
Hi, if you are referring to the top and bottom limits of the tongue jack, there are limiter switches to prevent power to the motor, and the fuse will not blow. My down limit was incorrectly adjusted [by me] and it blew the fuse when hitting the bottom. I corrected this.
Not sure about limiter switches on my 2012 tongue jack - fuses blown by both the service fellows when putting AS into storage and by me at home ... both at the top of the range as well as the bottom of the jack range. Can you refer me to the proper adjustment procedure, please. YMMV
Old 09-24-2012, 12:11 AM   #16
2005 19' Safari
GLENDALE , AZ
We have an Attwood electric tongue jack that ratchets at the upper and lower limits to protect the motor and gears, and we have never blown a fuse. However, the noise is very annoying; so we took a permanent marker and put a ring around the shaft where the ratcheting occurs, so we can slow down as the limits are approached.
Old 09-24-2012, 12:44 AM   #17
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, your tongue jack may be different. My motor housing has the limiter switches inside of it. The tongue jack must be timed. Remove the head and ground it to the tube. Run the jack motor in the down position until it stops. The limiter switch will stop it. Crank the jack by hand until it hits the bottom. Crank it back up, a few turns. Align shaft to motor assembly and re-install motor. Mine was hitting the bottom before the limiter switch came on and was blowing fuses everytime I bottomed it out. So I had to properly time the motor. See last paragraph.
Name:	Barker instructions.jpg
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 10-02-2012, 03:30 PM   #18
mefly2's Avatar
Many thanks!
Old 11-06-2012, 04:42 PM   #19
1969 23' Safari
Athens , Georgia
I'm a newbie and need some translation from your post I have a 1969 Safari, towed by a GMC 1500 Sierra. We have a very painted over hitch "lock" (?) and are having difficulty raising and lowering the hitch. I don't want to high jack this thread, but we are frustrated over lifting the truck to get the ball off. What is a WD?? Thanks!
sarasafari is offline   Reply With Quote
Old 11-06-2012, 07:31 PM   #20
1957 26' Overlander
1989 35' Land Yacht
Oakdale , California
Weight distribution hitch
Tmck is offline   Reply With Quote
Old 11-07-2012, 10:00 AM   #21
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Originally Posted by Goal15 View Post
Somewhere on here of a thread about hitching up without jacking up the TV
Our first AS had a manual jack.
I used to set the bars before hitching up. Carefully lining up the ball under the tongue, drop and lock.
With the Classic I've abandoned the procedure, using the electric tongue jack, with no problems.
