Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 08-02-2005, 09:46 PM   #29
2airishuman
2airishuman's Avatar
Profile:
if you are planning to purchase the nk rock tamers......don't wait.
i was somewhat hesitant until i saw silvertinkies upclose and realized how well made and 'airstream worthy' they were....by then i had 6-8 weeks of travel on the new trailer and 10-15 dings in the new higher stainless guards.....these didn't happen during travel on gravel, but rather from travel at highway speeds when gravel is propelled out of the tire treads.....many days/weeks after imbedding the gravel in the tires.
i had hensley ship me the lengthed shank setup so no mod of the brass nk was required.
as good at the nk's are, there is still a gap above them on the higher 4x4s (like the ford 250/350) so i also installed wheel well mud flaps for more complete protection.....after the horse was out of the barn.
so just don't wait for 6 weeks BEFORE deciding to add the flaps.....
cheers
2air'
Old 08-08-2005, 09:55 AM   #30
vajeep
vajeep's Avatar
Profile:  1976 27' Overlander
Richmond , Virginia
Images: 49
Just got the Enkay
Just got our Enkay rock tamers this weekend.
I hope to put them on this week. I checked and my Enkay will fit (snugly) on my Hensley stinger.
Any mounting hints??
"Abe" & Melissa Lincoln
1976 Overlander "Spirit"
2005 Suburban w/q-steer
Hensley Hitch
WBCCI# 7627 / VAC
Air #2798
vajeep is offline   Reply With Quote
Old 08-08-2005, 10:02 AM   #31
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
I noticed that there is corrosion from the differing metals where the rod holding the flap goes into the hub unit. It is easy to clean up but was wondering if there was something out there to keep this from occuring?
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 08-08-2005, 10:44 AM   #32
Tin Hut
Tin Hut's Avatar
Profile:  2005 28' International CCD
Southlake , Texas
holes
When I used the hole "punch" they supplied in my drill it was still very difficult to get it to cut the tough rubber. I took a screw driver, stuck it in the tip of the hole cutter to nick and rough up the edge of the cutter so it was burred. That seemed to do the trick and I was able to cut the holes quickly. I did have to keep burring the cutter though. I also had mine shaved at a fabricator to fit on the Hensley.
"would you rather have a mansion full of money or a trailer full of love?"
Warning: (20%)
Tin Hut is offline   Reply With Quote
Old 08-08-2005, 11:06 AM   #33
Sonia
Sonia's Avatar
Profile:
Thanks to all of you that replied and posted pictures of your mudflaps and the modifications made to fit the hub. We received ours last Thursday and got them milled just enough to fit the Hensley. We were in Hershey, PA this weekend and they worked great parking on the gravel site.
Now we are waiting for the SmarTires to arrive...that should be fun to do.
Sonia
Sonia is offline   Reply With Quote
Old 08-08-2005, 05:59 PM   #34
davidz71
davidz71's Avatar
Glad you are happy with them Sonia.
Craig
AIR #0078
3.73 rear end
Old 09-02-2005, 11:31 AM   #35
vajeep
vajeep's Avatar
Richmond , Virginia
Images: 49
Emergency brake cable
How do you all route the electrical and the emergency brake cable?
I have had the e-brake pull out when I was turning...
I would be interested in how you all routed around the Rock tamers and left enough slack for the Hensley but kept the electrical cord out of the way.
I am thinking some "bungie" cord , but would like to see how you all have solved this challange.
Thanks!
Hensley Hitch
WBCCI# 7627 / VAC
Air #2798
Old 09-02-2005, 12:23 PM   #36
aluminauts
aluminauts's Avatar
Profile:  2003 34' Classic
vancouver , Washington
for my set up
I have “threaded” the emergency cable thru a loose wire tie loop that is around receiver tube where the Hensley draw bar enters it. The end of the cable is hooked to wire loop that goes behind the license plate and then to a connection on my frame, not the hitch receiver.
As the cable leaves the E switch, I also guide it straight toward the tow vehicle by having the cable guided by about 3 inches of tygon tubing that passes over the middle of the trailer ball lock down.
This seems to center the movement of the cable away from the hensley and thru the rock tamer area.
Hope your E cable experience didn’t do too much to your nerves or rig.
Aluminauts
2003 34' Airstream Classic
2007 Chevy Silverado 2500HD
Allison Duramax 4X4
Hensley Arrow hitch
Kodiak / Actibrake Disc Brakes
Tekonsha Prodigy brake controller
Doran Pressure Pro
WBCCI #2984 Air # 4173
aluminauts is offline   Reply With Quote
Old 09-06-2005, 04:59 PM   #37
davidz71
davidz71's Avatar
I run the cable alongside the right hand side of the license plate on my 2500hd and the bumper. It then runs straight down and the loop on the end is secured to the hook/link at the end of the chain. The mudflaps are out enough so that they do not interfere with the main electrical cable to the trailer.
Craig
AIR #0078
3.73 rear end
Hensley and Rock Tamer davidz71 Hitches 12 03-31-2005 08:55 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
