Old 04-03-2015, 02:35 PM   #1
Grand Rapids , Michigan
Emergency tow for trailer
I watched an flatbed tow truck operator load and unload a disabled 18' trailer. The trailer was too long for the steep angles of the tilt-bed truck and the trailer dragged at the back while being winched up. Not good.
So what's the right way to tow a disabled trailer (say a burned bearing) to a repair shop?
Aren't there dollies a wrecker can put under a bad wheel and tow the trailer via the hitch?
crampshaw is offline   Reply With Quote
Old 04-03-2015, 03:30 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
If it is a tandem axle trailer with torsion axles, you can remove one wheel and tow on three wheels for some distance at a reduced speed.
Bill
Just my personal opinion
Old 04-03-2015, 05:00 PM   #3
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
They could have used a lower angle low boy trailer and winched it up or maybe gotten away with some wood blocks to raise the trailer as it's being winched. They certainly should have been prepared to avoid the tail end dragging. Some towing people have and use dollys but they are a pain to use and not so commonly available as they used to be. Can't say I've ever seen them used for a trailer but they might work.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Clipper, Emergency Exit, Land Yacht, Emergency Ladder masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 9 03-05-2015 10:34 PM
Emergency lights on your A/S trailer with no tow vehicle safari57 Lights - Interior & Exterior 10 11-19-2014 05:18 PM
Emergency trailer flasher/locater Viper2 On The Road... 5 10-28-2010 01:56 PM
Emergency Trailer Brake Quit Working AustinAir Brakes & Brake Controllers 3 01-17-2009 08:23 AM
Emergency RV Tow Service Safari-Rick Off Topic Forum 1 03-23-2006 09:31 AM
