Old 11-25-2015, 09:59 AM   #1
falls Church , Virginia
Electronic anti-sway system
Hello,
New to this forum.
I am a relative novice to towing.
Currently have a Husky Centerline WD with anti-sway and am not very satisfied with performance.
There a couple of very new products on the market that are essentially retrofit kits that add electronic stability control for trailers. They are Dexter Sway Control and the Direct Link/Tucson electronic sway control. These system propose a whole new way to control sway by differentially braking the left or right tires with very short brake pulses based on yaw rate changes sensed on the trailer frame. You would of course still need weight distribution. This seems like a great idea...but does it work?
Does anyone have any experience with these?
Schmeeze
Schmeeze is offline   Reply With Quote
Old 11-26-2015, 07:54 AM   #2
Livingston , Texas
I don't have any experience with an electronic sway control system for trailers, but I believe they certainly are worthy of consideration.
Lippert also now is producing the Sway Command Tow Control which is being offered as an option on all Jayco trailers.
Ron
Ron Gratz is offline   Reply With Quote
Old 11-28-2015, 07:58 PM   #3
Vintage Kin
Fort Worth , Texas
Good write ups at MR TRUCK and in older threads here on TUSON (search). See Andrew_T comments (expert opinion).
Old 11-29-2015, 05:12 AM   #4
andreasduess's Avatar
1984 34' International
Toronto , Ontario
If you wish to eliminate sway, I recommend a Hensley (or similar) hitch. No sway, ever, under any circumstances.
andreasduess is offline   Reply With Quote
Old 11-29-2015, 05:20 AM   #5
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Schmeeze,
Welcome to Airforums lots of experience, information and of course opinions abound. Hitches are agruably topic #1.
If you could it would help if you told us what your tow vehicle and trailers details are, and just as a curiosity, what is the issue with the Husky Centerline.
And pic's help alot.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Noisy Anti-Sway System jherhusky Hitches, Couplers & Balls 26 07-17-2015 06:03 AM
Turn off electronic sway control with Propride? Wanna EB Hitches, Couplers & Balls 7 01-06-2014 10:31 AM
