Old 10-01-2016, 12:24 PM   #1
Camano Islander
2007 19' Bambi
1965 17' Caravel
Iowa City , Iowa
Electric Jack Bent?
I was towing a short distance and I accidentally put a receiver on my truck with the wrong size ball. The trailer hopped off the hitch and was dragged along the road. Now the electric jack sounds like it's straining and I think it could be bent. I called my local Airstream dealer and they said it has to be replaced, can't straighten it.
Has anyone had a problem with a bent jack and did it require total replacement?
CamanoIsland is offline   Reply With Quote
Old 10-02-2016, 06:00 PM   #2
Sioux Falls , South Dakota
I would think that if there was sufficient force to bend the jack you would want to replace it. Even if, by some chance, you could get the post perfectly straight, what damage have you done to the motor from the shock of impact or trying to move that bent post? I suspect that you will have to replace it sooner or later anyway, so why fight it now? Also, might it be covered by insurance? The longer after the incident you wait the harder it will be to successfully file a claim.
David Lininger, kb0zke
TAC SD-6
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (for sale)
kb0zke is offline   Reply With Quote
Old 10-02-2016, 06:31 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Three bolts, one wire. Very easy DIY project.
MICHAEL
Old 10-02-2016, 07:20 PM   #4
2016 25' Flying Cloud
Holly Springs , Mississippi
Replace it. Keep the old jack for parts. Problem solved.
This may be a good opportunity to upgrade the size of the jack (e.g., from 3000 lbs to 3500 lbs.) if the current one made any sounds like it was straining, pre-drag event.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 10-06-2016, 09:12 PM   #5
steverino's Avatar
2010 27' FB Flying Cloud
Ivins , Utah
When I accidentally bent the jack, I was able to procure a replacement post from the manufacturer, Barker. About $100, as I recall...
steverino is offline   Reply With Quote
Old 10-06-2016, 09:53 PM   #6
2006 19' Safari SE
Hayes , Virginia
Bent/broken Jack Shaft
Mine bent. Upgraded to the 3500, easy installation, reasonably priced, and piece of mind. No regrets replacing.
mocus is offline   Reply With Quote
Atwood LP/Electric Water Heater Problems (Electric Has Failed) gquake Water Heaters, Filters & Pumps 10 06-29-2014 04:02 PM
Bent Stabilizer Jack - Need Replacement dbj216 General Repair Forum 4 01-19-2013 09:23 AM
Did something dumb...bent the electric jack! Skater Jacks, Stabilizers, Lifting and Leveling 8 08-12-2011 01:41 PM
For electric for genration hase to be oun for electric RichardT Electrical - Systems, Generators, Batteries & Solar 7 12-05-2005 09:05 PM
Electric or Gas electric fridge replacement?? tin can luv Refrigerators 26 03-22-2004 10:50 AM
