Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 03-23-2006, 01:57 PM   #1
Profile:  1979 31' Excella 500
Detroit Area , Michigan
Images: 41
Electric connections
Will and 1979 31' Airstream connect directly to a modern 7 pin electrical receiver such as the one that is equipted on my 2003 Expedition? Do I need an adapter to go in between the two?
wacnstac is offline   Reply With Quote
Old 03-23-2006, 02:10 PM   #2
wkerfoot's Avatar
Profile:  1979 23' Safari
1954 29' Liner
Orange , California
Wacnstac,
I assume that the 1979 Airstream has the round pin plug, if so just replace it with the spade plug which is used now. You may have to move the wires around because I believe that the locations on the plug are different now than in 1979. The Airstream corporate site has a list of old wiring diagrams or use a tester to determine which wire does what.
Good luck,
Bill
Just my personal opinion
1973 Dodge W200 PowerWagon, 1977 Lincoln Continental
wkerfoot is online now   Reply With Quote
Old 03-23-2006, 08:06 PM   #3
Images: 41
Hmm, is there an adapter to go from one to the other?
Old 03-23-2006, 08:09 PM   #4
overlander63's Avatar
Profile:  1974 31' Sovereign
On The Road , Fulltiming
Images: 52
Not that I have seen. It really isn't that hard, I have done it on many coaches over the years.
You repair things with tools. You fix things with a hammer.
AIR#2611
overlander63 is online now   Reply With Quote
Old 03-24-2006, 11:34 AM   #5
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 36
Yes, I have one for my boat trailer, it has the smaller round connector. Bought it at one of the auto parts stores (Pep Boys, Auto Zone or Checker Auto). I think it cost around $10.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 03-24-2006, 02:28 PM   #6
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 104
Greetings wacnstac!
Based on my experiences first with the Overaldner and then win the Minuet, my suggestion would be to obtain a trailer connector end that mates to your tow vehicle and plan on wiring in a new connector. Between age and corrosion the Bargman connectors on both of my coaches needed attention prior to towing home -- not to mention that neither was wired to anything approaching today's Industry Standard for the Bargman connectors.
I did, however, find that the diagrams posted on the Airstream website were quite helpful (the color codes matched those found on my coaches). You can find the diagram for the '79 models at:
http://www.airstream.com/airstream/p...lug1966-81.pdf
Good luck with your coach!
Kevin
Kevin D. Allen
AIR #827
overlander64 is online now   Reply With Quote
Old 03-24-2006, 07:59 PM   #7
Images: 52
Richard, was this an adapter from the 7 round pin to the 7 flat pin? Or was it the 7 flat pin to the 4 round pin flat connector? If it was the first one, I need to go over and pick one up, as it will save me a lot of time towing these old coaches around.
AIR#2611
Old 03-24-2006, 08:25 PM   #8
Phoenix , Arizona
Images: 36
The round side (male) has 6 pins and so does the flat side (female), the middle (backup lights) has no connector. I shot 2 pictures of it.....
ID:	19818  Click image for larger version
Richard
Pingbacks are On
voltage for electric jack maznblu Towing, Tow Vehicles & Hitches 3 04-16-2004 08:32 PM
Electric meter dienst1 Airstream Motorhome Forums 4 10-20-2002 09:17 PM
removing electric jack CHRIS CANNON Our Community 0 09-30-2002 06:51 PM
Electric hook up Dbraw Electrical - Systems, Generators, Batteries & Solar 2 07-07-2002 12:56 PM
Electric Brake Controller Problem Don Brakes & Brake Controllers 4 04-15-2002 01:05 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
