Old 05-23-2019, 01:54 PM   #1
Electric Brakes (2002 C25ft lassic) Testing
Ok, just purchased a 2002 25ft Classic. Would like to check if the brakes work reasonably well. TV is a 7.3 liter Ford f250 with a 5001 Draw Tite electric brake controller. Felt some pulls from the AS brakes driving it back from Tenn to Ga. Should I removed the wheels and check the magnet and state of the drum pads? Thanks in advance!
umasslax is offline   Reply With Quote
Old 05-23-2019, 01:58 PM   #2
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Yes you should. Unless you know when last service you will need to pull the wheels and inspect the brakes and bearings ( that is if you have serviceable bearings). If you know how to re-pack them get some grease and a new set of seals and go for it.
These are just things that need to be done.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Simple instructions for testing brakes? lbdesign Brakes & Brake Controllers 21 12-13-2012 10:24 AM
BRAKES, BRAKES and more BRAKES Inland RV Center, In Commercial Listings 7 11-17-2009 05:56 PM
testing the elec brakes? Rog0525 Brakes & Brake Controllers 3 06-11-2002 03:02 PM
