Old 08-21-2013, 05:36 PM   #1
2012 25' FB Eddie Bauer
atlantic beach , Florida
Images: 8
Electric brake warning message
2012 EDDIE BAUER WITH 2011 CHEVY SUBURBAN
The integrated brake controller reports messages to "check trailer brake system". We had the brakes serviced. No problem with EB brakes.
We are still getting the message on the Chevy console. Any suggestions?
Thanks.
Missy Grace is offline   Reply With Quote
Old 08-21-2013, 05:41 PM   #2
2007 22' International CCD
Verify SOLID connections and grounding...
rmkrum is online now   Reply With Quote
Old 08-21-2013, 06:54 PM   #3
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
The GM integrated brake system is looking for a low-resistance, high-current path to ground through the magnets in the electric brakes. Since the EB is a single-axle trailer, it will not take much of a poor connection to make the controller see too high a resistance. This is less likely on a tandem trailer with 4 magnets in parallel.
As mentioned above, really check the ground and brake pins in the umbilical. They are the two pins exactly opposite the raised key slot on the plug.
I have heard of cases with single axles where an additional dummy resistor needed to be added at the trailer end to insure that the accumulated resistance is low enough to satisfy the integrated controller.
John W. Irwin
WBCCI #9632
Pahaska is online now   Reply With Quote
Old 08-21-2013, 07:31 PM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Also, check battery connections in AS for looseness as well as the box where umbilical connects all the wires to trailer. Could be loose in there too.
One other item might be a problem inside vehicle 7way. Check it is ok along with harness connectors on GM TV.
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-21-2013, 09:13 PM   #5
1988 32' Excella
Robbinsville , New Jersey
Um, no the EBs are all tandem axle.
(I believe all EBs are 25' or 27')
It' been decades since Airstream built a 25' or larger single axle trailer. (OP's trailer is 25')
Old 08-31-2013, 10:36 AM   #6
JFScheck's Avatar
Rockville , Maryland
Images: 33
Double check your controller is in"Electric Brake" mode vice "Electric over Hydraulic".
Similar (but inverse) issue with my Prodigy 3 brake controller and my Diesel Touareg with my old 25FB trailer that had hydraulic brakes when the settings somehow got swapped on the brake controller.
John "JFScheck" Scheck
In Between Units
Airstream On Order
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 08-31-2013, 10:47 AM   #7
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
I had that problem with mine awhile back. In trying to isolate the source, whether it was truck or trailer, I hooked the trailer up to a buddies truck. Same problem. Took the trailer into the dealer and they were able to isolate two electrical shorts in the trailer brake wiring.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
