Old 08-09-2015, 10:05 PM   #1
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
EAZ-Lift: Need more links over time?
I have an EAZ-Lift Elite hitch. The dealer who set it up told me that over time I would need to shorten the length of chain under tension. He gave me some 1/2 inch bolts to use at first: Putting a bolt between two links shortens the chain by a half an inch. Over about 10,000 miles, we have shortened the chain several times. (yes, we do this after weighing at a truck scale, to make sure we are getting the weight distribution we want/need)
We are now running with one extra link hanging free, and two bolts in the chain. That's 2 1/2 inches shorter than original. And it's starting to feel like I need to go shorter again.
Is this normal? Where does it stop? Should I be adjusting the tilt of the head? (the head is tilted quite a bit; I don't know if there is any more room for adjustment there).
I have inspected the chain links themselves to make sure the links are not wearing through. They look OK to me.
SSquared is online now   Reply With Quote
Old 08-09-2015, 11:22 PM   #2
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
I wouldn't want to give you advice because I don't know enough about these things. However, I'll just relate my experience with EAZ-Lift.
In the first year of towing, I added two bolts to the chains. There has to be some added flex with time and that's to be expected, and, at the end of my second season, I dropped the bolts and moved up a whole link. That was fine until a little way into the fourth year when things started to get a bit saggy again. Investigation revealed that the hitch receiver box was getting deformed and allowing just a fraction too much upwards movement of the hitch head. My dealer welded a small wedge on the shank to take up the slack a bit and everything seemed fine, although I'm still one chain link up on the original setting. I did notice that the washers on the U-shaped hasps at the end of the bars were also getting a bit deformed with wear and that would certainly account for some of the slack that needed to be dealt with by tightening up the chains.
Over the winter I'm going to get some professional advice about where to go next. A whole new EAZ-lift kit is inexpensive but I want to see what the guys with the experience have to say. I am going to get a new (and modified) hitch receiver for next year, though, as the present one is showing its frailties and suffering with our Canadian winters.
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
eaz-lift dcribbins Towing, Tow Vehicles & Hitches 2 04-15-2012 12:01 PM
EAZ-Lift WD Hitch washers, need some rbs Hitches, Couplers & Balls 2 12-14-2011 02:56 PM
eaz-lift hitch, is it all here or not? G1obetrotter Hitches, Couplers & Balls 8 07-01-2010 07:18 AM
Dear new owner of my EAZ Lift weight distribution hitch pageclot Hitches, Couplers & Balls 4 05-11-2010 08:17 AM
Eaz lift ardenrj Hitches, Couplers & Balls 2 12-30-2004 07:03 AM
