Old 11-01-2012, 10:09 PM   #1
gatewaygrip's Avatar
1963 28' Ambassador
1967 26' Overlander
St. Louis , Missouri
Drop down receiver
Looking for a 4"-6" drop down receiver, made for towing a trailer. 500tw and 5000+gtw. Any suggestions?
gatewaygrip is offline   Reply With Quote
Old 11-01-2012, 10:13 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Curt Manufacturing makes receiver hitches and ball mounts.
Just type in Curt Trailer hitch into the search engine.
Old 11-02-2012, 08:09 AM   #3
dznf0g's Avatar
Oswego , Illinois
I assume you mean a DRAWBAR which has a 4 -6" drop. Never seena a receiver which drops down.
I you're looking for a drop drawbar, Reese, Equalizer....all make them. I'd suggest an adjustable one, like one of these:
Specialty Adjustable Shanks : Equal-i-zer Hitch Store
-Rich-
Old 11-08-2012, 09:07 AM   #4
Vintage Kin
Fort Worth , Texas
Contact etrailer for all the generic stuff.
Old 11-08-2012, 10:46 AM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Nothing special about them really. Any auto parts store or Walmart should be able to fix you up.
MICHAEL
Old 11-08-2012, 01:28 PM   #6
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Are you planning on using this to tow your Airstream?
If so you ought to be considering a weight distribution hitch with sway control. The drop bar would be included with the w.d./sway control hitch as an assembly.
doug k
Old 11-08-2012, 03:54 PM   #7
urnmor's Avatar
Berlin , Maryland
I agree with Doug. If in fact you are going to tow an AS you should determine the height of what the ball should be before buying just any reciever shaft. When I bought my knew TV I found out the receiver shaft that I had was to big for my vehicle because it came to close to the pavement and when I reversed it the tailgate would hit it (not good on a new vehicle). We then tried a number of Reese's adjustable shaft before I found one that gave be the correct height of the ball.
urnmor is online now   Reply With Quote
Old 11-09-2012, 08:45 AM   #8
1963 28' Ambassador
1967 26' Overlander
Doug,
Thanks for your advise. The drop down receiver would be for an old style w.d./sway hitch design for a lower vehicle. After searching and talking to multiple people, no such thing exist. All drop downs are for towing a vehicle behind a R.V. or accessory racks. Tried to save some money!
Old 11-15-2012, 09:07 AM   #9
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***
Can you simply fit a new shank to the WD hitch that you already have?
2015 25' Eddie Bauer International Sp Ed
2019 Chev New Silverado 1500 6.2 V-8; equalizer hitch
AIR# 44105; formerly WBCCI 2015.1
Terminal Aluminitis; 2-people w/ 2-dogs
Old 04-18-2013, 04:55 PM   #10
1973 Argosy 26
Fort Payne , Alabama
We have the old style WD sway hitch that came with our Argosy, but our F150 hitch is too high. We are looking for a drop hitch shank (not a ball) for 500 lb tongue weight & at least 5,000 lb gtw also. Has anyone found one that will carry that many lbs?
bbnaugher is offline   Reply With Quote
Old 04-18-2013, 05:38 PM   #11
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
How many inches of drop do you need? Curt manufacturing makes an assortment of different ball mounts. Which is the part that slips into the 2" receiver on the TV.
Old 04-18-2013, 06:08 PM   #12
Jared129's Avatar
1976 31' Sovereign
2014 28' Flying Cloud
1992 34' Excella
. , Maine
I just had to buy a new shank that had a larger drop when switching from my half ton Dodge to the new 3/4 ton. I found one through Draw-Tite which is rated at 14,000 lbs GTW and 1400 lbs tongue weight....they have a few selections here:
http://www.draw-tite.com/content/pro...ID=1635&part=0
Jared and Heather
WBCCI # 4998
AIR # 24449
Jared129 is offline   Reply With Quote
Old 04-18-2013, 09:35 PM   #13
1973 Argosy 26
We need 2" - 4" drop. Our receiver slips in the TV with a shank with a ball on the other end with the holes for the sway bars to fit in. So a regular ball mount will not work with our WD set up. Any suggestions?
Looking for a Hi-Low Drop Hitch Adapter with 500 lbs tongue weight.
Old 04-18-2013, 11:51 PM   #14
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Can you post a pic of your previous setup? Just stick the old one in the receiver and take a couple of shots for us.
Old 04-19-2013, 07:50 AM   #15
1973 Argosy 26
I will when the storm passes, thanks for your help.
Old 04-19-2013, 09:09 AM   #16
1986 25' Sovereign
Dalton , Massachusetts
Try Blue Ox at Blue Ox - Drop Receivers
They make a drop down accessory that works well and may not require modifications to what you have. I got one on Ebay for a good price.
Regards,
David
dnmais is offline   Reply With Quote
Old 04-19-2013, 11:01 AM   #17
1973 Argosy 26
This is what we have been looking at. One place told me it would work, but another place said it was not for pulling a camper, but it was made to tow a car behind the camper with a tow bar. This is the style that we need. Just needed to verify that it will work for pulling a camper. Which one do you use, the one for 5,000 or 10,000 lbs? What is the tongue weight on these?
Old 04-19-2013, 11:16 AM   #18
1986 25' Sovereign
Dear bbnaugher,
I have used the 4" drop 5000 lb model with an 86, 25ft Sovereign. Tongue weight is around 700 lb. Worked fine for us. It is extremely robust and the welds are first rate. You may wish to use the higher rating just to have a bit of a safety factor.
Only issue is it puts the pivot point a little further behind the rear axle. This did not cause any sway issues as we were using a 3/4 ton Dodge Ram diesel with extended cab with an 8ft bed. Truck had a very long wheelbase and was extremely stable. Our electric umbilical cord was long enough as well.
Old 04-19-2013, 11:42 AM   #19
1973 Argosy 26
Thank you for the info.
Old 04-19-2013, 01:32 PM   #20
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question Is this what your looking for?
Most companies offer an adjustable stinger.
This is what I used on our 63 Safari.
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Just because you don't know how, doesn't mean you canít."
Amanamus
Sweet Streams....🌥
