Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Towing, Tow Vehicles & Hitches
Old 04-22-2006, 05:53 PM   #1
pamelake
pamelake's Avatar
Profile:  1974 25' Tradewind
Lake Oswego , Oregon
Draw-Tite/What's it gonna do for me?
Hi, I have a 25' Tradewind I am towing with a Chevy Tahoe. I also have a Draw-Tite 750 that was purchased for me by my brother last year. Could someone take the time to explain what this will do for me. Is it a for weight distribution? Anti sway? I have sifted through old threads and there isn't much about this brand. I don't take that as a good sign. Is it appropriate for my needs or should I trade it in for something else. Thanks. Pam
pamelake is offline   Reply With Quote
Old 04-22-2006, 06:32 PM   #2
AYRSTRM2
AYRSTRM2's Avatar
Profile:  1966 22' Safari
Armada , Michigan
Does it look something like this?
John
John's Camping Blog
AYRSTRM2 is offline   Reply With Quote
Old 04-22-2006, 06:40 PM   #3
dscluchfc
dscluchfc's Avatar
Profile:  1984 31' Excella
Abernathy , Texas
Pics would really aid in providing you an explanation.....
David
AIR # 410
http://www.flickr.com/photos/dsphotoscapes
archival giclée prints available for each picture, 16 x 21 and larger.
dscluchfc is offline   Reply With Quote
Old 04-23-2006, 12:22 AM   #4
pamelake
pamelake's Avatar
John
John's Camping Blog
Yes~ Just like that...only the price tag was bigger! What do you think? Thank you for the response. Pam
Old 04-23-2006, 12:46 AM   #5
AYRSTRM2
AYRSTRM2's Avatar
Armada , Michigan
Then that means you have a weight distribution hitch with 750lbs spring bars. This hitch will be perfectly fine for your vehicle/trailer combo. What this does is essentially add a spring to the swivel point between car and camper, causing it to "lift up", put some weight back onto the front wheels of your car. This is a safety issue, since if you didn't have it, you could more easily loose traction on your front tires and loose control.
Others will tell you to get a sway control bar. We don't use one, but your coach is bigger in both length and weight than ours.
And BTW, Pull-Tite essentially sells Reese equipment under their own branding. Or vice versa, not sure which. So it is also a Reese, that's why you don't seem many Pull-Tites mentioned, they're the same thing. We have a Pull-Tite with the square bars and I think it's just fine.
John
Old 04-23-2006, 11:16 AM   #6
pamelake
pamelake's Avatar
Thanks!
John, Thank you for responding. Makes sense to me, last year an older guy at a gas station told us that in the 60's he saw them being advertised by pulling a TT with an El Camino with no rear tires! I thought the Draw-Tite would also keep the trailer from swaying. Is there room to add and anti sway bar? Pam
Old 04-23-2006, 01:13 PM   #7
Condoluminum
Condoluminum's Avatar
Profile:  1988 25' Excella
Sunnyvale , California
Yes to Anti-Sway Bar..
The Draw-Tite hitch system (we have similar model) does permit the installation of a friction bar anti-sway system. It usually requires installation of a pair of smaller hitch ball fittings ( approx 7/8" diameter steel balls) on trailer frame rail and on hitch mounting, usually to right of holes for bars to fit up into... The friction bar is a rectangular bar with socket on one end for ball, and it fits in sleeve with socket fitting at other end. Loosen friction handle to adjust length and fit over ball mounts with clips, and then tighten handle to creat friction...
Not as great as some of more expensive hitches like Equal-i-zer by Reese and others, but it will restrict swaying.. Install requires drilling into frame rail of trailer, and might better be done by installing dealer.
John McG
Condoluminum
Condoluminum is offline   Reply With Quote
Old 04-23-2006, 04:03 PM   #8
AYRSTRM2
AYRSTRM2's Avatar
Armada , Michigan
Pull-tite? Did I really type "Pull-Tite"? Yeesh, late night.
John
A/C Current Draw Pick Furnaces, Heaters, Fireplaces & Air Conditioning 6 07-03-2003 08:36 PM
BBBBRRRRRRRLOW Serious voltage draw Phaedrus Generators & Solar Power 1 06-15-2003 11:09 PM
Ron's Gonna Love This! Pick Airstream Motorhome Forums 1 12-28-2002 12:35 AM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 02:51 PM
Radio/Light Interface??? 74Tradewind Electrical - Systems, Generators, Batteries & Solar 3 06-18-2002 10:43 AM
test
