Old 06-27-2013, 05:48 PM   #1
Woodweavil7's Avatar
Southside , Tennessee
Dog chewed up the power plug. Ugh!
The dog at my uncles house chewed up the power plug that plugs into the bumper. Where can I get one? And are all the round plugs the same? Is there somewhere I can get a wiring diagram for the entire trailer?
Woodweavil7 is offline   Reply With Quote
Old 06-27-2013, 06:34 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Woodweavil7!
If my interpretation is correct, you are referring to the cord that connects the trailer to the tow vehicle. That cable I am referring to is referred to as a "Pig Tail" and can be obtained from an Airstream dealer. The cable can be found at this link.
I am not familiar with the 120-volt AC power cord on your Airstream, so cannot help if that is the cord that you need. If the dog only chewed the plug itself, a replacement for the 30-AMP RV electrical plug can be purchased from nearly any parts-stocking RV dealership.
Good luck in resolving your problem!
Kevin
Kevin D. Allen
AIR #827
Old 06-27-2013, 07:10 PM   #3
Chatthayer's Avatar
1972 25' Tradewind
Chattanooga , Tennessee
Images: 21
you can get a replacement plug at any rv store. just make sure that you wire it the same as the chewed up one.
Most owners manuals for AS's show a wiring diagram foe most of the systems like the tow vehicle plug. If you don't have that you can order from airstream and a couple of other sources, or get specific pages on the forums.
Bad dog!
Steve and Tobie Thayer
chatthayer@gmail.com
Chatthayer is offline   Reply With Quote
Old 06-27-2013, 08:15 PM   #4
Yes it's the pigtail that I'm referring to. But I would like to go over the univolt system as well
