Old 08-05-2015, 09:14 PM   #141
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Does my intended usage warrant going with diesel?
Originally Posted by slowmover View Post
A leaf sprung axle has problems with wheel hop under power. Axle wrap. Same for body movement against the suspension without a Panhard Rod.
Engine torque management and a five link coil rear suspension means the 2500 is going to be more sure footed under power. And more resistant to tripping hazards which should be a serious consideration. It is also better in crosswinds.
Hotchkiss drive is reliable, and can be made better. But it has its limits. And ride quality is not the main reason to choose another, more sophisticated type. But it can be "better" as perceived by passengers.
In racing applications you are spot on but in the world of towing and hauling your examples are negligible.
Coil spring suspension on trucks was a new thing in the 60's only to find out later that when loaded it produced more sway and it was unpredictable thus the addition of a pan hard bar.Coils work much better on passenger cars and in racing but not so good with heavier loads on the rear.Also the multi progression rates that the multiple leaf springs provide could not be reproduced with coil springs so the ride quality when unloaded was compromised
Easy demonstration take a spring out of a ballpoint pen stand it up and compress it with your thumb.See how it reacts to a load?Same thing happens when a load is applied to your truck.
The automobile manufacturers realized this and went back to leaf springs in the rear for trucks.Now it is being touted as a new idea and the way to go but alas it's already been done but it is great for marketing.Rear leaf springs ride smoother when unloaded are more stable with less sway and have a more controlled progression due to multiple leafs which come into play one by one as the load increases.This applies to pickup trucks used for hauling payloads.For racing Baja etc...coils are the proven way to go due to little or no payload.
Old 08-05-2015, 09:27 PM   #142
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
I don't think you understand, despite your examples. The differences are not negligible. My experience with tow vehicles from the 1970s says otherwise. And you'd agree were you to drive them.
Find some matches and do some testing. I have.
And understand that racing is applicable. Better trailer handling is directly related to better suspensions.
Old 08-05-2015, 10:36 PM   #143
Moflash's Avatar
Only negligible in our towing application as stated.I have spent 40 years in the automobile business.It has been my passion since I was a little boy.Also I have been fortunate enough to meet and spend time with the world best designers,engineers and production staff.I have attended many classes on the subject and hold numerous awards and accolades in multiple subjects relating to automobile product knowledge.I also have towed for many years.With my work I have received complementary new vehicles for personal use and evaluation since 1977 and they numbered in the hundreds.
I have driven on most of the major race tracks in the world and have driven the fastest most expensive supercars in the world.I could go on but it's pointless.
I guess what I am trying to say is that I like you have a little experience and knowledge in this subject and enjoy sharing it with people who are sincere in learning about vehicles.
I am also still eager to learn.So please explain your theory on how coil rear springs on a pickup are superior to leaf springs, please elaborate.
Old 08-06-2015, 08:25 AM   #144
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Have you towed the same travel trailer with otherwise comparable vehicles? Put them thru some hard paces? Try it out. Take the risk. See for your self.
Do you really believe those Chevy pickups were as bad as you recount, or did you use them? I didn't. Cars were then and now better. Some leaf and some coil rear back then. Broken pavement, crosswinds and the like, coil was better. Body didn't fight against tire traction. And MOOG had progressive rate coils then which worked as advertised.
Old 08-06-2015, 08:34 AM   #145
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Going to test drive a 2015 Silverado Duramax 2500HD with LT trim later today. It has more features than the Ram Tradesman I test drove, more similar to Ram Big Horn trim and price.
Kelvin
Old 08-06-2015, 09:05 AM   #146
Moflash's Avatar
Maybe this will help explain.
Old 08-06-2015, 07:48 PM   #147
KJRitchie's Avatar
2008 25' Classic
Kelvin
Test drove a 2015 Silverado 2500HD Crewcab LT. Short Bed. Nicely equipped. Plenty of power and very quiet and you don't even know you are cruising at 70mph. Slate Grey is nice. Dealership pays for oil change services for 5 years and they allowed me to take the truck home for the wife to preview. We took an extended drive including mixed city and highway. After about 20 miles we both agreed the cloth seats are not comfortable enough for long trips compared to our cloth Tundra seats.
The Silverado appears to ride more car-like maybe because its longer wheelbase than the Ram 2500 CC Tradesman and my Tundra. The Ram Tradesman seats from my memory were more comfortable but the test drive wasn't very long. We are going to test drive a Ram Big Horn with the upgraded cloth seats. We will also be able to determine if the Ram is quieter.
The short list just got shorter.
Kelvin
Old 08-06-2015, 08:11 PM   #148
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Kelvin
Proof that comfort is all driver perception. I'm a long time GM guy. I have only ever owned 3 other non-gm's. My Audi, a Ford Mustang and this Ram.
When I went and drove the Silverado, I thought it was a turd. And a huge disappointment.
But, it's all in perception. Ram won me over. But there are still some points about it, where I think GM and Ford are a lil better. But Ram has really come a long way in putting the screws to the other guys. This is my subjective opinion.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 08-06-2015, 08:29 PM   #149
Moflash's Avatar
You are right it's all about what is comfortable to you.
Old 08-07-2015, 12:00 AM   #150
jcl
Vancouver , British Columbia
Not worthy of being considered a trusted source IMO, given that the Youtube poster is "Dodge Chrysler Sucks Don't Buy Dodge Chrysler"
jcl is offline   Reply With Quote
Old 08-07-2015, 07:17 AM   #151
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We have the Big Horn trim level in the 2012 Dodge. I can drive it all day (10+ hours) and still be comfortable. The seats are a fabric that at least breathes some. Leather seats can be cold and clammy in the winter and hot in the summer. My Mercedes leather seats are vented to help keep retained body heat low.
I am short, so the Dodge fits my body pretty well.
Old 08-07-2015, 07:23 AM   #152
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
If I were shopping for a new road trip vehicle I think I would want to get a trim level high enough that would offer both heated and cooled seats. I had an opportunity to use these on a trip one time and was extremely impressed.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 08-07-2015, 08:17 AM   #153
Nomadic , USA
Our Ram is a Laramie trim package, and the leather seats are both heated & cooled and are not the slightest bit clammy. And like Switz, I can drive comfortably for long hours in it.
And I agree with the above. When we were shopping, it was LTZ trim for the Silverado, Lariat for Ford and Laramie for Ram I was looking at. I really liked the Platinum Ford F150 we looked at, but the Ram interior felt superior and I liked the seats a bit more.
But generally I look at top models.
True although I will say that sometimes you can buy what you thought was great only to learn later it's crap. And what you thought at the time was crap is actually superior. This is the realization that brought me around to using Apple hardware.
Old 08-07-2015, 09:07 AM   #154
2016 30' Flying Cloud
Oviedo , Florida
As to diesel or gas, you don't need diesel and you can't really justify it on cost unless you are piling up the miles far in excess of what most of us tow. However, I am on my second diesel Ram (05, now a 14) because I greatly prefer towing with a diesel. The available torque, ability to climb grades at speed without the engine screaming at 5000 RPM, range, exhaust brake and ability for low stress refueling at truck lanes are all part of why the $9K cost premium is worth it to me.
As to brand, I would still not touch a Ford diesel. While the 6.7's are way better than the 6.4's were, the Powerstroke forums are still full of powertrain issues, primarily turbo failures and water in fuel issues that Ford denies warranty coverage for. I personally ran across 2 6.7 drivers this year that suffered turbo failures.
I did test drive a couple F250's before buying my Ram 2500 last year and I felt the new chassis/suspension design on the Ram's resulted in a superior ride, notably the relative lack of frame flex when going over things like speed bumps or potholes. Ford does have some cool features (tailgate step, retractable mirrors, etc). YMMV of course.
I didn't personally consider a GMC/Chevy due to not liking the exterior styling (square wheel wells) or the interior at the time. I also was not happy with GM for other reasons. However, my impression is the Duramax is a reliable motor. The only thing I would be slightly concerned about is I believe they are using the Bosch CP4 lift pump (like Ford) rather than the time-proven CP3 that is in the Ram/Cummins.
The exhaust brake in the new Rams is outstanding, more effective than what I have experienced in the Ford. Putting the transmission in Tow/Haul mode, turning on the exhaust brake to Auto and setting cruise control is a remarkable experience - I have gone down some pretty steep, long grades without ever touching the brakes.
As far as transmissions, I never had a problem with the auto in my 05 and the 68RFE in my new truck operates perfectly from what I can tell also. I actually thought the 15 F250 6.7 I drove shifted worse (less smooth) than the Ram.
My opinion is if you want diesel, buy a Ram or GMC based on what seems most comfortable and or attractive. If you go gas, all 3 are in play.
Keith & Barb
2016 Ram 2500 diesel
Southeastern Camping Unit, WBCCI #1675
khollister is offline   Reply With Quote
Google's Chromecast May Fit the Bill for Air streamers (pun intended) Taylormade Audio, Video & TV 0 07-24-2013 06:24 PM
Weigh in (no pun intended) RTurnConn Tow Vehicles 17 09-23-2011 08:01 AM
Blond Moments - no disrespect intended funkill Off Topic Forum 8 10-02-2009 10:35 PM
mb 52 C going going...... goransons Refrigerators 5 08-23-2007 03:51 PM
Airstream Forum Blues-suggestions for forum usage hex Our Community 18 10-20-2002 11:12 AM
