Old 08-27-2015, 05:04 PM   #15
SKP46015's Avatar
I have used both a front hitch and something called a "power caster" to move my TT in tight spaces. The front hitch is a good solution out in the wilds IF you have someone you trust to direct you. The power caster worked wonderfully at home ... though only on concrete or asphalt... not on sand or a rock driveway... and certainly only on flat surfaces... not inclines... BUT... it is a PRICEY solution... however as someone else mentioned... if you PRACTICE enough, you can back your TT into most any tight spot using some tricks... like laying out some colored line on the driver's where you want the TT tires to go and then back the TT tires right along the edge of the line... works every time... BUT... you have to have confidence in your skills... just go very slowly and have a spotter just in case...don't be afraid to pull out and start again... go to some vacant parking lot some Saturday with your TT and practice, practice, practice until you can do it...
Ed
94 30 Ft. Front Kitchen Excella
99 GMC 2500 6.0L Ext.Cab. 8ft Bed
ARE Shell Topper
SKP46015 is offline   Reply With Quote
Old 08-27-2015, 09:30 PM   #16
1983 31' International
ecorse , Michigan
front hitch
I had one on my last ford van and it worked great, i had to have it custom made. But now they make a factory hitch for my qwigley ford E-350 4x4 diesel van. much easier going frontward.
gmcneil5 is offline   Reply With Quote
Old 08-27-2015, 09:35 PM   #17
Adiredneck's Avatar
2014 27' FB Classic
Vicksburg , Mississippi
I don't mind backing into camping spaces and my driveway - although with two vacations per year that's all the practice I get - but the idea of backing it into a garage with a foot clearance on each side is a bit intimidating.
"Hot meals, cold beer, dry bed & flush toilet - everything I look for in a wilderness experience..."
Adiredneck is offline   Reply With Quote
Old 08-28-2015, 05:18 PM   #18
Central , Mississippi
Originally Posted by Adiredneck View Post
HiHoAgRV, I've not come across an offset front hitch - they all seem to have just a center receiver. Do you know of a hitch manufacturer that makes/sells an offset?...Any ideas?
Sorry, they only ones I've seen were special built. One was on front of a small RV and used to launch boats, the other was on a tractor/front loader used to move campers at a pals lake lot.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Advice for easy in/out of tight cul de sac? blickcd On The Road... 22 06-06-2012 07:08 PM
Brakes, How tight is too tight? rhutson Brakes & Brake Controllers 5 03-15-2012 12:48 PM
Spaces under doors janetb 2007 Safari SE 17 01-23-2007 05:49 PM
How tight is too tight? Alden Miller Awnings 16 06-01-2006 09:09 PM
