Old 03-16-2019, 08:55 AM   #1
loislane's Avatar
2014 23' International
Saint louis , Missouri
Do I need an electronic brake controller with new 2018 Jeep Grand Cherokee?
Hi all,
We just bought a new tow vehicle - upgrading from a Toyota 4Runner V8 (which we are so sad we can't replace due to 4Runners no longer being offered with V*) to a Jeep Grand Cherokee 2018 V8 Hemi. We tow a 2014 23d
When we bought our first airstream the airstream dealer installed the brake controller in the 4Runner. The Jeep dealer thought we may not need it because of the tow package offered with the Jeep - but there is a brake controller harness included in the vehicle.
What do you experts think? Do we need the brake controller in the vehicle? It always bumped my leg so I'd love to not include it if we don't need it - but would get past that if you all think it isn't safe to go without.
LoisLane
2014 23d Int'l CCD
TV: Toyota 4runner
"Homer"
loislane is offline   Reply With Quote
Old 03-16-2019, 09:10 AM   #2
eagletoo's Avatar
2019 23' International
Long Island , New York
Hi LoisLane,
I have the exact same tow vehicle and trailer model as you. Car dealers, by and large, do not understand the needs of the towing world. It’s not their everyday work.
Our dealer (Colonial AS), installed and tuned the brake controller just above the gas pedal. Your leg should not come close to it at all.
Use the trailer’s brakes. They are installed for a reason. Don’t just rely on the Jeep’s brakes.
Enjoy the ride!
Long May You Run!
Bruce
2019 23FB International Serenity
2018 Jeep Overland 5.7L Hemi with factory towing package
Equal-i-zer Hitch
WBCCI #2600
Id rather be camping is an understatement!
eagletoo is offline   Reply With Quote
Old 03-16-2019, 09:25 AM   #3
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Check your state regulations I'm sure you are required by law to have one.
Safety dictates yep you need it!
Garry
Old 03-16-2019, 10:12 AM   #4
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
“Tow package” usually covers things like transmission cooler, upgraded radiator, brake controller harness, maybe mirrors and some other things, but usually not a brake controller in my experience. You definitely need it. Jeep salesman probably never towed anything ...
Alumacoot
"I'd rather be happy for just one day than miserable for the rest of my life."
Dan and Liz is offline   Reply With Quote
Old 03-16-2019, 10:26 AM   #5
2002 19' Bambi
Lafayette , California
A number of pickups come with a built-in brake controller, but, if your 2018 Grand Cherokee is like our 2016, it has some sway control software, but no brake controller. As the others have said, you need a controller. The salesman is wrong.
Tim
Tim A. is offline   Reply With Quote
Old 03-16-2019, 11:49 AM   #6
Mollysdad's Avatar
Yes, you need a brake controller. Either add-on or built in.
Otherwise when you touch the brake, the trailer wheels will lock up.
The controller sends a proportional amount of voltage to the trailer brakes.
Old 03-17-2019, 10:06 AM   #7
2016 20' Flying Cloud
Oliver , British Columbia
We tow our FC20 with a 2018 Jeep GC. Installing a brake controller was a bit of a challenge. Our GC has an airbag located below the steering wheel. The typical install location for the brake controller above the pedals put it in line with the airbag. If due to an unfortunate incident the airbag deploys I did not want the brake controller becoming part of my lower body. After much research I found four options. 1. install in typical location and not worry about air bag. 2. Use a brake controller like the Tekonsha prodigy with remote hand held unit. Keep hand held unit on console. 3. Install built in unit like the Redarc TOW-PRO ELITE V2. This was a pricey option 4. Modify the mount for the Prodigy P3 I already owned. I went with option 4 and modified a windshield mount for the brake controller. It is now easy to get at and easy to see. After towing across Canada this summer from BC to NL it worked great and did not obstruct my vision while driving. The other bonus is I can easily remove the controller when not towing. Hope this helps.
2016 FC20
mjmstream is offline   Reply With Quote
Old 03-17-2019, 10:26 AM   #8
SilverFire
2013 16' Sport
EUGENE , OR
Bluetooth brake controller option
Another option is a Bluetooth brake controller, no wiring required. This product received an award for one of the best trailering innovations recently. It is controlled by a simple app on your smart phone (required). The simple 7 plug Bluetooth receptacle plugs directly into your TV 7 plug receptacle and the AS trailer plug connects to Bluetooth receptacle. Simple and straight forward. In the event your phone battery dies, don't worry, the last settings remained programmed.
Mercedes have no brake controller harness or jacks under dashboard like many US domestic vehicles. My Sprinter van has a hard-wired brake controller which was a pain to install (required removing seat and digging into wiring) and required significant diagnostic time I don't want to ever repeat. The hardwired controller is in the way entering & leaving the vehicle.
I have an additional Mercedes GLE TV and did not want to go through that issue a second time and learned about the Curt Blue-tooth device option. Now wish I have never gone the hard wire route. The Curt allows multiple trailer connections too (I have other trailers). One device, multiple trailers & TV's. This was the way to go for me.
https://www.etrailer.com/p-C51180.ht...el=GLE-Class#/
Best of luck!
SilverFire is offline   Reply With Quote
Old 03-17-2019, 10:29 AM   #9
2019 16' Sport
Alexandria , Virginia
Check out U Haul.I tow my AS Sport 16 with a Mazda CX 9 2018 that came without a harness tow package and U Haul installed the 7 pin connector and electric brake controller for $400 with a 2 yr warrantee. Since you have the brake controller harness your cost should be quite a bit less than what I paid.BTW my AS dealer said that was a good deal I got from U Haul.Congrats on your TV.
Ron1934 is offline   Reply With Quote
Old 03-17-2019, 11:28 AM   #10
greenflag's Avatar
2016 30' International
Quartz Hill , California
Get a brake controller. Most states require them for trailers over a certain GW. Save the strain and wear on your tow vehicle. Not only do you need to pull but you need to stop.
greenflag is offline   Reply With Quote
Old 03-17-2019, 12:30 PM   #11
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
Yes you need it. Not only do you need the trailer to help in stopping, you need the trailer to slow down and stop behind you. I just hate it when, during an emergency stop, your trailer comes up along side and pulls you around backwards into the ditch or oncoming traffic.
Howard L. is offline   Reply With Quote
Old 03-17-2019, 01:33 PM   #12
2007 27' International CCD FB
San Diego , California
I had a V8 4Runner that I really enjoyed too. Agreed that it's too bad they don't offer the V8 in that model any longer.
Look into the Redarc tow pro brake controller. Great modern and well reviewed choice. The brain is hidden, and the compact controller can fit in most switch blanks or anywhere on the dash. So nothing large and substantial to get in the way.
https://www.amazon.com/REDARC-EBRH-A...26553662&psc=1
A great alternative to the 4Runner, or 120-series Prado as it's also known as in the rest of the world, is the Lexus GX if you ever were to look for a V8 4Runner again.
Boondocking option package:
'07 27FB Ocean Breeze "See Turtle", 3" lift
'09 Lexus LX570, on 33's
Tongue Mount Honda eu2200i - Rear Hitch - Underbelly Storage - Blizzard NXT w/ EasyStart - 3" Lift - 6" Fan Controller
pteck is offline   Reply With Quote
Old 03-17-2019, 02:08 PM   #13
waninae39's Avatar
2017 22' Sport
NCR , Ontario
yes; even newer vehicles with tow packages often need one
we have a Tekonsha prodigy p3
ensure that you get someone to set it up. first dealer did not do it well
we got Andy at CANAM london , ON to do it and it works like a charm
Name:	Tekonsha Prodigy p3-in Q5-a.jpg
waninae39 is offline   Reply With Quote
Old 03-17-2019, 04:01 PM   #14
banderabob's Avatar
2008 19' Bambi
2012 23' Flying Cloud
Bandera , Texas
Originally Posted by loislane View Post
Hi all,
Safety first, you should have it, especially when your rig is pushing you down a fair incline and you are trying to maintain a controllable speed. Set properly it will save the brake rotors on the new Jeep as well.
banderabob is offline   Reply With Quote
Brake Controller for 2017 Jeep Grand Cherokee Tartan Brakes & Brake Controllers 12 03-24-2017 09:39 AM
Jeep Grand Cherokee DIESEL as towcar Coloradobus Tow Vehicles 10 09-02-2008 01:47 PM
2007 Jeep Grand Cherokee Gravelcrunch Tow Vehicles 11 07-29-2008 03:36 PM
Jeep Grand Cherokee CR Diesel Nicksut Tow Vehicles 19 10-19-2007 08:07 AM
2004 Jeep Grand Cherokee V8 and a 20' Safari? Roger S Tow Vehicles 10 04-15-2007 03:04 PM
