Old 03-17-2019, 07:25 PM   #15
loislane's Avatar
2014 23' International
Saint louis , Missouri
Originally Posted by Ron1934 View Post
Check out U Haul.I tow my AS Sport 16 with a Mazda CX 9 2018 that came without a harness tow package and U Haul installed the 7 pin connector and electric brake controller for $400 with a 2 yr warrantee. Since you have the brake controller harness your cost should be quite a bit less than what I paid.BTW my AS dealer said that was a good deal I got from U Haul.Congrats on your TV.
Thanks Ron - that's a great idea - I'll try them - our airstream dealer isn't close!
LoisLane
2014 23d Int'l CCD
TV: Toyota 4runner
"Homer"
loislane is offline   Reply With Quote
Old 03-24-2019, 09:11 AM   #16
2019 19' Tommy Bahama
Albuquerque , New Mexico
I tow with a 2018 Grand Cherokee and would only do so with a brake controller. I don’t think you would feel safe without it.
Dtjeep is offline   Reply With Quote
Old 03-24-2019, 09:24 AM   #17
Gainesville , Florida
As far as i know every state requires trailer brakes on trailers as heavy as an AS. No brakes without a controller! This is basic towing info, the dealer should have known or told you he did not know. Misinformation is dangerous.
xrvr is online now   Reply With Quote
Old 03-24-2019, 09:47 AM   #18
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
The "only" answer to that question is "YES, you require a brake controller"
_________________________________
La Dolce Vita Brick & Mona
2004 International 25CCD "Blue Streak"
2013 F-150 SuperCrew FX4 Lariart (MaxTow) "Red Dragon"
Married With Airstream Blog Click Here
drbrick is offline   Reply With Quote
Old 03-24-2019, 10:50 AM   #19
Native143's Avatar
2013 20' Flying Cloud
2014 16' Sport
Dunedin , Florida
I have a 2017 Jeep GC, and definitely use my brake controller. I set it so that Jeep and trailer stop evenly, ie both doing the work. Can feel it if it is out of sync and the Jeep does the stopping. Have to retune it occasionally. So yes, it is necessary.
"All good things are wild and free."Henry David Thoreau
WBCCI #12814
Florida Unit #027, Suncoast Unit #129, Region 3
Save
Native143 is offline   Reply With Quote
Old 03-24-2019, 11:05 AM   #20
2007 22' International CCD
Do I need an electronic brake controller with new 2018 Jeep Grand Cherokee?
And, as we have seen far too many times around the forums, depending on a dealer to know what they are talking about (or not talking about) can be hazardous.
Just points out the fact that you have to do your own research and gain full knowledge about your vehicle, towing setup and other subjects. You are generally in the best spot to have full knowledge, nay specialize in what you are driving and towing.
Dealers are usually best at selling stuff. I seriously doubt they even try to be experts on anything else. At least that’s my experience. Do your own “due diligence” research first.
Then you are ‘armed’ with knowledge, and in a better position to know what’s real and true. It takes effort, but it’s vital to being an “informed consumer” rather than a victim...or, as I cynically put it, “lawful prey”.
Old 03-24-2019, 11:23 AM   #21
2019 22' Sport
Fulshear , Texas
We use a Prodigy wireless controller with a handheld unit — you can put it anywhere. Sorry about the Jeep...I work for Toyota and the V6 4-Runner should easily tow a 23 — what did your dealer tell you?
Scoot22 is offline   Reply With Quote
Old 03-24-2019, 12:12 PM   #22
Land of Oz
1970 25' Tradewind
Pittsfield Twp , Michigan
Toyota's website shows 5000 lb max towing. Working for Toyota maybe you know otherwise... The gvwr on that airstream is 6000 with a 720 lb tongue weight. Bad idea...
The Jeep has a 7200 lb tow rating, plus a hundred more horsepower for those hills. Our old Grand Cherokee had the 4.7 v8, but the new one with the Hemi makes towing our 5500 lb Trade Winds effortless.
Fyi our progressive brake controller with wiring harness for our Jeep was very easy install, plugged right in under dash, took about 15 min
wizardglass is offline   Reply With Quote
Old 03-24-2019, 01:44 PM   #23
2007 34' Classic S/O
Hillsboro , Texas
If your Jeep Grand Cherokee has a factory trailer brake control, use it. I'm towing a 2007 34SO (12K lbs.) with a 2011 Dodge RAM 3500 crew cab long bed dually. It was factory equipped with the ITBC, Integrated Trailer Brake Controller. I used it with my 1999 AS Excella with electric drum brakes and it was excellent. Now I use it with the 34SO with electric over hydraulic disc brakes. I replaced the OEM brake actuator on the AS with one made by CTS, formerly Carlisle. It works very good although newer TV's have a changeable option for the 2 different types of trailer brakes. Jeep is product of FCA, the same as my RAM, and the ITBC units are actually manufactured by a company who also manufactures aftermarket brake controllers. I've towed my AS in excess of 15k miles with zero problems.
John Green, Hillsboro, TX
2007 34' Classic LTD S/O
2011 Dodge RAM 3500/Cummins power
WBCCI #4432 & ARC member W9CJX
jwgreen is offline   Reply With Quote
Old 03-24-2019, 02:13 PM   #24
Stony Point , New York
Contact Tim from Etrailer.com - they have vehicle specific wiring harnesses and brake controllers . Just installed their unit in my 2019 Tacoma. Quick & easy install after watching their installation videos.
Stevelandco is offline   Reply With Quote
Old 03-24-2019, 03:07 PM   #25
2019 33' Classic
Maplewood , Ohio
We had a 2014 27' Eddie Bauer in the past and pulled this a time or two with our 2014 Jeep Grand Cherokee with the EcoDiesel. We had a brake controller added that was installed just below the fuel door button. Worked well for us with no leg interference.
kjseed is offline   Reply With Quote
Old 03-24-2019, 03:11 PM   #26
2015 23' FB Flying Cloud
Redmond , Washington
No need to repeat the excellent and very consistent responses to your inquiry.
I have 125,000 mi on our 2014 Jeep GC EcoDiesel (identical towing specs compared with the hemi V8), over 50,000 miles of it towing our 2015 23FB FC. We use a Tekonsha Prodigy 3 and it was easy to install with the Jeep’s OE harness. Placement is the question. Though I chose to place it on the right side of the lower air bag cover (used stick on Velcro fastener which works great without drilling into the Jeep). I really like the photo of the left window-dash area placement. Reaching for manual control woukd be much easier on the dash.
Having traveled Seattle to NL and several other cross country trips through mountains, I’ve found it helpful to use the just manual control of the AS brakes when going down very steep grades while completely avoiding use of the Jeep brakes. That, coupled with using the paddle shifters to stay in lower gears makes the Jeep feel like a very secure experience.
During my recent oil change the Jeep brakes are only showing 50% remaining life on the pads. The AS brakes show similar life during my recent wheel bearing lube.
WestieHouse is offline   Reply With Quote
Old 03-24-2019, 05:48 PM   #27
Mollysdad's Avatar
My Tundra did not have a built in controller (2015) but it did have the wiring harness. I bought the Tekonsha Prodigy 3, and it was a 15 minute install. The hardest part was mounting the bracket. (I like the Prodigy 3 a lot!!!)
I'm not saying all cars are prewired, but you can use Tekonsha's vehicle selector and it will tell you.
UPDATE: It looks like your 2018 Jeep GC is prewired.
You need a harness 3045-P to mate the controller to the
Jeep harness.
For my Tundra, I looked at YouTube videos to find how others did it. Easy-Peasy.
Here's one for Jeep 2014:
Old 03-24-2019, 06:16 PM   #28
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Yes...any tow vehicle needs a way to use the brakes that every Airstream is equipped with....The Jeep Dealer is full of not knowing what he is talking about.🥴
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Brake Controller for 2017 Jeep Grand Cherokee Tartan Brakes & Brake Controllers 12 03-24-2017 09:39 AM
Jeep Grand Cherokee DIESEL as towcar Coloradobus Tow Vehicles 10 09-02-2008 01:47 PM
2007 Jeep Grand Cherokee Gravelcrunch Tow Vehicles 11 07-29-2008 03:36 PM
Jeep Grand Cherokee CR Diesel Nicksut Tow Vehicles 19 10-19-2007 08:07 AM
2004 Jeep Grand Cherokee V8 and a 20' Safari? Roger S Tow Vehicles 10 04-15-2007 03:04 PM
