04-26-2018, 10:26 PM
2008 19' International
Lincoln
, Nebraska
Do I need Air Lift air bags? Other suspension help?
We just purchased our 2008 Airstream 19’ International, and am pulling with a 2015 F150 supercrew with an Equal-i-zer hitch. My truck is configured as 7,000 GVWR, with an allowable payload per door jamb sticker of 1,605 lbs.
The published figures for the 2008 International 19’ are as follows:
- UBW (Unit Base Weight) w/o options or fluids: 3,575#
- Tongue weight: 510#
- NCC (Net carrying capacity) 925
At the local CAT scale, I’m scaling the following weights:
- Truck, full tank of gas, driver, ReTrax Pro bed cover, no gear, no trailer:
- Front axle: 3,220
- Rear axle: 2,640
- With trailer, dry, no gear, weight distribution hitch:
- Front axle: 3,120 (100# decrease)
- Rear axle: 3,240 (600 increase)
- Trailer: 3,480
Therefore, I conclude the following:
- Tongue weight 500
- Axle weight: 3,480
- Trailer weight: 3,980
This should give me the following allowable payloads:
Truck: 7,000-6,360=640#
Trailer: 4,500-3,980=520#
Total: 1,160#; probably more like 900-950# with tongue weight increase
Again, being new to this, I'm estimating the following payloads:
- Fresh water: 175#
- Wife: 125#
- Gear: 450#
- Food:150#
Are these estimates reasonable? Assuming they're close, I'll be right at or slightly above my truck's GVWR. Should I consider air bags or other suspension mods? Will this have an impact on towing and ride in the TV?
Thanks in advance.
Mike (W9LG) and Jennifer
2008 International 19' Ocean Breeze, Equal-i-zer WDH
2015 Ford F150 4x4 Lariat SuperCrew EcoBoost, 3.55, Max Tow
04-27-2018, 05:29 AM
Lakes Region
, New Hampshire
All of your assumptions and estimations seem right on and well done. Once you get going, it is extremely easy to easily go over that gear number, with thinking of just one more thing to bring with you, so be careful there.
Airbags are good for an "appearance" of leveling, not for actual towing suspension assistance, they can actually make any issue worse, YouTube airbag towing and you'll see it explained, you are better off just getting your weight distribution dialed in as much as possible.
Without getting in too deep, you can pick your camp, GVWR or GAWR to not go beyond, but at a certain point you may just need to consider a more capable vehicle.
Good luck
04-27-2018, 07:10 AM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
It sure looks set up good to me. I think all you need to do is pull it for a while and see how it pulls. No, I do not think you need to add airbags or other suspension mods. I think it is fine to be right at or even slightly over payload for a pickup truck. I would check the axle rating and the tire loads to be sure you are not over on one of those. Those are numbers I would not want to be over by a lot for a long time. There is usually a few hundred lbs difference in the payload and the sum of the 2 axles so you should be just fine there. One day in the future when you have camped in it a while and have what you usually take on board it would be instructive to run it over the CAT scales again just to see how close your estimates were.
One small point: the weight you have identified as tongue weight is indeed the weight that the hitched trailer is adding to the truck but is probably slightly less than the actual tongue weight of the trailer because part of the tongue weight is distributed back to the trailer wheels by the WD hitch.
04-27-2018, 07:59 AM
2016 30' Classic
Victoria
, British Columbia
Here is an an excellent video explaining how airbags will level a TV, but will not transfer weight to achieve the results we are looking for.
https://youtu.be/XBZu39pQ8Gg
04-27-2018, 08:36 AM
Lincoln
, Nebraska
Thanks for the replies and advice. I appreciate validation of my numbers. We'll camp for a while and see how it tows and how it grows.
Mike
04-27-2018, 09:09 AM
Computer Consultant
2007 30' Classic S/O
Chino Hills
After hooking up, I'd place a level on the truck bed rail and verify it is level. If front end is too high your lights will be in the eyes of opposing traffic. I would then consider air bags to level out the truck.
my $0.02
Jennifer & Kent Behrends
Artemis' Chariot - 2007 Classic 30so
Blue Ox - 2004 F350 6.0l Diesel, Manual, 4x4
WBCCI #7192
N6ROQ
04-27-2018, 09:37 AM
1969 25' Tradewind
Shasta Lake
Load your truck and trailer as you were going on the road then run it across the scales . This will be the only way to know where you stand.
04-27-2018, 09:39 AM
Lebanon
, Tennessee
Don't do what I did: Install a fiberglass camper shell and bedslide. With the weight of the WDH added I am over my payload capacity because I haul a decent tool bag, jacks, grill, generator (Honda 3000 which is way too heavy) and what have you in the back of the truck. Plenty of room in the box, but not enough payload capacity.
04-27-2018, 09:57 AM
2010 20' Flying Cloud
Hailey
, Idaho
Like RandyNH said, airbags will improve the "look" of the rig, but will do nothing re increasing load capacity. But like the rest of us, I'm impressed by the thoroughness of your calculations. I'm equally impressed by the 150 lbs of food you take along...bon appetit. And safe travels. jon
04-27-2018, 10:20 AM
2013 31' Classic
billings
, Montana
The numbers look good, the 150 is one step up from a car...
04-27-2018, 11:08 AM
Anna Maria
- Front axle: 3,220
- Rear axle: 2,640
- Trailer: 3,480
- Tongue weight 500
- Fresh water: 175#
- Wife: 125#
- Gear: 450#
- Food:150#
Thanks in advance.
Air Bags don't work very well with the F-150. I installed them on the 2012 I had and eventually had to remove them. I too struggled with bumping up to and over the max payload so eventually went to a F-250.
04-27-2018, 01:56 PM
2017 25' Flying Cloud
Queen Creek
Caution!
You clearly like to live dangerously. NEVER publish an opinion about wife poundage!
04-27-2018, 06:35 PM
Lincoln
, Nebraska
my $0.02
I'm measuring the following top of wheel well/fender in center of wheel:
- No load, no passengers, full fuel
- Front 36 1/2"
- Rear 39 1/2"
- Trailer, with load leveling hitch
- Front 37 1/4" (3/4" higher)
- Rear 37 1/2" (2" lower)
I haven't checked the headlights but I would think this is within tolerance. I'll check it at night.
04-27-2018, 06:38 PM
Lincoln
, Nebraska
Thanks for the reply. That's a SWAG (Scientific Wild A** Guess) on food. We'll see when we start going on longer trips.
04-27-2018, 06:40 PM
Lincoln
, Nebraska
And fortunately it drives pretty close to one as well. I've had plenty of time in 3/4 and 1-ton trucks in my past. I like the compromise, and am willing to watch my weight .
04-27-2018, 06:42 PM
Lincoln
, Nebraska
You're very wise.
04-27-2018, 08:12 PM
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez
WD on a half ton truck towing a 19? Remove WD hitch, place trailer on ball directly and GO camping.
We pull our 19 with a Tundra extra cab no WD and tows like a dream.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
04-27-2018, 10:18 PM
Lincoln
, Nebraska
Interesting. This is my first experience with a TT and it's the way it was sold to us; the previous owner had the same class of truck as we do.
What's the downside with using the Equalizer?
04-28-2018, 06:38 AM
Lakes Region
, New Hampshire
And this is where you learn that not everything you see on here is good information.
The hitch on your truck, as are most ½ tons, is rated for 500lbs without weight distribution (please correct me if I'm wrong there) your stated tongue weight is 510lbs and you already have the hitch, why would you remove it?
Your very detailed measurements clearly demonstrate that with the WDH in use, you've almost perfectly leveled out your setup, again why would you remove it?
Let common sense apply and weed out the "I've done it like this and never killed myself" bad advice you'll get every now and then.
04-28-2018, 08:20 AM
2009 27' FB Classic
Sioux Falls
, South Dakota
Can't increase capacities with Air Bags
Air bags are only used to help out your TV springs support the load and level out the vehicle. The air bags cannot increase the TV's tow capacity or max payload capacities. Don't make the same mistake I did in assuming a 3/4T pickup has a higher max load that a 1/2T. I traded my F150 for an F250 because my F150 was continually overloaded. My mistake. The F250 only had 250" more Max Load than my F150. What an expensive mistake. The catalog ratings are what could be not actual. The only actual max load for your TV rating is on the door column. This is the only place in the world this is located. I assumed the F250 would be 1000"s more than the F150 (per the catalog) but just another mistake in this RV adventure.
Happy Streaming
