Old 02-18-2016, 05:36 PM   #1
1975 31' Sovereign
West Liberty , Kentucky
Do I need a transmission cooler?
We are going on the Southwest Adventure caravan this summer. I am pulling a 1975, 31' AS with a 2010 Chevy 2500 Duramax with an Allison transmission. I have been told that there are some long steep roads on this trip. Should I consider putting an additional tranny cooler on the truck? It has the factory tow package.
Air4563 is offline   Reply With Quote
Old 02-18-2016, 05:44 PM   #2
dznf0g's Avatar
Oswego , Illinois
Not necessary on that rig.
-Rich-
Old 02-18-2016, 05:56 PM   #3
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
You've already got one, just drive it...you've got a winner...
Old 02-18-2016, 05:58 PM   #4
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Yepper - the brakes, tranny and engine are TRUCK parts... not PICKUP. Love my GMC. The only difference between a 2500 and a 3500 are heavier duty springs. (Rougher ride).
I call mine "The Mother Truck II" or "Snow White". Some day soon I'll be pulling a 10 meter Avion with mine. Your trailer is a teardrop by comparison.
Old 02-19-2016, 11:44 AM   #5
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
The only way you will know for sure is to install a REAL tranny temp gage. The ones from the factory won't tell you it's too hot until it's too late. One thing about it, an extra tranny cooler is around $125 installed vs $3-4,000 if you blow a transmission.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 02-19-2016, 11:48 AM   #6
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
More like $4,500 - ask me how I know!
Silver Hawk is offline   Reply With Quote
Old 02-19-2016, 12:04 PM   #7
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
For what it's worth;
Even before I started towing an RV, I've equipped my vehicles with an aftermarket cooler.
I've found that the car will accelerate a modicum better, because of the cooler(thicker) fluid. Also, I've never needed tranny repairs. This, on four or five autos, and two U.V.s.
Now that I'm towing an Airstream, it looks like the Ford cooler is doing it's job. The temperature gauge shows a maximum of 98 Deg. C. in worse case conditions; which is fine.
MelGoddard is offline   Reply With Quote
Old 02-19-2016, 12:13 PM   #8
greenflag's Avatar
2016 30' International
Quartz Hill , California
I have towed extensively throughout the West with my Duramax/Allison. The hardest was Panamint grade the back way into Death Valley. 148,000 miles and no issues to report. Get your transmission serviced and enjoy your trip.
greenflag is offline   Reply With Quote
Old 02-19-2016, 12:19 PM   #9
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
And my dodge has 96000 towing and no problems and was told no warrenty when new if adding gauges, don't need them, drive accordingly...
Old 02-19-2016, 03:37 PM   #10
1972 31' Sovereign
Huntley , Montana
Maybe this is a good thread for me to pose my question, although TJDONAHOE (who coincidently lives within a 15 or 20 mile radius of me) may have already answered it. I have a 2000 Dodge 2500 extended cab, LB diesel with a 4-speed automatic tranny. My AS is a 1972 31' Sovereign. Some time ago, I became aware of electronic engine monitoring devices (for lack of a better term) that can be installed on older vehicles like mine. The devices I am referring to are made by Edge products (www.edgeproducts.com). I know the monitor screens on the Edge units can also be used with a rear camera which, of course is sold separately. To get right to my question, are devices like that even necessary? Any advice anyone has will be greatly appreciated!
Philip498 is offline   Reply With Quote
Old 02-20-2016, 07:39 AM   #11
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
My answer is , the engineeres at dodge, Gm, or ford , designed their engine for all around use and $3-400 spent on it isn't going to make better, common sense will be better put to use...
Old 02-20-2016, 07:50 AM   #12
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
My response would be that the tubes and hoses used on any aftermarket cooler I have ever seen suck in comparison to factory setups.
My advise for that truck and most other modern trucks is to not build in more leaks and blown hoses, leave the factory setup alone.
Brevi tempore!
Old 02-20-2016, 08:32 AM   #13
field & stream's Avatar
2008 23' Safari SE
2007 Base Camp
Santa Ynez , California
A transmission cooler is needed, but the factory cooler should get the job done. The other very important factor is whether or not your transmission fluid needs changing at this time.
field & stream is offline   Reply With Quote
Old 02-20-2016, 09:31 AM   #14
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Learn to use the transmission correctly. Don't just put it in drive and take off.
If you are in conditions which cause the transmission to shift constantly you should take appropriate action to reduce the constant shifting up and down. Select a lower gear as the top gear to prevent the shifting.
It's the shifting that wears on the transmission more than anything. IMHO
Opinion please, on transmission cooler.. kidsgone Tow Vehicles 7 01-30-2010 11:50 PM
Transmission cooler 2008 Suburban. adonh Tow Vehicles 39 09-02-2008 11:25 PM
aux transmission cooler? nickglase Mechanics Corner - Engines, Transmission & More... 10 04-08-2007 11:37 AM
Transmission cooler thenewkid64 Mechanics Corner - Engines, Transmission & More... 13 11-10-2003 10:37 AM
