Old 03-25-2014, 12:51 PM   #1
SilverEagle6's Avatar
2013 25' Flying Cloud
2008 30' Classic
On The Road To Wherever We End Up , Traveling the USA
Distribution of weight to front and rear axles
I have a reese dual cam hitch, tongue weight on my FC 25' is 860 lbs. Does anyone know the distribution of weight to the front and rear axles? I know the total is about 85% of the tongue weight, just trying to guesstimate the axle distribution.
Thanks.
Jeanne and John, and always with us...Jake
2008 30' Classic Ltd Rear twin, 2014 Ford Super Duty
WBCCI 3100, unit 12, TAC USA-1, Escapees 129379
https://instagram.com/silvereagle3100/
SilverEagle6 is offline   Reply With Quote
Old 03-25-2014, 03:23 PM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Weight Transfer
With a Reese hitch, the amount of weight that is transferred from the back wheels of the truck to the front wheels is controlled by the angle you set on the ball mount and the number of links in the chain you are actively using. Some people set the ball angle to be a little backwards, so they can have two or three links hanging loose. You need to use a truck scale or measure the height of the truck front and rear (at the wheel wheel) to see that both the front and back wheels have been depresses and equal amount when the bars are engaged. Therefore are carrying half the tongue weight of the trailer.
Old 03-31-2014, 06:34 AM   #3
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
For two-pounds to TV steer axle, one-pound to TT axles; generally.
Or, in the range of 75/25, maybe 80/20 of: weight on hitch ball remaining to weight transferred.
Guesstimates won't do the job. Weigh the TV as if loaded for camping obtaining FF and RR weights separately. That's a start. Same for TT, get the TW.
Axles Axles Axles GeocamperAS Axles 33 11-20-2015 12:01 PM
Weight Distribution and Tongue Weight AldeanFan Hitches, Couplers & Balls 28 01-27-2013 10:28 PM
Tongue weight and weight distribution Bex Hitches, Couplers & Balls 8 06-06-2010 12:11 PM
Refined TV weight numbers = required weight distribution? flyfishfred Hitches, Couplers & Balls 4 01-12-2008 08:13 PM
