Old 09-12-2019, 02:16 PM   #1
denver , Colorado
Disconnecting 12v charge current from tow vehicle?
Hey all,
2010 27FB, 2015 Ram 1500 here.
I just installed some pretty expensive lithium batteries, and I'm trying to determine if I can disconnect the 12v power coming from my 2015 Ram 1500. My assumption is that one of the other pins on the 7 pin connector is supplying power to the breaks, but I figured this would be the best place to ask.
Ksears is offline   Reply With Quote
Old 09-12-2019, 02:32 PM   #2
BambiTex's Avatar
1955 22' Safari
1967 26' Overlander
Clear Lake Shores , Texas
Diagram
Here you go.
BambiTex is offline   Reply With Quote
Old 09-12-2019, 03:03 PM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
You may be able to just pull a fuse on your Ram. Check the manual for a fuse for trailer 12V or trailer charge, or something like that. After pulling the fuse, check to make sure your brakes still work. My F-150 had a fuse just for the charge line.
Another alternative is to find the charge line at your 27's DC panel and disconnect it.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 09-12-2019, 03:18 PM   #4
2020 Classic 33 on order
Box Elder , South Dakota
Pull the fuse. Or install something like the Victron Cyrix-ct 12/24V-120 battery cmb. Good diagram at https://amsolar.com/rv-battery-accessories/98-altagmtow as you build your system.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Old 09-12-2019, 07:46 PM   #5
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Yup pull the trailer aux fuse in your fuse box. My 2500 gmc had a 30A fuse dedicated to the aux charging line on the 7-way. I pulled to so as not to mix and match voltages across lead acid and lithium. Works like a charm and takes 15 seconds once you know which one. Just check your book.
If you go the victron route you need an Orion DC-DC converter. Just search “Orion” on the forum and you’ll pull up posts and I shared model number in the past....
wulfraat is online now   Reply With Quote
Old 09-12-2019, 07:51 PM   #6
Missed the lithium bit. Here's the AMSolar setup for use with LiOn batteries. Does not require an Orion unit.
https://amsolar.com/rv-battery-accessories/98-altclitow
Gary
NØVPN
Old 09-13-2019, 08:00 AM   #7
denver , Colorado
You guys rock, thank you! I found the positive charge line where it tied into the positive bus bar under the bed. I disconnected that and we're in business .
Old 09-13-2019, 08:02 AM   #8
denver , Colorado
So I looked into this a little bit ago, and I had interpreted the install as needing to run a new positive and negative line straight from the battery-- is that not the case? Don't the existing lines connect directly to the vehicles alternator?
Old 09-13-2019, 08:38 AM   #9
denver , Colorado
I just checked out AM Solar's diagram, and it looks like they're using Battleborn drop-in replacements. Those batteries have an internal BMS that regulates voltage going into the cells, enabling them to take current straight from the alternator, whereas I have raw LiFePo4 cells with no BMS, so I would need something like the Cyrix to regulate voltage. (I think)
Old 09-13-2019, 08:48 AM   #10
waninae39's Avatar
2017 22' Sport
NCR , Ontario
get a battery isolator between the TV and AS.
we use a victron converter/inverter to chnarge our lion from AC/solar. we tell it we have BB lion battery and program the correct parameters as given by BB.
it works like a charm
waninae39 is offline   Reply With Quote
Old 09-13-2019, 09:55 AM   #11
Half a Rivet Short
Carlisle , Pennsylvania
Hi
If you are running a lithium setup that does *not* have a BMS ... yikes ..... that's not a good idea at all.
Even with a BMS, you need to do something about the alternator. It's set up to charge a lead acid chassis battery. Dropping a lithium across a lead acid (which is what the charge line is doing) means that one or the other is not getting what it should. Either you nuke the lithium or the lead acid.
Best bet is to spend $80 on a DC/DC converter. Set it at 13.4V and forget about it.
Old 09-13-2019, 11:44 AM   #12
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
RIP your very expensive batteries...
TheGreatleys is offline   Reply With Quote
Old 09-14-2019, 08:26 PM   #13
1988 32' Excella
Robbinsville , New Jersey
I would NEVER do a long term fix on the TV, any long term fix should be on the trailer side.
What happens if you break down and need to have someone else tow your trailer?
Destroyed batteries, maybe even with telling them it's needed.
Old 09-15-2019, 08:29 AM   #14
wulfraat's Avatar
You need a victron Orion dc-dc converter to regulate voltage per post #5....
12v
Disconnecting the shell from the trailer frame DavidF Repairing/Replacing Floor &/or Frame 2 10-02-2015 07:09 PM
Disconnecting Shower Drain ? AldeanFan Plumbing - Systems & Fixtures 3 10-09-2013 04:55 PM
Disconnecting the batteries Bobdes Batteries, Univolts, Converters & Inverters 6 06-02-2011 03:51 PM
Battery Disconnecting on Solar Application jeff4506 Generators & Solar Power 4 11-24-2008 07:32 AM
Disconnecting toilet from tank vishwa Airstream Motorhome Forums 1 09-06-2003 02:25 PM
