Old 02-25-2014, 10:40 PM   #1
Vitaminsea's Avatar
2012 28' International
Alameda , California
Different Tongue Weights same size trailers 28' vs 27'
Hi streamers,
I was researching tow weights and hitches but confused on the big difference of hitch weight (tongue, nose, pin) between the 27Fb model verses the 28. That is 770 pounds verses 950 pounds respectively. Both the same size and with the same gross vehicle rating at 7600 pounds. The 28 is one inch shorter in length strangely.
Is it the bedroom switch? Plus the kichen? The tanks and batteries are all in the same places. The bedroom is heavy too.
Any thoughts most appreciated.
Vitaminsea is offline   Reply With Quote
Old 02-25-2014, 11:09 PM   #2
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Those are empty weights. The beds are a very large storage area, the 27FB will probably load heavier in front than the rear bed 28. The loaded tongue weights may be much closer.
Doug and Cheryl
Old 02-27-2014, 10:17 PM   #3
Vitaminsea's Avatar
Thanks for that. Didn't think about the airstream posted weights as empty figures and how much that would effect hitch weight. I've stocked my storage compartments, drive with full fresh water, and have food in the frig. I weighed my tougue and it's 850 (or less) verses the 950 airstream posts for the 28'. Now it makes sense. Thanks again.
Monica & JT
Old 02-28-2014, 06:19 AM   #4
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
The 28 footers are one of the heaviest from a tongue weight perspective. It has to do with layout and furnishing. Yes, the tongue weights from the factory specs are a bit confusing, close but will not win the prize. The only way to know what you really have is to weigh it. The water tank is between the axles and when full can help reduce the tongue weight by a bit. The frig is also over the axles and doesn't impact the tongue weight too much. Of course, cargo loading in the rear of the trailer also helps reduce the tongue weight. The 28 Flying Cloud goes over a thousand pounds if you aren't careful with the loading. The 28 International may have an advantage over the FC since the design of the booth is much lighter and the overhead cabinets are fewer and a bit lighter as compared to a Flying Cloud.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 02-28-2014, 06:43 AM   #5
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
What Alphonse said-
The distance from coupler to axles figures into the equation as well.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 02-28-2014, 06:52 AM   #6
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Camping ready, our 2013 25FB International Serenity had a 1,175 pound tongue weight (literature tongue weight of 833 pounds). We had a Hensley hitch installed.
Old 02-28-2014, 06:58 AM   #7
Alphonse's Avatar
Lower Alabama , USA
Switz,
Interesting that you count the Hensley as tongue weight! Many wish to ignore that.
Alan
Air #64439
TAC AL-8
2018 Canopenian
Old 02-28-2014, 07:10 AM   #8
dkottum's Avatar
Originally Posted by m.hony View Post
What Alphonse said-
Absolutely. Forum posted tongue weights of similar Airstreams can vary widely depending on the position along the tongue the scale is placed. For example the scale placed under the tongue jack will indicate higher tongue weight than a scale placed under the coupler.
Doug and Cheryl
Old 02-28-2014, 07:16 AM   #9
SteveH's Avatar
Common Sense , Texas
Yes, I've actually weighed mine at the jack, and then again at the coupler, and the difference was more than 100lbs. Seems all of the Airstreams are heavier on the tongue than stated in the literature, and that's probably because of the propane and batteries, but may also be stated on the light side for marketing purposes. It's really not a big deal, just adjust the WD hitch as needed.
At a rally a while back after I had bought my scale, we went around weighing all the tongue weights, and the heaviest in our unit was a 2000 34' SO with the long couch slide, and it weighed over 1300 pounds.
Regards,
Steve
Old 02-28-2014, 09:08 AM   #10
JFScheck's Avatar
Rockville , Maryland
Images: 33
As stated by "Sean" (Big Kahuna at ProPride), the Hitch head and mechanism as mounted on the trailer do add to the tongue weight of the setup!
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 02-28-2014, 09:18 AM   #11
m.hony's Avatar
2013 30' Classic
I agree with a couple of statements here.
1. You must include the weight of the hitch head. It is there- hanging off the receiver- you can't ignore it.
2. Accurate tongue weight should be Measured at the coupler as that is the part that sits on the ball/hitch head/receiver/truck axle...
3. To add to all of that, if I am exceeding 1,000# tongue weight the truck doesn't seem to know or is not bothered by that fact. The weight distributing hitch may make tongue weight a little less because it is designed to transfer some weight to the tow vehicle front axle and trailer axle.
How does one measure tongue weight with weight distributing hitch on? Cat scales? Can it be determined with total combination weight, steer axle weight, drive axle weight, and trailer axle weight? Or is the only way to unhook and get another reading? but this would be on the jack...not the coupler...
TAC #MS-10
Airforums #70955
Old 02-28-2014, 11:49 AM   #12
Alphonse's Avatar
Lower Alabama , USA
Yes, a WDH does move some tongue weight to the front axle of the truck and a little to the trailer axles. These transferred axle loads do not miraculously eliminate the tongue weight from being a concern however. The applied tongue weight relies on the strength of the receiver hitch to translate the moments and forces into vehicle and the trailer. This is where the capacity of the hitch receiver must be adequate for the service and why they are typically rated for "tongue weight with a weight distributing hitch". Their capacity is not stated as rear axle weight after weight distribution.
Tongue weight can be measured directly using a Sherline scale. The Cat scale tickets can also give you enough data to calculate tongue weight by removing or unloading the weight distribution bars and weighing the TV and Trailer in this condition (w/o weight distribution) as compared to the TV alone.
Alan
Air #64439
TAC AL-8
2018 Canopenian
Old 02-28-2014, 11:57 AM   #13
m.hony's Avatar
2013 30' Classic
I know I am at or near or exceeding tongue weight capacity, but it is really a moot point.
I ain't buying another truck...
I will run what I brung...
If I am at or exceeding buy just a few pounds all is surely OK.
It would be a different story if I were several hundred pounds overweight- like stuff would most likely start braking and failing-
So far, so good in 4 years and 25,000 miles-
TAC #MS-10
Airforums #70955
Old 02-28-2014, 01:11 PM   #14
Alphonse's Avatar
Lower Alabama , USA
m.hony, Sorry, I did not intend to infer the choice is not yours.
Alan
Air #64439
TAC AL-8
2018 Canopenian
Copper Pipe Size? jr3149 LP Gas, Piping, Tanks & Regulators 16 01-27-2016 10:32 AM
Right Size Drill Bit For Olympic Rivets VeggieBullet Ribs, Skins & Rivets 75 12-27-2011 01:44 PM
BEDS... Suggestions for 3/4 size??? TPdrums General Interior Topics 1 12-05-2011 11:28 AM
Snap Size '65 Tradewind? P&A Upholstery, Blinds, Walls & Interior Finishes 2 07-16-2011 03:27 PM
waterlines size qc1500 Fresh Water Systems 8 01-11-2011 06:04 PM
