Originally Posted by wacnstac
The airstream charts shows the Dry Weight for the trailer I just bought (79' 31' rear bath) at being just shy of 5000lbs.
With an AC, LPG bottles, and a few other unsheddable pounds, I would not be surprised if your total weight was between 5500 and 6000 lbs.
I assume you used this link to determine what AS said the trailer should weigh.
http://www.airstream.com/airstream/p.../weights-1.pdf
The info plate on my '78 sovereign is below -
I suspect that the above GVWR is the rating of the axles (6400 lbs) plus the probable hitch weight - +/- 500 lbs.
Your GVWR is probably identical to the plate shown above, but your trailer's GVWR should be listed on your info plate as shown in the photo.
The weight listed in the PDF file by AS is indeed the bare bones weight with NO options as the trailer left the factory new - I would think that the trailer probably has put on a lot of weight since then - better to take it to a scale and weigh it to be sure - at the same time it is a good idea to use to scales to adjust your weight distributing bars.
BTW, I towed a brand new '28 Classic a couple of years back ONE time with an Expedition - I have one word for it - squirrely.
The trip was white knuckles all of the way - and the entire time I was thinking about the Ford one-ton dually sitting in my driveway. I would NEVER attempt to pull a Sovereign with an Expedition again.
What type of brake controller and weight distributing bars will you be using?
Luck.
