Old 03-21-2018, 07:13 AM   #1
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Diesel preventive maintenance?
I have a 2007 Dodge diesel with 200000 miles on the meter. Going on a 5 month trip north. Canada and Alaska. It is now time to change the coolant. Is it a good idea to change all the hoses and the water pump as a preventive measure? What else should be considered to be done over regular maintenance?
Bill M. is online now   Reply With Quote
Old 03-21-2018, 07:21 AM   #2
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Two spare tires for the truck (and possibly for the trailer too) and TPMS for both the truck and trailer.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is online now   Reply With Quote
Old 03-21-2018, 07:22 AM   #3
r carl's Avatar
Lin , Ne
https://dodgeforum.com/forum/dodge-ram-diesel-88/
Old 03-21-2018, 07:42 AM   #4
2016 28' International
Sioux Falls , SD
New coolant, 1-spare for each and a good patch kit should be fine. I have done the AlCan 4x and never a flat. Your milage may vary as some say.
Check belts and hoses very carefully. If not cracked or brittle they should be fine.
Have your brakes checked.
Carry extra windshield fluid.
Have a great trip!
2016 Int. Signature 28' w/ ProPride 3P-1400 Hitch
Mich. LTX w/ 16" Sendels, Centramatics
2017 Ram 2500 4x4 Diesel, CG1800 Bed slide, Leer topper
Better to live one day a lion than a lifetime a sheep. Camp hard, camp often
DBinSD is offline   Reply With Quote
Old 03-21-2018, 08:18 AM   #5
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Change the fuel filter and carry a spare if you get a load of fuel with water. Not a bad idea to change out all fluids, belts and hoses as these are age related preventative maintenance items. How are the shocks? Checked the u-joints - especially the front axle u-joints and wheel bearings as those are usually first to go. Carry a spare water pump. Do you have a battery hydrometer for checking the individual battery cells? This can be an indicator of the life left in the batteries. I would also check for wear with the ball joints, track bar bushings and remaining steering linkage. These are typical wear items for a truck with high mileage.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
345 Preventive Maintenance John Woodrow Classic Motorhomes 19 02-09-2017 04:01 PM
Preventive Leak Maintenance GuitarmanFL Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 12-16-2015 08:22 AM
How much POR-15 Rust Preventive Paint toastie Repairing/Replacing Floor &/or Frame 8 12-20-2007 01:41 PM
Annual Preventive Maintenance and Inspection Requirements flyfisher Our Community 0 04-26-2007 08:14 AM
Black tank preventive maintenance balrgn Waste Systems, Tanks & Totes 0 10-05-2005 04:26 AM
