Old 04-14-2015, 12:50 AM   #57
2016 30' International
Scottsdale , Arizona
Road Geezer... I believe that you will be very well-served with the 3/4 ton Duramax/Allison option. There is significant "headroom" with this option.
Numbers-wise, we could have stayed with our Yukon Denali towing the 30' Flying Cloud, but in the end, I believe it is better to go with more capability, rather than with less and that is why we, too, are choosing the Denali 2500HD to pull our 30' Flying Cloud.
DHart is offline   Reply With Quote
Old 04-14-2015, 05:09 AM   #58
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
Hi Bruce
the issue is how many degrees off a straight course can you turn in a very short distance without losing control of the vehicle due to oversteer. Or, put differently, how much steering angle will the vehicle's front wheels accept at highway speeds without the driver losing control?
Basically this is what we are testing with the slalom and lane change test. I get a call or two from customers every year telling me how their combination was able to avoid an accident so it does happen.
A few years ago one of our customers told me about driving through Atlanta. His wife was driving their Astro Van towing their 25 classic. They were in the right lane when just ahead of them a driver in the 3rd lane made a lane change into a car in the second lane just ahead of them both cars started spinning out of control right in front of them.
He thought this is it were going to crash. All of a sudden his wife wiped the wheel to the left tires squealing into the left lane then back to the right around the cars. When he got his breath back he said, how did you know you could do that! She said I watched the video at Can-Am.
Andrew T
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 04-14-2015, 09:41 AM   #59
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Denali 1500 w/6.2L vs. Denali 2500HD Duramax
Most over correction accidents happen because the driver has not trained him or herself to always STAY COOL, and NEVER freak out.
Too many folks overestimate the size of the tow vehicle in safe towing, not quite understanding that tow vehicle mass is not superior to a well thought out and executed combination of tow vehicle and trailer.
Yes, there IS more than one way to skin a cat.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 08-17-2017, 05:54 AM   #60
2017 30' Flying Cloud
downing town , Pennsylvania
I was in a very similar situation – owned a 2015 F150 KR with all the options. Loved it! Then bought a 30’ FC. I was way within the towing specs (even the real ones for my truck’s configuration, not the TV ad ones). While it towed ok, it did strain a bit on hills and depending on grades, I felt uneasy on downhills. But as mentioned in other responses the biggest challenge for me was payload. With a trailer tongue weight of around 1k, fuel, my wife and myself, we were at the vehicles GVWR limit. And we had not even added items in the bed of the truck. And I had to play a lot with the weight distribution to get weight off the drive axles since I had exceeded that. I spent a lot of time at the CAT Scales. I know the 150 wasn’t going to just break, I’m sure I could have dumped 500 more pounds on it but I was already nervous, beyond my comfort level and could feel a strain on the truck as I towed. I ended up trading in the 150 for a new GMC Denali HD with the Duramax. Night and day! I could spend hours talking about the towing difference, the 3/4 ton made it a much better experience. I went through the Blue Ridge mountains with ease. Downhills were no trouble with the exhaust brake, at times I even had to give it gas to keep going! I could carry all the gear in the bed with no worries. The only towing issue I had was on highways forgetting at times I was towing something until I looked in the rear view and saw a trailer right behind me! Now, this isn’t for everyone – the ¾ ton is bigger, harder to park in cramp areas. But the ride is not bad, not as great as the 150 but very nice. And the gas mileage is as good if not better than the 150 (I had the 3.5 eccoboost). I was getting 15mpg towing, 19-20 on mountain highways when not towing. Get around 15-18 around town. The higher cost is a factor but fortunate for me I was able to handle that (you don’t have to buy new). I will say that the 150 had way more features including the one that I REALLY miss, keyless entry, start. But I’m glad I made the switch.
mike-FC30 is offline   Reply With Quote
Old 08-18-2017, 04:41 AM   #61
2012 19' International
Southeastern MI , Michigan
Originally Posted by DHart View Post
I am looking at two potential trucks as a TV. I know that either one is more than fully capable to tow a 30' Flying Cloud, but want to get some feedback from those who may have/had either of these two trucks.
2015 GMC Denali 1500 truck with the 6.2L engine - 9,200 lbs. towing capacity 1740 lbs. payload
2015 GMC Denali 2500 truck with Duramax - 13,000 lbs. towing capacity 2793 lbs. payload
Aside from the $6k-$7k price difference:
The 1500 would have more than enough capability for pulling the 30' Flying Cloud, no problem, and is more "car-like" to drive around.
The 2500 HD is more "truck-like" to drive around, but its extra margin of towing capacity would be very reassuring. I do like the extra height and more truck-like quality of the 2500HD. And the fact that this truck could tow something heavier than an AS, should I ever want to do so, though I don't anticipate having another RV after a 30' Flying Cloud.
I'm told that late model 3/4 ton diesel trucks are in greater demand and tighter supply than 1/2 ton gas trucks are, which may indicate that the former could hold resale value better over the coming years.
I drove both of these trucks today and really liked them both, though there was a marked difference in "feel" while driving them. As I said, the 1500 with 6.2L was quite car-like and the 2500 with Duramax was quite noticeably a very beefy truck, but still quite luxurious and comfortable.
So... your comments about either or both of these trucks would be appreciated.
I had a 2500 Duramax and grew to love it for commuting. If the difference is only $6k you are getting a good deal. I drove the 6.0 gas before buying that truck and it was fine too but the Dmax was a little quicker off the line. As far as parking and handling in traffic there was no difference.
Countryboy59 is offline   Reply With Quote
Our new 2015 GMC Sierra Denali Duramax 2500HD time2play Tow Vehicles 91 08-07-2017 06:05 AM
Denali Sierra 2500hd 6.0 gas with 4.10 Pappy Tow Vehicles 42 07-31-2012 07:45 PM
Extended Cab or Crew Cab 2500HD w/Duramax for TV??? TomR Tow Vehicles 19 01-31-2007 06:27 PM
Hensley and 2500hd davidz71 Hitches, Couplers & Balls 4 03-24-2005 08:57 PM
