Old 04-05-2018, 04:25 PM   #1
1969 31' Sovereign
McCall , Idaho
DEF Freezing
Have any of you folks living in colder climates have any issues with DEF freezing? I have a 2017 Ram 3500 Heavy Duty Turbo Diesel, I live in McCall, Idaho, and have had no issues. I assume it's possible, just curious if anyone have experienced it.
supercubep is offline   Reply With Quote
Old 04-05-2018, 07:34 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I have not had any DEF freezing problems in my '13 Super Duty. The DEF tank is heated. There are required sensors to tell you if the DEF freezes and is not dosing the SCR correctly. Mine might go to limp mode.
There is just a lot of diesel trucks out there with DEF tanks.
DEF does freeze as it is what, 70% water.
David
WBCCI #8607
VAC Region 11
Link to my 1975 Overlander Improvement Journal:
https://www.airforums.com/forums/f17...ml#post2053792
Old 04-06-2018, 08:14 AM   #3
1969 31' Sovereign
McCall , Idaho
DEF Freezing
I know the tank is heated, but how about when the vehicle is not in use?
Old 04-06-2018, 09:31 AM   #4
dznf0g's Avatar
Oswego , Illinois
It begins freezing at 17* and becomes a slush at down around 13*F. The system has a time out for DEF injection and corresponding code setting until after the heater is activated for a few minutes after cold startup. Since there is a very little bit of DEF injection at any given time, it only needs to thaw a small amount right around the pick-up tube. As operation continues, the whole jug eventually becomes liquid.
In EXTREME arctic conditions it is sometimes necessary to install additional insulated and heated covers over the jug....but we're talking extreme conditions (ie. Prudoe Bay fleets)
-Rich-
Old 04-06-2018, 09:44 AM   #5
1986 31' Sovereign
Miami , Florida
Basically, you are fine as long as you don't top off the DEF tank when freezing temperatures are expected. This allows room for expansion as the DEF freezes.
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 04-07-2018, 08:18 AM   #6
1969 31' Sovereign
McCall , Idaho
DEF Freezing
Thanks for the valuable input!
Diesel/DEF mileage. ROBERTSUNRUS Tow Vehicles 28 03-19-2014 11:47 AM
DEF Fluid eliasurbina Sprinter and B-van Forum 8 11-23-2013 11:29 AM
Def aa9zz Sprinter and B-van Forum 4 10-03-2013 11:34 PM
Diesel Exhaust Fluid (DEF) Brentsouth Sprinter and B-van Forum 17 04-13-2013 02:18 PM
Hi-Def on the road????? FlaAirstream Full-Timing 2 11-26-2007 06:30 PM
