Old 01-06-2013, 06:39 AM   #1
SteveH's Avatar
Common Sense , Texas
Cummins Oil Change
How frequently do you change the oil in your Cummins Diesel engine, and what type oil do you use?
Steve
Regards,
Steve
Old 01-06-2013, 07:33 AM   #2
Gruveeman's Avatar
Panama city , Florida
I have a '93 Dodge D250....new to me within the last year. Book says 5000 miles. I change @ 4500 with 15W-40 Rotella. NW Fla weaher, daily driver, 5500# once a month or so. It lives an easy life.
Gruveeman is offline   Reply With Quote
Old 01-06-2013, 07:44 AM   #3
sandlapper's Avatar
1993 34' Excella
York , South Carolina
I change mine at 5000 miles. Fuel filter every 10,000. It's not a daily driver, mostly for towing, not as much as I'd like to. I drive it every week even if not towing
Our local Dodge dealer has a cracker jack diesel tech, military trained. I do whatever he says. Don't even know the brand oil, just that it is the low sulfer type.
Thanks for putting out the question, looking forward to the replies.
John
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 01-06-2013, 07:57 AM   #4
Vintage Kin
Fort Worth , Texas
Year model & engine spec. In over 20-years of production there is a range of expected time/miles recommendations.
On mine: 7,500 - 15,000 miles or one year depending on use.
12-quarts of SHELL Rotella 05W-40 and a BALDWIN or DONALDSON filter.
I usually replace the fuel filter (BALDWIN) and air filter (MOPAR) at the same time just to be consistent.
Brings my minimum annual cost to around $120 for parts/supplies.
Old 01-06-2013, 09:19 AM   #5
pgr32e's Avatar
1974 27' Overlander
Sault ste Marie , Ontario
I've got the 98 24 valve, Change the oil and filter spring and fall, usually rotella 15w 40. K&N air filter cleaned as needed and a fuel filter in the spring.....Phil.
pgr32e is offline   Reply With Quote
Old 01-06-2013, 09:20 AM   #6
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
2007 Dodge pickup. Oil & filter 3500 miles. Dino oil
Old 01-06-2013, 10:31 AM   #7
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I have a 99 Dodge 2500. Change oil every 30,000 using Delvac 1 Synthetic diesel oil. Change oil filter at 6000 mile intervals using Fleetguard filters.
The fuel filter gets changed at the same intervals as the oil.
I have had the oil analyzed several times and no problems.
I went to the Delvac 1 at 100,000 miles after the warranty ran out.
I am now at 570K and all is well.
I originally went the synthetic route because I was delivering trailers and when I had to get an oil change on the road they would usually use a gorilla to tighten the drain plug. I can change an oil filter by the side of the road with little difficulty.
Were I not running the Delvac I would likely use rottella and change every 6K or so.
We live in a rural area and the truck rarely sees any city type driving. Always gets fully warmed up etc.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 01-06-2013, 03:37 PM   #8
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
My truck goes no more than 5k oil changes due to the emissions components. Egr valve puts a lot of soot back into the engine and possible fuel dilution caused by dpf regeneration events.
I have had local dealers send me oil change coupons but there was a $30 difference in price. One dealer was $79.95 and the other was $109 for the same service. Go figure......
Three years back I bought an oil change contract from Chrysler good at any dealer nationwide, 6 prepaid oil changes to be used within 3 years cost ~$37 each.
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 01-06-2013, 04:42 PM   #9
crisen's Avatar
2012 25' FB Eddie Bauer
Fairbanks , Alaska
Steve
Steve,
Your 6.7 required different oil than the older 5.9's. The oil must meet Cummins spec 20008. This requirement is stated in the owners manual diesel supplement.
I use Valvoline Premium Blue Extreme synthetic. It is 5W-40. The standard Premium Blue in 15W-40 also meets the Cummins spec and may be more appropo in your climate which warmer than Fairbanks! For filters I use the Fleetguard Stratopore.
Max oil change interval is 7500 miles and I find that when towing the oil change reminder which is duty cycle based goes off around 7k to 7.5k miles. If you do in town a lot it will go off sooner, some guys who use their trucks for grocrey getters find it goes off in 2000 miles.
I also installed a Fumoto oil quik drain valve and it sure cleans up doing an oil change.
Hope this helps.
Rick
"When you find yourself in a hole - quit digging!"
2012 1/2 Eddie Bauer, 2016 Ram Laramie 3500 SWB 4x4 6.7L Cummins 68RFE
crisen is offline   Reply With Quote
Old 01-27-2013, 12:00 PM   #10
5000 miles or once a year. Any 15W40 C-4 oil. I use Delo because I can get it cheap at Costco. My Cummins book on QSC engines recomends against synthetic oils.
handn is offline   Reply With Quote
Old 01-27-2013, 06:01 PM   #11
ALí UM- MONEY's Avatar
1976 31' Sovereign
Ball Ground , Georgia
Duramax oil change
I don't want to change the discussion from Commings but I have a new(4500miles) Duramax. Do most of you change by time or mileage or do most trust the computer to determine when it is time. Does the same thing go for the computer and fuel filter change. Thanks.
A husband is the biggest baby you will have and take the most adult supervision.
Gene and Elaine Thomason
Ball Ground Ga.
1976 31 foot Sovereign
2011 GMC 2500HD Denali
6.6 Duramax Diesel
ALí UM- MONEY is offline   Reply With Quote
Old 01-27-2013, 06:35 PM   #12
SteveH's Avatar
OK, I finally got the owner's manuel for the '12 Ram Cummins, and it recommends 7500 mile, or six month oil change intervals.
Regards,
Steve
Old 01-27-2013, 07:05 PM   #13
RUMSHIP's Avatar
1988 32' Excella
Bonita , California
Images: 16
It's new. Take it to your dealer so it gets done right. You spent a lot of money for a good truck. Don't cheap out on the oil changes and screw it up along with your warranty. That being said, I have mine changed at the dealer every 5k. It's easier to keep track with mileage that way. They can also change out the fuel filter and do flash updates if needed while its there.
Happiness only real when shared.
Christopher Johnson McCandless
2/12/68 - 8/18/92
RUMSHIP is offline   Reply With Quote
Old 01-27-2013, 10:46 PM   #14
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***
Same as Crispy; 5k miles.
2015 25' Eddie Bauer Int Sp Ed
2015 Chev Duramax 2500; equalizer hitch
AIR# 44105; formerly WBCCI 2015.1
Terminal Aluminitis; 2-people w/ 2-dogs
