Old 12-03-2013, 09:36 AM   #15
SteveH's Avatar
Common Sense , Texas
Originally Posted by Wabbiteer View Post
On the same convenience theme I've seen on F-150s, once engine repair gets involved, they'll lift the body off the frame rather than work in the engine compartment.
I've heard/read that is the norm when doing most any work on a Ford 6.0 or 6.4L Diesel engines, and can really run the cost up as the labor rate is something like 21 hours to R and R the body.
Regards,
Steve
Old 12-03-2013, 09:39 AM   #16
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
No worries you just got one that was defective.The new motor will be fine.
Things happen.
Old 12-03-2013, 09:43 AM   #17
Ottawa , ON
I guess I would feel lucky that it happened while under the guarantee!
Can't recall hearing about a cracked block since the Year Gimmel.
Which engine do you have?
Old 12-03-2013, 09:46 AM   #18
2003 22' International CCD
East Durham , New York
Cracked engine
It's the 4 liter v6.
James
bluvalley is offline   Reply With Quote
Old 12-11-2013, 12:52 PM   #19
K.C. , Missouri
I agree with the others you just had a fluke failure. In general, the VQ engine series is very reliable with few recurring problems. I tow with a '06 Frontier like yours, same engine, same manual trans. This truck has 90K miles with about 35K miles of that towing.
gmw photos is offline   Reply With Quote
Old 01-01-2014, 05:23 PM   #20
Retired
tvketchum's Avatar
2008 30' Classic
Livingston , Texas
My only thought is the manual transmission, if you are not letting the engine revs get high enough before upshifting and/or not downshifting soon enough, the engine may be lugging, even though you may not be feeling it or hearing it. A lugging engine will develop hotspots as well as wear components prematurely.
Tom
AIR 71620
WBCCI 5809 Reg 5 Unit 041
2008 Classic 30'
2013 F150 Ecoboost
tvketchum is offline   Reply With Quote
Old 02-02-2014, 12:57 PM   #21
1999 34' Excella
Cinnaminson , New Jersey
it happens... nothing you did made that happen and nothing you can do will prevent it from happening again. It wont happen again. I'm a Diesel mechanic for Caterpillar I can tell you sometimes small imperfections (very small) can make it past the elaborate checks that almost every engine manufacture does. In the industry we call it a porous block. Most likely not a crack, but was an imperfection in the casting process that was just was too thin. eventually the temperature changes and vibrations caused a pin hole to develop and the leak occurred. Also can be influenced by poor cooling system maintenance. low quality coolants that do not have the correct corrosion and inhibitor packages and accelerate that kind of a failure. This is the reason you have a warranty. Even if you were out of the warranty period by a little, most manufactures will still replace it because its a manufacture defect. No engine out there should expect to have a block failure ever... if it was taken care of and doesn't suffer damage from another failure like a crank or bearing. In 18 years I've seen it happen 3 times, and one of them was on a remanufactured engine so its questionable if it was a casting issue.
You got a new life on the motor don't worry about it. biggest thing to keep an eye out for are leaks like hoses and fittings. most were reused and something can leak in the future.
excellaf350 is offline   Reply With Quote
Old 02-02-2014, 01:28 PM   #22
new engine
Hi, and thanks everyone for your responses. I decided to trade the truck in a get something else. I simply didn't trust the Nissan after this happened. I'm now a very happy owner of a 2014 Chevy Silverado. The dealer gave me an incredible deal on the trade (probably because it had a new engine). The new truck is awesome. My first American car! I love it. Haven't towed yet but certainly not worried about it, it gets better mileage as a daily driver than the Frontier, even with a V8!
Thanks for all the thoughtful responses. I'm looking forward to my first camping trip in the spring.
James
Old 02-02-2014, 02:07 PM   #23
withidl's Avatar
2002 31' Classic
Houston , Texas
Originally Posted by crispyboy View Post
It can happen to any brand but typically it is a casting issue but sometimes it is a design issue.
From 1999 to 2001 Cummins had a B series engine which was known as the "53" casting block could develop cracks.
Cummins # 53 Block Casting | Identification, History, & Repair
Another engine that was known for cracked blocks were the Cadillac Northstar engines. A member in our family had one of these infamous cars that developed a crack.
It wouldn't surprise me that there isn't more trouble with cracked blocks as auto manufacturers are always trying new methods/materials to get costs down. Most engine troubles seem to show up with warped cylinder heads where an aluminum alloy is used or the manufacturer doesn't use enough or the correct type of fasteners to keep the cylinder head from warping.
I would keep driving the vehicle with the new engine but one thing you may want to do is let the engine idle for a couple of minutes after making a particularly hard tow or driving the interstate - this helps to cool down the internal components or other hot spots in the water jacket.
Regarding the Cadillac Northstar engine, my mother has a 2003 Sedan DeVille which experienced this problem as evidenced by the #4 cylinder "hydraulically locking" with coolant after engine shut-down, which is actually due the steel head stud threads electrolyzing with the aluminum block threads and thus releasing the torque holding the heads against the gasket. The dealer fix was to R&R the engine and install "time serts" in the block for ~$4,000.
My solution was to pour a new product, "Bar's Leaks Head Gasket Fix" (rear label actually states that it fixes Northstar engines), into the coolant system which after ~two years has maintained the problem.
The product has also maintained my 1990 Lincoln Continental engine with head gasket problems. The stuff seems to really work.
withidl is offline   Reply With Quote
